Like Tree26Likes
Old 11-09-2013, 01:48 PM   #12826
Trader Rating: 29 (100%+)
Originally Posted by ink'd View Post
does anyone run on smooth clay? (literally smooth clay)
if so, what is your recommended setup?
also, any pics on how to do the mid motor setup? 210 noob..
My High Bite setup is on post 12452. Also scroll down and there is pictures of the buggy.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 11-09-2013, 02:29 PM   #12827
ink'd's Avatar
thank you! sexy 210 btw!
Team Durango
http://www.rctech.net/forum/r-c-items-sale-trade/772144-brushless-motor-esc-saddle-packs-crawler-rims-tires.html#post12728946
ink'd is offline   Reply With Quote
Old 11-09-2013, 02:30 PM   #12828
ink'd's Avatar
guy at my local track said the 210 will be discontinued because of durango's new line?
think they will stop producing 210 parts? i see the bulldog body has already been discontinued..
Team Durango
Old 11-09-2013, 04:12 PM   #12829
There has to be a new buggy coming but I believe it will be a version 2 with just a few upgraded parts. Even if its a whole new buggy they will continue to produce 210 parts for a long while.
Old 11-09-2013, 04:43 PM   #12830
rcjunky1's Avatar
It is in fact a dex210v2 that is expected to be available late February, too late for Motorama The new dex410v4 is expected late December, I'll have to look into the SC and st.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 11-09-2013, 07:14 PM   #12831
platgof's Avatar
Did a shock trick that worked well. I drilled out some shock pistons with a #30 drill bit and put them on the bottom of the shocks to limit travel. It helped to stabilize the buggy, and stopped excess air from getting in the shocks. I do not like it when shock pistons come up to high and leave the shock body. This is a negative situation that will just cause problems. I like the piston to stop just before the top of the travel in the shock body, not in the cap like mine were.
platgof is offline   Reply With Quote
Old 11-09-2013, 08:28 PM   #12832
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Thumbs up
Originally Posted by TAMAK View Post
Here ya go! Setup is dialed!
Attachment 1091372
Looks awesome! I've also been thinking about doing this to my DEX210 especially when I look at the worlds pics and I've seen a few RB6 setup this way as well. Are you also able to fit a full size pack? Can you post a pic of that if you can?
Also I wonder why you've turned your shocks around…I've done it but hated how much damage I would take when I'd get rear ended…especially by a short course in practice. Those things destroy little 2 wheelers!
Thanks!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 11-09-2013, 08:32 PM   #12833
Trader Rating: 18 (100%+)
Puts more weight behind the rear axle without adding any extra weight. Should give you more rear traction. I did it too hit also made a slew of other changes last night out so I can't say for sure how effective it was...
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 11-09-2013, 08:51 PM   #12834
13Maschine's Avatar
I might try it again when I'm not trying to avoid giant trucks...
Old 11-09-2013, 08:56 PM   #12835
rcjunky1's Avatar
The wing will save the shocks most of the time. I'm not worried about the rear mounted shocks.
Team Durango Canada
Old 11-10-2013, 07:20 AM   #12836
i got mine setup the same except i got my batt. to the front of the servo better turn in and more ballanced when jumping.
ScottZ is offline   Reply With Quote
Old 11-10-2013, 07:28 AM   #12837
That's what droop screws are for man.
homershoots is offline   Reply With Quote
Old 11-10-2013, 08:07 AM   #12838
Trader Rating: 57 (100%+)
Did you use the blanks for this? I can't imagine that'd be good but the piston would be free floating otherwise. Sounds like it's really being used as a shock limiter. Use the droop screws like Homershoots says. Do you have the black rubber stoppers in also?
If you reversed the arms, I think using using plastic 1 mm washers may be a better solution.
shagino is offline   Reply With Quote
Old 11-10-2013, 02:59 PM   #12839
platgof's Avatar
When you flip the shocks to the rear, no droop screw. Now my shocks do not suck up excess air into the oil. I had extra pistons for the small bores that I would never use anyway. I am also using the black stoppers.
Old 11-10-2013, 04:03 PM   #12840
GregerL's Avatar
I believe you two are talking about two different things. Droop screws are for limiting down-travel. If you don't want your piston entering the cap it is up-travel that should be limited.
I am guessing these blanks are fitted just above the spring perch below the rubber stopper. Right?
GregerL is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
