Like Tree43Likes
Old 10-26-2011, 06:30 PM   #1246
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by joho View Post
For people that are having problem with too little rear droop, any chances that you may not notice there are changes on the download manual, which indicate a different rear busing when you are fitting the gear box to the chassis? the part number in the printed manual are wrong, and it will not allow your gear box to be fully seated on to the chassis, just a thought.
Yep noticed that also...The issue with the droop is when you use the 0 kickup block. When you use the 1.5 or 3 its fine as it raises the arm. And probably wont use 0 so no big deal.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 10-26-2011, 11:25 PM   #1247
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
U guys notice the 210 parts.
They have a front weight for the 210. Gear diff are $28
http://www.losipartshouse.com/servle...210/Categories
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 10-27-2011, 04:40 AM   #1248
Matt Howard's Avatar
I thought you meant they were in stock
After building this balldiff though I'll probably just stick with it. It's pretty awsome
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-27-2011, 04:45 AM   #1249
Originally Posted by Jonny5 View Post
Did you put the washers in? Before and after the spring? If so, try adding another washer.
Are you sure its not your diff slipping?
Ok fitted the electrics last night and genetly bedded in the diff. Doing this has also made the friction on the slipper better.
There is a deffinate difference between a friends slipper in the sense if I set it like his, it slips like mad, if he sets his like mine then he gets v little slip.
At the end of the day it's working, but shame not consistent between the two cars. yes they are both built correctly.
mikeyscott is offline   Reply With Quote
Old 10-27-2011, 06:07 AM   #1250
FRONTI3R's Avatar
Originally Posted by 1armed1 View Post
The only issue I had was the ballcups but that is now sorted out using Kyosho studs and cups.
Dayton
What Kyosho ball cups do I buy to replace the DEX ball cups?
These ones - Kyosho Hard Ball End Set (10) [KYO97021H]:
http://www.amainhobbies.com/product_...all-End-Set-10
or
these ones - Kyosho 4.8mm Hard Ball End (Gunmetal) (18) [KYOUM112H]:
http://www.amainhobbies.com/product_...nd-Gunmetal-18
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 10-27-2011, 06:12 AM   #1251
Glowster21's Avatar
Trader Rating: 116 (100%+)
Guys need some help, feel like a moron with these setup sheets. I get the whole insert and adjustment deal, are you guys running the front axle trailing or inline for longer wheelbase? On the setup sheet for axle, is the number that's checked off the number of millimeters back from inline (trailing) ? Just want to double check as that just hit me...
Glowster21 is offline   Reply With Quote
Old 10-27-2011, 06:56 AM   #1252
Trader Rating: 45 (100%+)
For the ballcups, try pre-threading and then add a little grease inside the pre-threaded area prior to building the steering\camber links. Allows for easier adjustment so the ballcup doesn't pop off the pivotball. This way atleast you can wear out the stock stuff before switching over.
Apex is offline   Reply With Quote
Old 10-27-2011, 07:15 AM   #1253
TAMAK's Avatar
Trader Rating: 28 (100%+)
Just practiced up at Trackside, Milwaukee, WI. And what a difference!! I am still using 6 hole pistons. with 40 up front and 35 in the rear and stock springs. I was not bottoming out, plenty of traction. A slight on power push, but I am just so use to 4wd buggy that it could just be the nature of the class. I was still able to drive it fast, Just watching where I had to brake and roll in the corner. I would still like to limit the amount of on power push I have in sweeping corners. Suggestions? Aside from the shocks, I am using Randy's setup.
Also no popped ball cups!! Trackside is a little more forgiving in that sense.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 10-27-2011, 07:34 AM   #1254
limit your front droop a bit to get rid of that onpower push
RCTech #361
Old 10-27-2011, 08:09 AM   #1255
triplesix's Avatar
You don't adjust the wheelbase with the front axle position. The more you go from trailing to inline, to more spacers are needed in front of the c-hub.
So full trailing setup means all four spacers behind the c-hub, full inline means all spacers in front of the c-hub.
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 10-27-2011, 08:12 AM   #1256
grapejuice's Avatar
Trader Rating: 133 (100%+)
So after popping off another rear inner ball cup last night, had to try something else and after looking at it a bit, I just put on a regular turnbuckle that I had leftover from my 410 and so far no issues!! Didn't pop off, doesn't rub on anything...so far so good
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 10-27-2011, 08:15 AM   #1257
triplesix's Avatar
Which configuration do you run? RM3?
MBX6R
B5M Lowrider
DEX410
Supastox GT
Old 10-27-2011, 08:25 AM   #1258
grapejuice's Avatar
Yeah...sorry, should have included that
Old 10-27-2011, 09:11 AM   #1259
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
As said, you need to keep the spacers moved around on either side of the C-hub as you change the position of your axles. I myself am running my axles in the middle, and therefor am running 2 spacers in front, and 2 behind the C-hub.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-27-2011, 09:15 AM   #1260
FRONTI3R's Avatar
Default DEX210 INSERT SETUP GUIDE
This was just posted yesterday on the TD site... good info. for most of us that are trying to figure out this car
http://www.team-durango.com/blog/201...-insert-guide/
www.teknorc.com
St Ives RC Club B4Bandit Australian Racing 16581 Yesterday 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
