Like Tree43Likes
Old 09-25-2013, 06:20 PM   #12361
Trader Rating: 47 (100%+)
Originally Posted by lil_man72 View Post
for you guys running on tight indoor tracks, what motor do you prefer?
i'm planning on starting with a 6.5 in my 4wds and maybe 7.5 or even 10.5 in the 2wd buggy.
i've been running the super stock 13.5 class but planning on running mod in the next couple of weeks.
Are you planning on running at Fastlane or Shawnee? Fastlane can handle a bit more motor due to traction and more open layouts (8.5 for 2wd, 7.5 for 4wd). Shawnee has much tighter layouts where a lot of motor is really not needed (10.5 for 2wd and 8.5 for 4wd). Jakes in Topeka would be pretty similar to Shawnee, a little more open but traction can get little sketchy at times
porter is offline   Reply With Quote
Old 09-25-2013, 06:24 PM   #12362
Trader Rating: 14 (100%+)
the Losi is hands down a better kit to build, instructions are better, parts are bagged in an organized fashion, etc...but to answer your question, the kit aluminum chassis is NOT +8. The RTR includes the +8 chassis and ball diff, but does not include any of the parts needed to make it MM (idler gear, bearings, etc) I have a RTR DESC210 and a kit DEX210 (and a kit Losi 22T)
Zak
TLR 22 4.0, Associated B64D
Team Absima UK
PR Racing UK
fivepointnine is offline   Reply With Quote
Old 09-25-2013, 07:16 PM   #12363
Trader Rating: 18 (100%+)
Wow. What a difference the front Holeshots made. Like an entirely new buggy that would actually steer on power. Loved it at practice tonight!!!
Awesomatix A800XA - Xray XB2 2018
iTz Nicholas72 is offline   Reply With Quote
Old 09-25-2013, 09:36 PM   #12364
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Can someone please tell me what the advantage of the lowered rear shock tower would have?
Thinking of giving it a try.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 09-25-2013, 10:17 PM   #12365
Trader Rating: 520 (100%+)
I am not sure other than adding to droop, should be similar to running longer shock shafts, no?
flame56mx is offline   Reply With Quote
Old 09-25-2013, 10:24 PM   #12366
vr6cj's Avatar
Trader Rating: 124 (100%+)
yeah, more droop, more steering and lower cg a bit
vr6cj is offline   Reply With Quote
Old 09-25-2013, 11:38 PM   #12367
Dino_D's Avatar
Originally Posted by daveb View Post
I'm in the market of buying a new buggy and I'm considering the 210. The problem is, I can't find the 210 in kit form, so I'm thinking of just getting RTR. My question is, is the RTR chassis already the +8? If I buy the optional aluminum (std. in the kit version) one is that +8? Any other suggestions of parts I should buy would be welcomed? I'm either going to get the 210 or the 2.0/.2 tomorrow. I was wanting the kit version to have my son finally put one together himself. Thanks
I have both cars. Most people are upgrading the pro kit chassis to the dimec +8 chassis. If you run on carpet a gear diff is preferred, on dirt use a ball diff. I had a losi 22 before, and I can tell you that the 210 has more steering than the 22, but the 22 is a stronger car. Also using the 4 gear transmission with the avid slipper will give you more grip and acceleration over the 22 on a loose track.
The difference between the 210 Pro Kit and the RTR is that the Pro Kit comes with a ball diff, extra idle gears for 4 gear transmission, rear aluminum sus. holder and the aluminum chassis. The RTR kits comes with a gear diff, and the newer +8 composite chassis. It would be easier to just buy the extra idle gear and the aluminum sus holder and ball diff (if necessary). Bonus is that the RTR comes with electronics already, but get rid of the stock servo saver on the RTR and use a direct servo horn.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 09-26-2013, 04:00 AM   #12368
ewashburnaf's Avatar
Not sure where this info came from. So, to correct the statements that are wrong here. The RTR includes a gear diff, not a ball diff and it includes everything that you need to change it to MM3/MM4/RM4 except maybe a couple bearings that go in the idler gears. It comes RM3. If you get the RTR you NEED to get some aluminum skid plates to protect the weak parts of the chassis. The Losi kit is a good vehicle, but that steering rack is atrocious.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 09-26-2013, 05:29 AM   #12369
P6
Anyone wanna shoot me a offer I switched to dimec with skids so ill let my kit chassis with side pods go just pm me
P6 is offline   Reply With Quote
Old 09-26-2013, 05:51 AM   #12370
madweazl's Avatar
It does not include everything you need to convert to 4 gear trans. You need the pins, idlers, shim kit, and bearings. The gear diff only has 2 spiders vs the 4 you'd want. That being said, I still went with the RTR as I wanted the +8 chassis and the cab forward body. I ordered the aluminum rack and ball diff, ripped the electronics out, and used mine.
As for the handling comments vs the 22, I didnt have the same results. Not sure how people seem to manage to get a 22 to not steer as it has plenty, typically being tougher to get a tight setup than most vehicles (apparently the 2.0 addresses that). Having driven it, the 210 (only +8), the B4.1 WC, and the Tamiya in the last 3 years, I have had the same results with all of them after some setup changes. The stock setup on the RTR is actually pretty good for a medium traction outdoor track on the appropriate tires. It tends to understeer but not horrible. I made a ton of changes to the front of the car and have it steering much better now along with a different shock setup (had Avid springs on hand so went with those). I've read a lot of posts about weak rear shock towers and that the chassis was weak as well but I've have no issues with either. Actually, havent had a single problem with the car yet and stuffed it on a couple big jumps twice that made me cringe.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 09-26-2013, 08:24 AM   #12371
Originally Posted by madweazl View Post
The ball diff only has 2 spiders vs the 4 you'd want.
A ball diff doesn't have spider gears. The RTR has a 2 spider gear, gear diff. The kit has a ball diff and the alternate gear diff has 4 spider gears.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 09-26-2013, 08:35 AM   #12372
Thanks for the information. I should have bought the pro kit a couple of weeks ago when my shop had it for $139. So what chassis is everyone running? I understand Lutz is running a +8 alum. chassis but I only see (1) on the website and its the kit chassis which I understand isn't +8. If I could find one for as low as my shop out here was selling it for I'd buy it. Upgrade to a ball diff and tear it down for a new chassis so my son can understand how it goes together.
daveb is offline   Reply With Quote
Old 09-26-2013, 09:00 AM   #12373
Trader Rating: 57 (100%+)
Correct. Lutz is running a prototype which isn't available.
A lot of people here either upgrade to the Dimec +8(better you get the type B) or aluminum.
A few machinists or RCTech made both +8 and +10 models. rcjunky1 and BMan's 3XNT come to mind. I have stuff from both of them. High quality stuff.
Tresrey(+10) and RDRP(+11) also make an aluminum chassis.
shagino is offline   Reply With Quote
Old 09-26-2013, 05:36 PM   #12374
ekt
ekt's Avatar
Here's a link to a list of option/aftermarket chassis http://durangofansite.com/main.php?v...market#chassis
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 09-26-2013, 07:16 PM   #12375
Hey guys, I have a dex210 rtr and I love it, I wanted to get into a 4 wheel buggy and I think I would like to go with a durango. First question, should I get the r or the reguler, second question, should I buy a desc210 and race that instead of a four wheel drive, and is a thirteen five a good place to start for the four wheel? Please reply, thx
Team durango-speed passion-anza
Sam Macmillan is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
