Like Tree26Likes
Old 11-23-2013, 02:39 AM   #12946
Originally Posted by S1CK-M1ND3D View Post
Hey Guys!!!
I ran my 210 mid motor last night and had it geared way off so I pulled spur off and re-geared it and it started slipping real super bad so I ended up burying the the slipper and it still slipped then I buried the diff and still slipped.What could it be??? ....
Hi,
Did you check, if one of the shims (TD709032) is missing in front, or behind the spring?
If not, may u can try one extra shim!?
Just a thought.
A new sprig, normaly is not needed.
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 11-23-2013, 04:25 AM   #12947
coaltrain's Avatar
Originally Posted by jsrocket13 View Post
Hey guys I have a few questions about this car as I just picked one up slightly used cheap for my 5yo daughter it's a RTR now does it have the big bore shocks and the plus 8mm chassis? What kind of after market body will fit it only because I want to paint it more to her liking.
Yes, it does come with BB shocks and the +8 chassis, this is the only body made to fit the DIMEC +8 http://www3.towerhobbies.com/cgi-bin...?&I=LXCUXF&P=7
I still say you should run the 210 and give her your 22 2.0
DEX210 DEX410 MIP-SCTE
coaltrain is offline   Reply With Quote
Old 11-23-2013, 10:48 AM   #12948
will these tires fit the wheels that comes with the 210 kit?
http://www.amainhobbies.com/product_...Tires-Yellow-2
What inserts should i go for? aka red cells?
out track is astro turf
these_savages is offline   Reply With Quote
Old 11-23-2013, 02:15 PM   #12949
jsrocket13's Avatar
Trader Rating: 26 (100%+)
HAHA!!!!!!!!!!! Just a stepping stone for her and when she's ready for 213 I'll get to stock up on $13 spur gears yeah.
RIP Motorsports, TLR, Airtronics, Tekin, Trinity, BSR, Protoform, Pro-Line, OHP supporter.
jsrocket13 is offline   Reply With Quote
Old 11-23-2013, 02:51 PM   #12950
Trader Rating: 29 (100%+)
Yes they will both mount to the kit wheels. Inserts you don't use them in those front tires, and for the min pin rears i like the Panther orange inserts they are firm.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 11-23-2013, 03:01 PM   #12951
Trader Rating: 96 (100%+)
Originally Posted by micholix View Post
Hi,
Just a thought.
The shim is there the coils on the spring is completely compressed.
S1CK-M1ND3D is offline   Reply With Quote
Old 11-23-2013, 04:19 PM   #12952
thanks bro. do you think this is a good setup for the 210 on astro?
also.. did u say no inserts/foam in front tires??
im gonna order everything on amain i think, doesnt look like they have panther orange there.. hmm any other suggestions?
Old 11-23-2013, 05:19 PM   #12953
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
That's right.. no insert/foam... you mount them like this on the rim and then cut off the excess inner portion with a dremel... it makes them skinnier... that's the Euro way of carpet/astroturf racing.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 11-23-2013, 06:03 PM   #12954
Speedo711's Avatar
Default Dex210 bodys
I have been working on vacuum forming my own bodies for my dex210...I have these sketches and some 3d computer models for 3d printing molds.... which one do you like the best?
Durango DEX210 Thread-body2.jpg   Durango DEX210 Thread-cabforward1.jpg   Durango DEX210 Thread-team-durango-dex210-2wd-buggy-3.jpg   Durango DEX210 Thread-final.jpg
Team Durango DEX210-Novak-Promatch Racing-Mid Motor
Team Durango DEST210-Trackstar-Novak-Promatch
E Olsen
Speedo711 is offline   Reply With Quote
Old 11-23-2013, 07:13 PM   #12955
rcjunky1's Avatar
The last one. Nice steep cab forward, lots of side area and lots of room for wiring the esc down the center.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 11-23-2013, 07:25 PM   #12956
kornatoa's Avatar
Maybe if you could combine 2 and 4. Always liked the shark fin on racers.
You want me to put that in there. Ok but hold my sign I don't want to lose that thing.
kornatoa is offline   Reply With Quote
Old 11-23-2013, 08:45 PM   #12957
Just as stated above, mount the fronts exactly like the picture, you can dremel off the extra or just run the like the pic shows. I trim them as it looks better and its less weight not much but every bit helps. You can order the Panter foams straight from panther http://www.panthertires.com/store/in...product_id=183
I would use AKA reds if you don't go with Panther.
Old 11-23-2013, 08:47 PM   #12958
I like number 4.
Old 11-23-2013, 09:54 PM   #12959
P6
I wonder if a ss panther slick would work like a narrow tire like that on wet clay maybe a thin foam if it felt to soft
P6 is offline   Reply With Quote
Old 11-24-2013, 12:49 AM   #12960
1 and 4 I'd buy the first one for sure.
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
