Like Tree17Likes
Old 11-08-2013, 12:54 PM   #12811
Dino_D's Avatar
Originally Posted by iTz Nicholas72 View Post
Think Durango will release some LRC RF blocks so you don't have to run 3* antisquat. Better yet offering an entire LRC combo in plastic would be great so I don't have to spend $20 on something that I might not even like/use.
They need to make the RF block in aluminum so we don't need to go get an aftermarket version, and it should be a LRC version, with an included shim to raise it back to the normal height for HRC. This way 1.5 or 3 is 3 degrees, so we don't need to do math and subtract X - Y.. Make it simple. Add shim or remove shim for HRC or LRC in the front.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 11-08-2013, 01:02 PM   #12812
Excellent idea.
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 11-08-2013, 03:12 PM   #12813
Trader Rating: 57 (100%+)
The only problem with this is shims raise the gearbox. Rcjunky1 makes an aluminum hanger that does this. A friend noticed that the gearbox doesn't quite sit flush with the shims. Even running at 1.5, it was slightly higher. The top deck pretty much brings it down but not flush for the OCD folks. Also he wasn't able to get 3/3 when running mm due to clearance.
shagino is offline   Reply With Quote
Old 11-08-2013, 03:20 PM   #12814
tlr22 use that(shim) method for anti-squat,
it uses a shim under the aluminum RF hanger for roll center/anti squat adjustment, and an insert inside the hanger to take up the space between hanger and gearbox.
nicholasxuu is offline   Reply With Quote
Old 11-08-2013, 03:27 PM   #12815
That chassis may allow for the space. The method isn't bad. I just know it isn't flush in Durango's. Try it. You can probably dremel the gearbox though.
Old 11-08-2013, 03:37 PM   #12816
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Thumbs up
Originally Posted by Konich View Post
http://www.team-durango.com/in-the-p...rticle_id=4472
Personally I like the feel of the MM4 on high bite clay with the LRC rear end.
I've run my MM4 setup at SCVRC in SoCal quite a bit and it's pretty dialed. We run slicks when it is wet and when it's dry we usually run Barcodes or something similar. Super soft or clay compound tires. I am also running 18g weight via the Revolution rear suspension hanger.
http://www.revolution-rc.com/our-pro...ion-mount.html I've also been experimenting with the gear diff and about 5K-7K fluid. I've been running this setup for a while and I'm able to carry quite a bit of speed on the faster turns and I still have great low speed steering.
Hope this helps!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 11-08-2013, 03:40 PM   #12817
13Maschine's Avatar
I've also run my MM4 setup at OCRC but I've only had a few runs. It seems pretty dialed although initially I was pushing a bit….will post more next time I go!
Old 11-08-2013, 04:58 PM   #12818
Mopar's Avatar
Revolution makes the LRC mounts already. Complete set includes 3 RR mounts and 1 RF mount at A Main for around $65.
Mopar is offline   Reply With Quote
Old 11-08-2013, 06:26 PM   #12819
I like RDRP. Only problem is it won't work on a type B chassis. I like being able to share parts with my SC and ST.
Old 11-08-2013, 09:40 PM   #12820
Mopar's Avatar
What's the issue? Chassis clearance? If so just do a little surgery with the dremel tool.
Old 11-08-2013, 09:59 PM   #12821
ekt
ekt's Avatar
Each of the RR holders needs to be modified to accommodate the type B motor guard tab.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 11-08-2013, 11:17 PM   #12822
13Maschine's Avatar
Smile
Originally Posted by Woulvesbaine View Post
I looked when I first switched over and could not find a non- Cab For body.
I've looked around a bit too and haven't seen anything really for the longer chassis. Can anyone speak to what they are using for longer chassis?
I also hate cab forward….ALL OF THEM ARE UGLY!
Old 11-09-2013, 03:54 AM   #12823
tony montana's Avatar
Trader Rating: 65 (100%+)
What are you guys finding the type b chassis to do better than the stock aluminum? Also where in the world can I find the type b in stock?
K.C. Guy. Team Xray - rc america
tony montana is online now   Reply With Quote
Old 11-09-2013, 05:17 AM   #12824
rcjunky1's Avatar
if you need the chassis and the parts needed to convert to the Type B, order TDRZ2001 at your LHS. The central warehouse shows in stock, the west warehouse should have them soo, its the type b conversion kit, I think its the 3 parts but once I get mine I'll post here. Theres no info on it and its not on Tower's or Durango's site, so its going to be like christmas end of next week or early the following when it should arrive
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 11-09-2013, 12:49 PM   #12825
ink'd's Avatar
does anyone run on smooth clay? (literally smooth clay)
if so, what is your recommended setup?
also, any pics on how to do the mid motor setup? 210 noob..
Team Durango
http://www.rctech.net/forum/r-c-items-sale-trade/772144-brushless-motor-esc-saddle-packs-crawler-rims-tires.html#post12728946
ink'd is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16562 Today 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
