Like Tree43Likes
Old 10-15-2013, 05:22 PM   #12631
GasGod's Avatar
Default Coming from mm 22
Hello-Just picked up a 210 rtr for crazy$$$.I have 2 22"s already1 rm 1 mm.I only have 2 packs thu the 210 and lovin the car right outta the box so far.Are the sumo braces a no brainer?I read somewhere if you file the servo mounts it "de-stresses" the front of the dimec chasssis.so do you all recomend the alum skids?I run mostly on a carpet offroad track thats sometimes brutal.Seen many snapped b4's.Gonna run rm3(stock)for a while then try mm4 after I get a feel for this buggy,any tips?
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 10-15-2013, 06:41 PM   #12632
tony montana's Avatar
Trader Rating: 65 (100%+)
Quick question, When running mid motor, what are the differences between 3 and 4 gear? Which will have the most traction? Also I just picked up a 81 tooth spur. What pinion should I start with running a tekin gen2 8.5?
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 10-15-2013, 07:01 PM   #12633
Trader Rating: 29 (100%+)
MM4 will have more traction. I would start with a 23 or 24 pinion.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 10-15-2013, 09:46 PM   #12634
ekt
ekt's Avatar
The sumo gearbox braces are a good preventative measure to avoid breaking the gearbox camberlink mounts. Personally I don't run them and haven't broken a gearbox yet but have seen others break theirs.
The aluminium skids will help reinforce the type A chassis to prevent breakages but if you're running on high grip carpet I would recommend getting a DIMEC20 or even the aluminium chassis for more consistent handling.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 10-16-2013, 03:07 PM   #12635
My son is assembling his kit and I noticed he's got some play in the rear arms where the hinge pin is. Curious if this is correct because the front end is spot on with no play at all but the arms drop without resistance (w/o shocks on). He followed step 12 and it shows no washers so I'm assuming its correct. It's about over 1mm of play, if I put a washer in their it's tight enough that my arms don't fall as there's a little resistance.
daveb is offline   Reply With Quote
Old 10-16-2013, 03:57 PM   #12636
Trader Rating: 520 (100%+)
The rears were a little loose on my car also, but you definitely would rather they be loose than too tight. If they dont drop under their own weight, its too tight. I have used Kyosho shims in the past Part #96641 and they are very handy for tightening things up a bit.
flame56mx is offline   Reply With Quote
Old 10-16-2013, 07:01 PM   #12637
are all the type b parts just a revised part for durability? Same geometry?
Old 10-16-2013, 08:00 PM   #12638
As far as I've seen yes, but the new trans case is also supposed to ease some maintenance issues when removing or servicing the back end..
Old 10-16-2013, 08:34 PM   #12639
ekt
ekt's Avatar
Some for durability, others are for ease of working on the car. Same geometry.
Leo Lorenzen
Old 10-16-2013, 10:08 PM   #12640
Trader Rating: 18 (100%+)
I'm liking the new Type B hangers. No more pivot balls that like to cause hassle when adjusting anti squat etc. Now to order the Type B gearbox and rear brace to make changing antisquat less of a nightmare!
Awesomatix A800XA - Xray XB2 2018
iTz Nicholas72 is offline   Reply With Quote
Old 10-17-2013, 04:53 AM   #12641
peter george's Avatar
Trader Rating: 352 (100%+)
Originally Posted by Walkman View Post
17.5 gearing 33/69.
gotta put all this new info in my set up book. Gonna try out the 210 for the first time this weekend in 3M configuration. A lot of useful info on this thread,thanks to everybody.
Team Underdog - Team UPURZ -
peter george is offline   Reply With Quote
Old 10-17-2013, 05:07 AM   #12642
8ight-e's Avatar
Trader Rating: 58 (100%+)
Anyone using that newly re-designed RDRP front steering link? Looks pretty sweet...
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 10-17-2013, 09:14 AM   #12643
Oasis's Avatar
Trader Rating: 36 (100%+)
Did they make a change to the one that is like the kyosho style?
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 10-17-2013, 10:56 AM   #12644
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Hey All,
I picked up couple DEX210's for our program and one was a parts roller, it needs a few things to get it going. Also picked up a DESC210 but it only needs a new front/rear bumper and body mounts.
Need the following
front top deck bushings
Layshaft spacer
Shock bottom spring retainers
Shock bottom (part that mounts to a-arm)
slipper (not pads) alum. disc parts
Could also use the stock 2.4 radios and electronics for all our cars.
Also looking for spares for them so if you change out or upgrade anything please keep us in mind.
http://www.rctech.net/forum/r-c-item...1-10-road.html
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 10-17-2013, 11:17 AM   #12645
Trader Rating: 57 (100%+)
Let me double check but I think I can help with these. Bling'd the bushings and switched to avid.
shagino is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16581 Yesterday 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
