Like Tree26Likes
Old 10-23-2013, 12:54 PM   #12691
Trader Rating: 96 (100%+)
Thanks Dino... anyone have any setups I'm running a tekin gen2 17.5 combo rear motor setup and a 8.5 mid motor I run on large indoor clay track's with medium size jumps and 100 ft straight.
Thanks..
S1CK-M1ND3D is offline   Reply With Quote
Old 10-23-2013, 09:52 PM   #12692
Trader Rating: 18 (100%+)
Going to try shortest front links and see how I like those...
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 10-24-2013, 08:30 AM   #12693
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
Default New parts
Could be old news but it looks like new parts keep coming.
This Big Bore aluminium shock cap set is manufactured from strong and durable material.
Precision designed to provide secure shock cartridge closure, with added strength and professional race looks.
This set includes all the items you will need to mount your shock caps to increase smooth operation under all racing conditions.
Features: Custom Team Durango etched livery for professional race looks - Aluminium cinstrcution for added durability
Includes: 2 x Aluminium shock cap - 2 x 0-rings - 1 x set of shock stand-off inserts - Bleed hole seal kit and screws
Specification: Black
More can be found on TD parts page.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 10-24-2013, 11:41 PM   #12694
I hate to ask but I don't have time to read through all the posts Can someone tell me what springs people are running on clay med/high bite surface? I run in UT usual tires are MC scrubs/suburbs. If anyone can recommend what they would run that would be great. If you run AE or TLR springs let me know as either way I need to order but the TD springs are harder to come by.
daveb is offline   Reply With Quote
Old 10-25-2013, 05:25 AM   #12695
I run 4 hole pistons (2 holes epoxied shut) 27.5 front oil, 25 rear oil, Lose red/yellow springs (stock 22 spring rates)
Zak
PRS1 V3 (FM), Mugen MBX7 Eco
Team Absima UK
PR Racing UK
fivepointnine is offline   Reply With Quote
Old 10-25-2013, 05:58 AM   #12696
Trader Rating: 27 (100%+)
There have been a lot of setups added to team-durango.com recently and if you grab one of my most recent setups from there, it should get you pretty close.
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 10-25-2013, 09:20 AM   #12697
Also, petit rc has a whole page completely dedicated to setups for the 210. That is what I have used over and over to gather hints on everything from ride height to gearing. I did a google search for dex210 setup and it's the first result.
simonseize is offline   Reply With Quote
Old 10-25-2013, 09:06 PM   #12698
Does associated spurs fit? I want something lower than a 75t found on amain.
Crashkt90 is offline   Reply With Quote
Old 10-25-2013, 11:02 PM   #12699
Trader Rating: 57 (100%+)
Not out of the box. You either need the Tresrey conversion kit or you can slightly enlarge the hole.
RW makes a 69 spur for TD cars. Avid makes a 66 if you want to go that route.
shagino is offline   Reply With Quote
Old 10-26-2013, 03:25 AM   #12700
What pinion should I use with a 8.5 mid motor and a 17.5 rear motor I have a 69 tooth spur and a 87? Please help.
Old 10-26-2013, 06:30 AM   #12701
8ight-e's Avatar
Start w/ a 24/87 on the 8.5 +/- pinion size based on temps, bigger for the 17.5 26-28/69 id suspect but I've never dialed in a 17.5 on my buggy. 8.5's seem best 22-24 range.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 10-26-2013, 09:11 AM   #12702
8ight-e mind posting your setup sheet for your DEX210? When I tried yours for my DESC410 it was dialed!
Old 10-26-2013, 10:04 AM   #12703
8ight-e's Avatar
I have to update my current today,, I'll try to get it up. I finally have a pretty dialed setup. My old setup already on petit was pretty good and can be done w/ stock parts mostly... but this new one is better for sure.
Tekno ET48, EB48.2
Old 10-26-2013, 10:41 AM   #12704
8ight-e's Avatar
I sent the update to petit, but here is a link to dropbox CLICKME
I tried to make a note but on the front steering hubs if you don't have the revolution design R2 steering plate, use 4-5mm spacers, the r2 plate lowers the position of the link on the inside and you don't need really anything on the outside to level it. Nice part. I also added the sumo racing tranny brace to keep the inner pins from every having an issue so if you don't have this I would run about 2-2.6mm worth of spacers on the inside ball as well. I have the sumo part with 1mm spacer on mine.
Tekno ET48, EB48.2
Old 10-26-2013, 12:51 PM   #12705
Thanks eight -e. I put a 69/32 on and did some tests out front and is fast I don't know how it will work on the track. Thanks again I'll give the 87 and try.
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
