Like Tree17Likes
Old 11-14-2013, 09:18 AM   #12886
RC10Nick's Avatar
Originally Posted by spbrown86 View Post
Hi all, im just getting into off road RC, new indoor track opened up up the road, and im very interested in the DEX 210. Ive been searching all over, but every place I look the kit or the Rtr is back ordered. Does anyone know why? Are they just having trouble filling demand or something else?
A new dex210v2 is in the works. It doesn't sound like it will be out until February-ish. Until then, it's pretty likely the current kits won't be restocked. I'd love it if they were restocked and sold at the blowout price they had a month or two ago, but don't really see that happening.
If you want a 210, either wait for a new updated version, or find one used somewhere.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 11-14-2013, 09:50 AM   #12887
I wonder when the new gear case will be out? It says mid November. It is mid November.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 11-14-2013, 09:54 AM   #12888
GregerL's Avatar
Originally Posted by ae4ever View Post
That's a measurement of shock length, correct me if I'm wrong but droop is how much down travel the shock has at ride height?
Almost correct, actually droop can be seen as the amount of up-travel from ride-height the chassis can have until the wheels leave the ground, or the amount of down-travel the arms can have from ride-height.
This means that the same amount of droop when measured on the shocks will give different actual droop for different shock mounting locations.
No matter how you choose to define your droop the most important thing is that you can get a consistent measurement that does not depend on changes in your suspension geometry, i.e. shock placement.
GregerL is offline   Reply With Quote
Old 11-14-2013, 02:14 PM   #12889
Mopar's Avatar
What's different with the new case?
Mopar is offline   Reply With Quote
Old 11-14-2013, 02:23 PM   #12890
ekt
ekt's Avatar
It has an additional camber link hole and has more material reinforcing that area.
The sway bar mount is also part of the case now instead of being a separate piece.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 11-14-2013, 02:25 PM   #12891
Mopar's Avatar
Thanks! The picture on Durango site only shows one set of holes.
Old 11-14-2013, 03:04 PM   #12892
Hey guys dumb question but I just got some springs
TD330143 Light Red Front Spring 49gf/mm
TD330136 Black Spring 47gf/mm
That is what the packaging reads, I thought they are supposed to be switched the black spring being heavier and light red being lighter. Is this a misprint on the package or has something changed from durango?? Im a bit confused and dont want to be mixed up when making a spring change.
mindless is offline   Reply With Quote
Old 11-14-2013, 03:54 PM   #12893
ekt
ekt's Avatar
The type B gear box has a different part number #TD310459
Interesting, will have to contact TD about that. Most places have the black listed as the harder spring though.
Leo Lorenzen
Old 11-14-2013, 04:10 PM   #12894
8ight-e's Avatar
Trader Rating: 57 (100%+)
Jump to about a minute in on this Adam Drake how to setup droop video. BTW he leaves his tires on, I guess this could be more accurate, and with a buggy it's easy.. sct with bumpers a little harder.
http://www.youtube.com/watch?v=H99PKqsUZjA
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 11-15-2013, 03:01 PM   #12895
GregerL's Avatar
That is a great method if you never change your shock mounting location.
Old 11-15-2013, 05:58 PM   #12896
Question on chassis. If I am planning to just run 17.5 blinky class, which chassis would be recommended, the aluminum or the dimec type b. I will be racing on a variety of surfaces from high bite glued surface to low bite clay. Thanks for any input
fanfor18 is offline   Reply With Quote
Old 11-15-2013, 06:50 PM   #12897
ae4ever's Avatar
Droop will always change when you change shock mounting location unless the manufacturer took that in consideration when designing the suspension.
ae4ever is offline   Reply With Quote
Old 11-15-2013, 06:59 PM   #12898
Wow, I am honestly speechless that a "pro" considers that a way to measure droop. It is however a way to verify each side is equal.
Old 11-15-2013, 07:22 PM   #12899
Trader Rating: 18 (100%+)
I could see doing that after actually checking droop to make sure it's the same left to right but if you move your shocks them it changes everything...
I've been checking mine by removing the wheels and putting the chassis on a parts container that is 27MM tall. Then measuring the height of each axle. If it's 25MM then I have -2MM droop.
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 11-15-2013, 07:26 PM   #12900
rcjunky1's Avatar
I normally run an alloy +8mm chassis but will be running a dimec type b for17.5 at Motorama (as well as probably some club racing before that) Its lighter and light is good for 17.5 (especially rotating mass, but can't justify the cost of the lightweight outdrives and axles )
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16561 Yesterday 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
