Like Tree33Likes
Old 09-23-2013, 05:39 AM   #12331
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
I ran fairly competitively in stock last year. Running a Hobbywing 120A V2.1 with 508 stock software, Speed Passion V3 MMM 17.5T with 15degree can timing and Venom 3800mah shorty. Gearing was usually 69/34. Car was more or less stock other than ceramic bearings throughout and a CF steering rack. There's no reason this car should be slow in stock if it's in the right hands.
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 09-23-2013, 06:37 AM   #12332
EvanAZ's Avatar
Trader Rating: 99 (100%+)
I picked up a used parts roller and it is missing a bit more than what was said it needed to finish. This car is going to be used in our kids program and I would like to try an finish it before our re-opening this weekend of our track.
https://www.facebook.com/pages/Over-...44652455636350
I am looking for stock ball studs, I have plenty of tie rods and ends but need balls
also need a layshaft spacer but I will order one today if there is none out there.
I figure with a lot changed over to other balls there might be some out there someone would be willing to donate.
I am starting to find many 210s and will be adding them to the cars we use so if you have extras or parts your not using please let us know.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 09-23-2013, 08:53 AM   #12333
You can have mine. I switched over to ball studs and rod ends from the 22. I sheared one 210 ball stud vertically right through the ball. They are fairly weak compared to the goliath 22 pieces. PM me your address and I'll send them to you minus one of course.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 09-23-2013, 09:10 AM   #12334
Originally Posted by knowitall156 View Post
I'd be very interested in getting the guys that are having success with the 210 in the blinky class to chime in. The buggy mod class has virtually disappeared in the last couple months and everyone locally is running blinky. I pulled my 8.5, dropped in a Fantom/Trinty V2 17.5, 69/33 gearing, 40-50 degrees of can timing, 100c shorty pack and drove it in practice and didn't race it because I didn't feel it was going to be competitive. I must have something not dialed right. The platform works great with my mod motor so looking for some feedback. Thanks.
Think I may have found the culprit: Took the gearbox out and the slipper rod that goes through the Avid top shaft for the Triad slipper had a nasty bind. Tried another slipper rod and it was clearly the top shaft. So I swapped that out, rebuilt the entire diff as it did some damage to the thrust bearings and put it back together. By that time it was 11:00 p.m. and I have to work like everyone else so I'll finish it up tonight and test it out. Pretty sure that has to be it.
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 09-23-2013, 05:12 PM   #12335
Trader Rating: 520 (100%+)
Well, I have only had 1 transcase ballstud issue in the nearly 2 years of running my 210, and after having the Tresrey piece, and making my own a few times, I wanted less parts to add to the rear end. So, lets have a little vote on this idea. Its a piece of stainless steel that I cut and massaged down, held in by the ballstud, and a cut down droop screw farther back where some remounted their ballstud on a broken case..
Durango DEX210 Thread-pq5gtgg.jpgDurango DEX210 Thread-buxepoy.jpgDurango DEX210 Thread-ekrmmpg.jpg
flame56mx is offline   Reply With Quote
Old 09-23-2013, 05:31 PM   #12336
Trader Rating: 57 (100%+)
I have 4 sets of Avid Triads. On one of them, I had this problem, super tight. I bought a needle file set which helped. The most effective thing was an 3mm arm reamer though.
Great idea. I'd be interested in that. I run the Tresrey mounts on my RM cars but I don't think it'd work on SC MM because of the bumper.
shagino is offline   Reply With Quote
Old 09-23-2013, 05:54 PM   #12337
Originally Posted by fivepointnine View Post
wish I knew..the top stock guys are running almost 2 seconds a lap faster than the most perfect lap I can put together. Im running 72/32, I was running 69/32 before but struggled in the tight sections. I am swapping out motors this week see if that helps, I am running a Trinity D3 now, I will be running a Shurrspeed this weekend.
I run 72(Avid)/35. I've used a D3.5 but now I'm using a TrakPower. Are you sure it's the motor that's the issue? 2 seconds is a lot. How big is your track? What's a fast lap on your track? Sounds like you're not hitting the right lines to me. I have that problem too.
Originally Posted by ekt View Post
While I am only an average skilled racer, I've found to compete in stock racing you need to keep clean, precise lines to compete as you don't have the excess power of mod to make up for wide lines and crashes.
What your local club is like can play a big part in what is required to compete too. Stock racing can be a cheap form of racing or the most expensive, people buying lightweight parts and the current 'best' electronics to squeeze out any advantage they can get.
I'm just about to make a year back after a very long layoff. I'm fighting to be average but I find this to be true. Stock doesn't mean a not as skilled racer.
Old 09-24-2013, 03:41 AM   #12338
Trader Rating: 27 (100%+)
I have an 8 year old son who wants to get into racing. He will just be starting in the novice class. Is the RTR version suitable to start and we can upgrade as we go?
Trying to take the RC racing world by storm (of course I have a long, long way to go)!
AE RC10B5 | Airtronics | Sanwa | Reedy | SMC | Savox | J-Concepts | Schelle
langsky is offline   Reply With Quote
Old 09-24-2013, 04:04 AM   #12339
Which track would you be going to? The RTR is fine to start with but having parts support and getting help from others running the same car is pretty useful.
Old 09-24-2013, 04:14 AM   #12340
I just picked up an RTR last friday and had it on the track sunday to start doing 2wd again... I replaced all the electronics with mine, but I can tell you from another user that the steering servo is junk ... I would look at replacing that soon. As for durability, I've beat mine up pretty good and it has held. Overall I am pleased with it so far. I am running the Savox 1258tg, Viper VTX10 with 10.5, and Ko Propo radio and it is a joy to drive.
I'd say the common items are probably the items to get, with the exception of the plastic hinge pin blocks should you choose to stay with them. So:
A-Arms
Rear Hinge Pin Blocks
Spur Gears
Also only other change I made was put 37.5F/35R shock oil for the time being.
Tekno NB48 Samurai Proline Tires
Tekno NT48 XZB Speed Proline Tires
Tekno EB48.3 Viper Proline Tires
Tekno / Dialed RC Hobbies / TKO Competition Development /
Stirex is offline   Reply With Quote
Old 09-24-2013, 04:53 AM   #12341
8ight-e's Avatar
A-Arms
Spur Gears
I've never broke an a-arm or a tranny stud in two years, that said the plastic c-hubs are the easiest part to break (keep spares or get aluminum) and I would always replace all the plastic hinge pin holders with aluminum, it will pop with the plastic,, just a matter of time. Another great piece is the exotek front bulkhead w/ the droop pads and a pair of locking hex's. Exotek also has a weight for the front for a good price. One stop shop for the Durango in many cases.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 09-24-2013, 05:17 AM   #12342
Trader Rating: 14 (100%+)
I pulled that D3 out last night, I think I overheated it, lots of burned looking areas around the solder on the bottom of the stator. Im not expecting a good motor to drop me a second a lap or anything, but any little bit will help!
Zak
PRS1 V3 (FM), Associated B64D
Team Absima UK
PR Racing UK
fivepointnine is offline   Reply With Quote
Old 09-24-2013, 06:57 AM   #12343
TAMAK's Avatar
Trader Rating: 28 (100%+)
http://petitrc.smugmug.com/Hobbies/2...qzmX4&lb=1&s=A
Hupos car... I see a lot of new things coming...
http://www.oople.com/forums/showthread.php?t=136827
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 09-24-2013, 07:05 AM   #12344
The two most noticeable things that I see are the front arms are now straight with the front shock tower being slightly taller as a result, and the rear shocks mounted behind the arms. I wonder why the straight arms? They result in a slightly higher center of gravity since the shocks are a bit higher up. If anyone wants to try this now all they have to do is run B4 front arms. They are a direct swap.
Old 09-24-2013, 07:19 AM   #12345
rcjunky1's Avatar
no dirt on the tires, why don't they just build a concret track and coat it in spray adhesive... no track maintanence needed...
The new tranny is interesting though, the front arms/shock tower won't be too expensive, the tranny is concerning on upgrading
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
