Like Tree24Likes
Old 10-08-2013, 08:16 PM   #12556
Pittster's Avatar
I have replaced the Ackermann to the TD alloy one as it was $9.
Installed exotek rear alloy hubs after ripping the ball stud clean out of the plastic one.
Installed a Sumo racing camber link as I snapped the stock gearbox at the ball stud mounting point + new gbox.
Have snapped a front right C-hub but replaced with the same part number and noticed it is thicker in alot of spots so perhaps a revision from the kit one by TD.
I have a spare set of towers just in case of a failure but if it happens I will get carbon front and rear.
This is from 2 race meets so hopefully the breaking will stop.
All these breakages happened on landing apart from the front C-hub that was into a barrier off a jump at full speed so it was to be expected.
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 10-09-2013, 05:14 AM   #12557
8ight-e's Avatar
Trader Rating: 57 (100%+)
  • Aluminum ackerman good investment
  • Aluminum hex's also good investment
  • Rear hub, all you really need is the long ball stud and a nut to be bulletproof, aluminum not needed
  • Several companies make aluminum front c-hubs and are a great buy
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 10-09-2013, 01:27 PM   #12558
Trader Rating: 18 (100%+)
RM4 parts came in! Too bad I blew up my ESC. Hopefully I'll be able to rig something up before this Monday and even get some time with RM4 to get it dialed in.
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is online now   Reply With Quote
Old 10-09-2013, 01:46 PM   #12559
you may like it. all I ever ran is MM4... even in my DESC. I always liked the feel.
DESC410V2 TEKIN RX-8 PRO 4 4000
DESC210 TEKIN RS 10.5 NOVAK
DEX410V3 TEKIN RS PRO 6.5 NOVAK
DEX210 TEKIN RS THUNDER POWER 13.5
jonsee is offline   Reply With Quote
Old 10-09-2013, 02:14 PM   #12560
I might try MM4 since it would he a quick swap but with how low bite the track is I have a feeling I'll have better luck with RM4.
Old 10-09-2013, 03:30 PM   #12561
Try it but I definitely don't think of it as a quick swap. Wires rerouted/switch the camber links/reset camber
shagino is offline   Reply With Quote
Old 10-09-2013, 06:08 PM   #12562
I'd be willing to run RM4 one qualifier than MM4 then the next and switch back to RM4 if I felt smoother with it. Quick enough if I'm willing to tackle it between heats haha!
Though I am buying another RTR since it's not much more than an ESC and the Type B chassis upgrade. Something like $60 for an extra roller my cost which is stupid to pass up. Why have spares when I could have a spare buggy minis ESC/Servo/Receiver.
Old 10-09-2013, 06:28 PM   #12563
Very true!
A friend just got the desc210 RTR from tower. They threw in all the B chassis parts!
Old 10-09-2013, 09:05 PM   #12564
Very true!
I just got two of them from tower a red one for myself and the blue one for a friend who otherwise would not have been able to afford the purchase. The red one came with all the extra b chassis parts the blue one did not. Should I change out the chassis and parts straight away or is it not something that will make a big difference in handling?
homershoots is offline   Reply With Quote
Old 10-09-2013, 09:37 PM   #12565
It's for durability to fix the weak points on the original DimeC and DimeC20 chassis'.
Old 10-09-2013, 10:09 PM   #12566
Oh ok. Looking forward to running this class should be fun. I haven't run it yet and will run it with the rtr radio until my m11x reciever shows up. Deffo want to change out the servo do you guys recommend a low profile or mini servo? Or is just a standard high speed servo ok? Not sure what to use coming from 1/8
Old 10-09-2013, 10:15 PM   #12567
1slash's Avatar
I have yet to run mine myself as well. But everyone I know just runs the normal sized servos. I'm sure a Low profile would work fine but I don't see any major needs to run one.
www.corvictoria.com
Team Durango DEX410/SP Reventon Pro/5.5T
Team Durango DEX210/SP Reventon Pro/5.5T
1slash is offline   Reply With Quote
Old 10-10-2013, 04:07 AM   #12568
I'd call Tower and ask them about the parts. Personally, I'd change out the chassis for convenience. Seems easier to do it now. It shouldn't change handling though.
I use a normal servo but I know a guy who used a low profile before the switched cars. Depends how much you crash.
Old 10-10-2013, 06:21 AM   #12569
with a low profile servo you can run the battery in the most forward position, a full size servo blocks the screw holes for the forward battery block.
Zak
PRS1 V3 (FM), Mugen MBX7 Eco
Team Absima UK
PR Racing UK
fivepointnine is offline   Reply With Quote
Old 10-10-2013, 06:36 AM   #12570
Ok good to know, an extra tuning option is always a good thing.
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
