Like Tree24Likes
Old 10-28-2013, 04:53 PM   #12721
The dirt track here that was just changed would probably work well with MM4 since there are no sweeping curves. Just swing the rear around and accelerate as fast as possible. MM4 can definitely do that just fine. I'm not sure that I could get MM3 to work well on this layout. Perhaps but is the effort really worth it when the car has other options? Probably not. I know RM3 will work. Since the crowd at this track is mostly 4WD SCT or 1/8 scale, they really setup the new layout to cater to them. It would be hard to make anything else work well on it. The newest tracks popping up here where buggy is still popular are on the opposite side of town from where I live. It figures.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 10-28-2013, 05:01 PM   #12722
GregerL's Avatar
Originally Posted by jaank View Post
I'm using ball studs like this with a logner neck. Like the ones from TC5.
Should I change the amount of shims under the studs from stock?
If you want to keep the same setting as stock, yes you should change. Iti is the height of the ball/link that gives the setting, not the number of shims. With these I believe 1mm less should give about the same setting as stock.
I would also recommend using a short neck version for the inner side of the steering link, you will need to add a lot of shims to the outer one to compensate for bump steer, and you even might be going out of range on that adjustment.
GregerL is offline   Reply With Quote
Old 10-29-2013, 09:50 AM   #12723
???E-Racer's Avatar
Hey guys ive decided to get this chassis. I like the fact it's ready to run and you dont have to build it.
Novak, Viper, LRP
4wd Slash Platinum,4WD SC10,Stock Slash Latemodel Oval,Losi Slider,E-firestorm Bomber, Team Terribles,www.rkhobbies.com,GOLFLAND USA
???E-Racer is offline   Reply With Quote
Old 10-29-2013, 10:44 AM   #12724
I have gone to the MM4 setup for my local indoor clay track. I placed as much weight on the back wheels as possible. The handling & jumping is better then the RM3. I have no weight up front and steering is also very good. It does occasionally get a little loose if you drive off of the groove into dusty areas.
I also have a 22-2.0 and the MM4 DEX210 is running as good if not better. How many others are running MM4 in the dirt?
jpas is offline   Reply With Quote
Old 10-29-2013, 01:47 PM   #12725
But if there are no spacers in stock like at the front c-hubs?
I removed 1mm from anywhere possible and then maybe I'm going to work out the bump-steer.
jaank is offline   Reply With Quote
Old 10-29-2013, 01:57 PM   #12726
You don't have to build the RTR version. The kit is still very much a do it yourself affair. Keep in mind the RTR version does not come with everything necessary to convert to MM and the gear diff only has 2 planetary gears unlike the 4 available in the optional version. The kit version of the car comes with a ball diff.
Old 10-29-2013, 04:14 PM   #12727
8ight-e's Avatar
Trader Rating: 57 (100%+)
I grabbed a RTR for parts and it came with the parts to make it MM, it also comes with the gear diff,, huge bonus imo. The gear diff w/ 5k is dialed, take it over the ball diff any day... can go a touch lower if you have zero traction.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 10-29-2013, 05:16 PM   #12728
Trader Rating: 18 (100%+)
Only thing you need to buy to convert the RTR to MM4 is the Idler Gear Set, Two 5X10X4MM bearings, Idler Gear Shims, and an Idler Gear Shaft.
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 10-30-2013, 08:09 AM   #12729
Trader Rating: 68 (100%+)
Can someone tell me the advantages,of using mm3 vs mm4 what conditions,what differences do you feel with the two,thanks
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 10-30-2013, 08:46 AM   #12730
Konich's Avatar
http://www.team-durango.com/in-the-p...rticle_id=4472
Personally I like the feel of the MM4 on high bite clay with the LRC rear end.
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 10-30-2013, 08:51 AM   #12731
Trader Rating: 29 (100%+)
+1
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 10-30-2013, 09:14 AM   #12732
Konich's Avatar
Also I've found that running MM you almost have to have a extended chassis to get it to work well. The standard length I couldn't get to work as well.
Old 10-30-2013, 04:19 PM   #12733
Slash and Burn's Avatar
Trader Rating: 24 (100%+)
My son is trying MM4 and we are looking for setup advice. Did you change anything going to MM? Other MMs are working well at our track, the K car, the 22 and the AE Centro, so I'm assuming the 210 can be good also.
Any help is appreciated!
Shannon
A big "Thank You" to my son's sponsors:
Pro-Line Racing | O'Donnell Racing Fuel | RCAmerica / Xray | TeamSR
Slash and Burn is offline   Reply With Quote
Old 10-30-2013, 05:49 PM   #12734
platgof's Avatar
Just rebuilt the ball diff, and just added Acer tungsten balls. They are so smooth. I also made sure to use the concave side of the plate rings against the balls. This is the second one I have done, and they are so smooth and last a long time. I also upgraded my servo to Savox for some more speed.
platgof is offline   Reply With Quote
Old 10-30-2013, 07:23 PM   #12735
My rear end breaks free when I get on the power in a tight turn. Should I go with a lighter diff oil - running the RTR gear diff.
simonseize is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
