Like Tree26Likes
Old 11-12-2013, 01:56 AM   #12856
Trader Rating: 520 (100%+)
Originally Posted by Slash and Burn View Post
I've ordered the lowered shock from Diggety Designs and filed my existing rear hangar down just to try it and it seems to help, so I'm trying to figure out which one to buy, I'd like to get the TD one, but can only seem to find it on TD.com and don't want to pay the $65 shipping, anyway, I'm rambling on...
What chassis are you running, have you tried any of the after market chassis's?
I am running the type "B" chassis, I do have an aluminum chassis here that B-man made a few months back, but dont have alot of time on it. Lately I have been running blinky class, and the type "B" is quite a bit lighter than the aluminum.
flame56mx is offline   Reply With Quote
Old 11-12-2013, 03:24 AM   #12857
The Czechexican's Avatar
Anyone know of a good set of drill bits for drilling out pistons I need 1.2mm 1.3mm.
thanks.
:DEX210:
:DEX410V3:
MARCCA Carpet Racer.
"I Huff SXT 3.0"
The Czechexican is offline   Reply With Quote
Old 11-12-2013, 03:41 AM   #12858
ekt
ekt's Avatar
thanks.
I use http://www.amainhobbies.com/product_...ston-Drill-Set for drilling pistons
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 11-12-2013, 04:04 AM   #12859
Trader Rating: 57 (100%+)
I'm going to have a few of the LRC RR hangers soon. A friend in Scotland ordered a few and I'd bringing them over. The UK price plus shipping make this an expensive part though. He has 2 extras not sure about the price but my guess is around $40. Let me know if you're interested.
shagino is offline   Reply With Quote
Old 11-12-2013, 06:54 AM   #12860
Just wondering if this has happened to anyone else. I've had a desc210 for almost a year and one thing that has been bulletproof through all the races is the trans. The gears the case all of it. I've taken it apart and rebuilt many times. I just got a new dex210 rtr and ran it once and took it apart to change the diff fluid and put it back together. Seem to be running ok but would always slip even after slowly tighten the slipper then just I tightened it all the way. Still slipping wtf. When I took it apart to try new pads the pin that goes thru the spur and into the trans locked onto the keyed shaft that drives the gear inside the trans. I tried everything to get it off so the spur motor plate a bearing the spacer inside and that shaft are all stuck together. I've built the trans many times so I'm not sure I messed it up idk what happened. Anyone else have this trouble. I ordered new parts so ican just break the pin and replace it. But I'd like to know if it was my error or not to prevent it from happening agian.
Badcompny44 is offline   Reply With Quote
Old 11-12-2013, 06:57 AM   #12861
Ill post a pic after I get the parts and show you guys and maybe you can tell me what I did wrong or what happened excatly. Like I said it could be my fault but I've built the trans a lot.
Old 11-12-2013, 07:33 AM   #12862
Devin's Avatar
What chassis do you guys like for outdoor dirt tracks? The longer chassis or the stock aluminum? I bought it used and it came with both, not sure which one to try first.
Devin is offline   Reply With Quote
Old 11-12-2013, 08:17 AM   #12863
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
I prefer the long chassis 100% of the time on an out door track. I feel it just makes the car easier to drive harder.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 11-12-2013, 09:38 AM   #12864
ink'd's Avatar
is the kit chassis the +8 or is it the same length as the RTR?
Team Durango
http://www.rctech.net/forum/r-c-items-sale-trade/772144-brushless-motor-esc-saddle-packs-crawler-rims-tires.html#post12728946
ink'd is offline   Reply With Quote
Old 11-12-2013, 10:03 AM   #12865
Devin's Avatar
The aluminum kit chassis is the same size as the rtr I believe, but in aluminum.
I thought the added weight of the aluminum might help grip and be the default outdoor chassis, but I can see the advantage of more stability, especially with our high speed corners.
The long chassis is what's in use right now, didn't think it would be preferable, but I'm happy to keep it as is and give it a whirl first.
Old 11-12-2013, 10:19 AM   #12866
GregerL's Avatar
The kit chassis is original length, and the RTR is the +8 chassis The RTR is also a bit wider in the side pods than the kit.
GregerL is offline   Reply With Quote
Old 11-12-2013, 02:02 PM   #12867
GasGod's Avatar
Anyone run droop? If so why? New to the dex 210
Manual says nothing-about settings and I am confused
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 11-12-2013, 02:35 PM   #12868
I haven't yet, meaning I run at full droop, no limiting. I played around with it a little when I ran mid motor last year. If you run the stock rear shock shafts (silver) some have said it helps to run a little less droop to help the cvd's from catching the out drive slots on full extension. If you run the ti shafts (black or gold) they are 3mm shorter and eliminate that issue. I am assuming the droop screws would be more of a tool aimed at rug racers..
Old 11-12-2013, 02:44 PM   #12869
ink'd's Avatar
has anyone noticed a night and day difference between the kit and the +8 aluminum chassis?
i actually need a new chassis (mine is scratched to sheet) also if anybody has new extra parts/rims/upgrades i'm always looking to buy.. am i allowed to post that?
Team Durango
Old 11-12-2013, 03:58 PM   #12870
Trader Rating: 18 (100%+)
I run max droop front and rear. Helps when your driving on a small indoor track that is blown out to hell and amazingly rough with terrible faces on the jumps.
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
