Like Tree43Likes
Old 10-22-2013, 12:49 AM   #12676
Trader Rating: 96 (100%+)
Is there any way to use 12mm hex on front? I just picked up a 210 and have a boat load of 22 wheels and tires that I'd like to use.
S1CK-M1ND3D is offline   Reply With Quote
Old 10-22-2013, 01:22 AM   #12677
Check out petitrc.com for the hex conversion parts
daveb is offline   Reply With Quote
Old 10-22-2013, 08:07 AM   #12678
Has anyone used Kyosho ball cups with appropriate ball studs?
jaank is offline   Reply With Quote
Old 10-22-2013, 08:10 AM   #12679
rcjunky1's Avatar
the 22 doesn't use 12mm hex, theres no way that I've heard of to use the 10mm 22 front hexes.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 10-22-2013, 08:44 AM   #12680
Dino_D's Avatar
If you do a search, there are posts where users have used 22 rims on the DEX210.
On a site note. For those who want to use share 4wd fronts on their 2wd car using the 14m hex, all you need is the DESC210R steering knuckle, DESC210 front axle, the plastic 14mm hex and pin.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 10-22-2013, 08:46 AM   #12681
EvanAZ's Avatar
Trader Rating: 99 (100%+)
http://www.petitrc.com/setup/durango...0_FrontHexMod/
For the rear I think you can use the SC10 hex. I had one on a buggy but got rid of it because I have tons of Durango wheels.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 10-22-2013, 09:50 AM   #12682
Trader Rating: 14 (100%+)
does anyone have a very successful MM4 setup for med-high traction clay? I tried it before from some setup sheets I found on Petit but was not successful, I want to try again since the Centro's are doing so well at my track.
Zak
PRS1 V3 (FM), Associated B64D
Team Absima UK
PR Racing UK
fivepointnine is offline   Reply With Quote
Old 10-22-2013, 04:41 PM   #12683
8ight-e's Avatar
Trader Rating: 58 (100%+)
lutz has a couple high bite setups on his web site.. I have yet to find a MM config that rivals the RM,, but I don't run on super high bite tracks so.....
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 10-22-2013, 05:00 PM   #12684
Thanks guys.. where can I find some good setups for a large clay track's edit size jumps and 100 ft straight I'm running a tekin gen2 17.5 combo rear motor and a 8.5 tekin mid motor.
Old 10-22-2013, 05:13 PM   #12685
Trader Rating: 18 (100%+)
Made my rear camber link longer #3 and it was so close to perfect. Now to get a little more steering on exit and I'll be set. That and finding the sweet spot for shocks. Running on a small medium bite extremely bumpy/rough track makes is hard haha
Awesomatix A800XA - Xray XB2 2018
iTz Nicholas72 is offline   Reply With Quote
Old 10-22-2013, 05:25 PM   #12686
mechanic77's Avatar
Yep, I'm running them with Losi 22 ball studs.....just make sure and drill the ball cups a little deeper for the front (if you're using stock turnbuckles), if you don't the turnbuckle will bottom out and ruin the ball cups.....I found out the hard way
Durango DEX210, Tekin RS, SMC 7.5, Savox 1258TG
Durango DEST210R, Tekin RS, LRP 8.5, Savox 1256TG
Ofna Nexx 8, Tekin RX8/1900kv, Hitec 5955TG (FOR SALE)
mechanic77 is offline   Reply With Quote
Old 10-22-2013, 09:34 PM   #12687
Has anyone tried using the desc210 hubs and spindles to use hex adapters?? If so can you post a parts list.
Also where can I find some good setups for a large clay track's edit size jumps and 100 ft straight I'm running a tekin gen2 17.5 combo rear motor and a 8.5 tekin mid motor.
Thanks.
Old 10-23-2013, 07:02 AM   #12688
Trader Rating: 40 (98%+)
Hi guys, I picked up a used 210 that didn't come with the servo horn or steering linkage. I made a linkage out of my parts box, but I'm having trouble getting a horn to fit, they all seem long. I'm headed to the track tonight and they don't carry TD parts. Will any other buggy servo horn work?
Ruger357 is offline   Reply With Quote
Old 10-23-2013, 07:11 AM   #12689
I've been told the losi 22 horns work well.
homershoots is offline   Reply With Quote
Old 10-23-2013, 07:38 AM   #12690
Dino_D's Avatar
Thanks.
Yes
#TD330382 - STEERING KNUCKLE SET
#TD330383 - FRONT AXLE (2pcs)
#TD310135 - ROLL PIN
Plastic 14mm Hex from the 210 or 410 kits or #TD310226 Aluminum 14mm Hex
The only thing you can't do in this setup is change the trailing axle location. It will always be in the 4mm trailing position.
St Ives RC Club B4Bandit Australian Racing 16574 11-04-2017 02:55 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
