Like Tree43Likes
Old 09-24-2013, 10:36 AM   #12346
http://www.neobuggy.net/2013/09/24/t...-v2-spy-shots/
Philipm is offline   Reply With Quote
Old 09-24-2013, 12:10 PM   #12347
1slash's Avatar
Originally Posted by 1slash View Post
Got my Dex210 a couple days ago. The build has been great so far! It's my first time ever building a ball diff. How tight do I want to set this for indoor carpet? and/or a good basic all around setup for the ball diff would be greatly appreciated
Thanks.
Anyone? I was going to go set it as some suggested at my club (Crank it down and then back it off until it does not bind)
But I recently read this is not what you want to do with the durango ball diff or most likely any ball diff.. Bit confused on what to do.
Thanks again.
www.corvictoria.com
Team Durango DEX410/SP Reventon Pro/5.5T
Team Durango DEX210/SP Reventon Pro/5.5T
1slash is offline   Reply With Quote
Old 09-24-2013, 12:29 PM   #12348
Thanks again.
There is a ball diff build and break in video on Durango's site-very good. also I believe there is a good ball diff build break in post here on R/C tech also very helpful.
Once you build a ball diff there is a small seat or break in period you can do right on the bench, then tighten a bit more. After that there is a slipper set procedure you can do prior to doing final tuning at the track.
Hope this helps.
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 09-24-2013, 04:20 PM   #12349
tony montana's Avatar
Trader Rating: 65 (100%+)
Originally Posted by Philipm View Post
looks like a bunch of new stuff. Wonder if they will make a upgrade kit.
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 09-24-2013, 04:26 PM   #12350
Trader Rating: 41 (98%+)
Questions?? 12mm wheel hexes
What are a few ways to run 12mm hexes.
I have around 50 sc10 and b4 tires and wheels and that's the only thing stopping me from trying a DESC210
ICEMAN96 is offline   Reply With Quote
Old 09-24-2013, 04:31 PM   #12351
Default DEST210 to a DESC210
I fond a good deal on a DEST210 KIT with all the hop ups but I want to make it a DESC210 are the chassis and body mounts all I need
Old 09-24-2013, 04:58 PM   #12352
Trader Rating: 520 (100%+)
Thanks again.
Really you need to work your way into the tension part, if you use the build it, torque it down and back it off method, you will be doing it again fairly soon. I am not saying the way I have been doing it is gospel, but it works really well, and I don't have to rebuild very often.
I build the diff like most others, I do sand my washers to put a light "honing' cross hatch on them, but the important key IMO is to gradually break in the washers by putting light tension on the diff screw. Chuck the diff up in a cordless drill, holding the exposed out drive and spin the diff for 20sec in fwd/20 sec in rev. Re-chuck the other side outdrive and repeat the process. Add approx 1/4 turn of tension and repeat the process keeping an eye on the diff nut to observe your progress. Dont try to rush it and get the diff and new grease burning hot, take your time, and you'll will get to the point where you have a hard time adding tension. Now, you should be at the "feel it" part where they say back it off so it doesn't bind, the balls and washers are already mated or broke in, should be smooth, with just a hint resistance..
flame56mx is offline   Reply With Quote
Old 09-24-2013, 05:34 PM   #12353
Trader Rating: 18 (100%+)
I'm liking the look of the new rear hubs. Like turnbuckles straight rather than needing a 90* twist in them.
Getting my last day of practice tomorrow before the local Monday night indoor series starts. Hopefully the Tazers in the rear and Holeshots up front give me the traction/steering I'm looking for.
Awesomatix A800XA - Xray XB2 2018
iTz Nicholas72 is offline   Reply With Quote
Old 09-24-2013, 05:41 PM   #12354
1slash's Avatar
Thanks for the write up! I will definitely give that a try
www.corvictoria.com
Old 09-24-2013, 05:46 PM   #12355
Trader Rating: 57 (100%+)
See you in the DESC210 thread.
Team Durango DEST210R thread
shagino is offline   Reply With Quote
Old 09-24-2013, 11:03 PM   #12356
COOL THANKS
Old 09-24-2013, 11:58 PM   #12357
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
Excellent advice! You don't need to spin the diff fast. This methood will give you a long lasting trouble free diff.
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 09-25-2013, 05:43 AM   #12358
lil_man72's Avatar
Trader Rating: 29 (100%+)
for you guys running on tight indoor tracks, what motor do you prefer?
i'm planning on starting with a 6.5 in my 4wds and maybe 7.5 or even 10.5 in the 2wd buggy.
i've been running the super stock 13.5 class but planning on running mod in the next couple of weeks.
team durango
lil_man72 is offline   Reply With Quote
Old 09-25-2013, 04:23 PM   #12359
A 7.5 is a lot of motor for 2wd buggy. Even turned way down the 7.5 I tried was very hard to wheel. The 10.5 is a decent motor, depending on the obstacles and if your speedo has the ability to run a little boost that would be the route I would pick, but that's just me and my $.02
Old 09-25-2013, 05:22 PM   #12360
I'm in the market of buying a new buggy and I'm considering the 210. The problem is, I can't find the 210 in kit form, so I'm thinking of just getting RTR. My question is, is the RTR chassis already the +8? If I buy the optional aluminum (std. in the kit version) one is that +8? Any other suggestions of parts I should buy would be welcomed? I'm either going to get the 210 or the 2.0/.2 tomorrow. I was wanting the kit version to have my son finally put one together himself. Thanks
daveb is online now   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16576 Yesterday 07:25 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
