Like Tree27Likes
Old 10-10-2013, 09:49 AM   #12571
WolfAusti's Avatar
Trader Rating: 37 (100%+)
Hey all, been running the dex210 and love it for the most part. Is it a common issue for this buggy to tend to understeer? I have been trying to shake this issue for a while now and have yet to be successful. I recently switched to a shorty pack mounted full forward, but it still pushes more than I'd like. I've tried stiffer rear springs, raking ride height, the tires everyone else is using on the track, front closed cell inserts and open cell inserts. When I make changes, I honestly can't tell if there's much difference turn in at all. This is frustrating because a buddy of mine just picked up a b4.2 and it handles wayyy better and has all the steering you would want. My steering throw is usually set to full lock, so I know that isn't an issue. It just seems like the front cannot bite when entering a turn. Any thoughts would be appreciated! I can try to post my setup sheet later if that would help. Looking for suggestions of changes I can make that would increase steering. I wouldn't mind making it twitchy and oversteer and dial back from there.
Daily drivers: B5M | Xray XB4 | Axial YETI | Scion FR-S
WolfAusti is offline   Reply With Quote
Old 10-10-2013, 10:29 AM   #12572
peter george's Avatar
Trader Rating: 351 (100%+)
Do you run on clay?
I donít always talk smack but when I do itís 99% spot on
peter george is offline   Reply With Quote
Old 10-10-2013, 10:31 AM   #12573
Is your car set up as rear or mid motor? Forgot to ask, I just traded my b4.2 for the 210 and I run on clay. I am interested in the answer to your question even tho I have not even raced mine yet. I looked at this buggy cause of all the adjustability that is built into its design. Also many guys at our track are switching from rear to mid motor. I am still trying to read the entire thread to get as many tips as I can but I'm afraid it will take me years to sort thru all this info. It's been very helpful tho , I must say there are a lot of great little bits and pieces that should help. Good luck and I'll post too once I run mine.
Old 10-10-2013, 11:54 AM   #12574
TAMAK's Avatar
Trader Rating: 28 (100%+)
I am switching my 210 over from MM4 to RM3 and my last rear RM clay setup was dialed. I am going to test that out again this weekend and will report back to you.. I would highly recommend the brass front weight that sits under the servo, (http://www.exotekracing.com/dex210-d...-brass-weight/). That addition gave this car much more steering. I also ran Losi red front spring and toggled between Losi yellow and pink in the rear, Full trailing in the front. I will need to fill out a full setup sheet this weekend.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 10-10-2013, 01:16 PM   #12575
Personally, I like to adjust the caster and toe to "balance" the car to the given track conditions. This car has so much adjustment to it. adding caster/ leaning towards the rear of the car will tend to make it "twitchy". I made some "0" out of some spare rear inserts, thats what I mainly run. you can also try adjusting the front axle position. I try to only add weight when absolutly necessary. IMHO
DESC410V2 TEKIN RX-8 PRO 4 4000
DESC210 TEKIN RS 10.5 NOVAK
DEX410V3 TEKIN RS PRO 6.5 NOVAK
DEX210 TEKIN RS THUNDER POWER 13.5
jonsee is offline   Reply With Quote
Old 10-10-2013, 02:43 PM   #12576
Dino_D's Avatar
1.Going back to RM3, or MM3 will yield you less traction and get rid of some of the over steer.
2.Have you shimmed the steering turnbuckles to eliminate bump steer?
3. Using more antisquat will give you more off power steering.
4. Run less trailing.
You said it doesn't bite enough entering the turn. Is this turn low speed or high speed? Is the track high bite or loose?
if its a RTR 210, get rid of the servo saver.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 10-10-2013, 04:50 PM   #12577
Devin's Avatar
Getting a kit one of these, never had a 10th scale buggy. The guys like the rtr tires when our track is wet, what is an approximate substitute. They aren't happy in the powder. What works good with a thick loose layer, spikes?
Our track is medium packed sandy clay.
@dino what's popular at B&D down south? We plan on making a few trips next year.
Devin is offline   Reply With Quote
Old 10-10-2013, 05:38 PM   #12578
tony montana's Avatar
Trader Rating: 65 (100%+)
I have also noticed the understeer. I would also agree the b4's do turn better. But like said above the car has so many adjustments Im sure it can be setup to turn better. But I have not fiqured out what to tune to get better steering.
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 10-10-2013, 05:38 PM   #12579
I run inline steering on all of my cars (but I'm not necessarily against trailing) and I will never ever run 30 degrees of front caster. 15-25 somewhere is generally where I stay.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 10-10-2013, 06:01 PM   #12580
Brushless420's Avatar
Trader Rating: 169 (100%+)
Thumbs up
My suggestion was going to be to run inline front axels. The buggy comes setup trailing. Going to inline will yield a lot more steering. Use the 0 inserts up front as it made a huge difference to me.
Brushless420 is offline   Reply With Quote
Old 10-10-2013, 07:10 PM   #12581
This car does not lack for steering at all. If steering isn't good it's a setup problem.
Old 10-10-2013, 08:22 PM   #12582
Trader Rating: 18 (100%+)
Any difference between shortening the front camber link at the tower vs the hub?
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 10-10-2013, 08:38 PM   #12583
WolfAusti's Avatar
Thanks for the tips guys! Few more details, I'm running on a high grip damp clay conditions where super soft compound is a must. I'm also running rm3. I also tend to shy away from adding more weight to the vehicle. I feel as if the setup should be able to be tweaked so that it turns well. I'm going to try running no trailing and maybe some more aggressive caster angles and see if that helps...
Old 10-10-2013, 08:39 PM   #12584
WolfAusti's Avatar
What I'm really looking for is just some more rotation. I really like the feel of a buggy that will rotate on command. Not to compare apples to oranges, but this is one of the handling characteristics I really love about my eb48. Exceptional rotation on demand.
Old 10-10-2013, 09:27 PM   #12585
The 210 does not lack steering... What pistons and shock oil are you running? Go to Ryan L. site and copy one of his set ups it will give you a good staring point with pistions etc.
chet is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
