Like Tree43Likes
Old 09-17-2013, 05:07 AM   #12286
Trader Rating: 57 (100%+)
Originally Posted by slammedwagon View Post
hey guys what setup stations do you use setting these up? iv been looking at the hudy 1/10th off road system or the intergy universal system then I can use it on my DESC210 and 410 as well
I use the Hudy on my DEX210/DESC210/DEST210. For the DEX210, I switch had to get the imperial axles ans switch them out when using the setup station. The normal ones don't fit. You also should use the aluminum spacers that should have came with the Hudy. I use them on front and back.
shagino is offline   Reply With Quote
Old 09-17-2013, 05:44 AM   #12287
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
Originally Posted by iTz Nicholas72 View Post
Sounds like I'll like them. Calibers are great but there's always room for improvement. Plus the Tazers are M4 vs M3 with Calibers which should help even more.
I'm running the stock RTR setup minus Losi 30wt. oil and 3K in the diff. I'm looking for more steering on power mid-late turn. Think I should add some weight under the servo (running Savox 1251 LP) or try some other setup change?
Added a picture so you can get an idea of how rough/bumpy and dusty the surface it. Could almost go as far as saying it's almost sandy but very very fine sand...
I don't have the rtr setup in front of me, but you could try running 15 to 30 grams of weight in the nose. You could also try moving the top of the shock in one hole.
No setup station. I just use a ride height gauge, camber gauge and a toe gauge.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 09-17-2013, 09:39 AM   #12288
Trader Rating: 18 (100%+)
I'm assuming you mean move the front shock in one upper hole correct?
With all this talk about the DEX210 liking it's ball diff tighter should I go ahead an try 5K from 3K. Didn't look as if it was diffing out and from how I understand it thicker oil would give me more of an on power push, right?
But as usual I'm getting ahead of myself with setup considering I haven't driven 2WD in over 6 months and have one practice day with my DEX210 on a new ever changing track. Lol
Awesomatix A800XA - Xray XB2 2018
iTz Nicholas72 is offline   Reply With Quote
Old 09-17-2013, 10:27 AM   #12289
Tunatsol's Avatar
Im running 100k in my gear diff. Im also running -10 caster inserts in the front and have all the corner speed i could need or use.
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 09-17-2013, 12:17 PM   #12290
Originally Posted by mechanic77 View Post
I use a drill with an old driveshaft to break my diff in out of the car and just keep tightening the diff a little at time, run it, tighten some more, etc. until I completely bottom the screw and back it off an 1/8 of a turn.....done
Thanks, I'll give that a try.
jha07 is offline   Reply With Quote
Old 09-17-2013, 12:40 PM   #12291
Yes. You could also take a small amount of droop out off the front. There are many things you can do to add a little more on power steering, but they all have trade offs.
I do the same, but I use a dremel. Works like a charm.
Old 09-17-2013, 01:09 PM   #12292
sc10pc's Avatar
today i received my revolution designs r2 steering plate for my buggy, and its so different that i have no clue how to install it in the right direction. does anyone run this part? could someone tell me which way to install it on the buggy?
thanks
Ofna Nexx 10SC: Novak Ballistic 550 4.5t, Novak GTB2, Orion Vortex 1007
Durango DEX210: Tacon 8.5t sensored, Duratrax DE10, Savox SC1257TG
Team Associated B44.1: Viper VST6.5T, Duratrax DE10, Orion Vortex 1007
RETIRED: Team Associated B44
sc10pc is offline   Reply With Quote
Old 09-18-2013, 12:32 PM   #12293
Trader Rating: 74 (100%+)
Guys I have my dex210 up for grabs. Its a very special unique car. Its as close to jorn's car as possible. Call me 2035508518 if interested.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 09-18-2013, 05:39 PM   #12294
ekt
ekt's Avatar
thanks
RDRP recommends installing it with the ballstud facing forward https://www.facebook.com/photo.php?f...levant_count=1
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 09-20-2013, 05:00 PM   #12295
tony montana's Avatar
Trader Rating: 65 (100%+)
question, How in the world can you tell which side is the rounded side of the snap ring on the diff. I have a magnifing glass and still can not tell
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 09-20-2013, 05:26 PM   #12296
Tony,
If you cannot see, I would then try to feel the edges. I know it is a small part.
Also look at the color to see if one side is brighter than the other.
NitroBuddy
::Arsenal of Fun::
{Losi 8ight 2.0
{Team Durango DEX210, DESC210r, DEST210
NitroBuddy is offline   Reply With Quote
Old 09-20-2013, 09:09 PM   #12297
How much?
Team durango-speed passion-anza
Sam Macmillan is offline   Reply With Quote
Old 09-20-2013, 09:19 PM   #12298
Trader Rating: 520 (100%+)
Originally Posted by NitroBuddy View Post
Tony,
NitroBuddy
Originally Posted by Sam Macmillan View Post
How much?
I think you'll need to call him..
flame56mx is offline   Reply With Quote
Old 09-20-2013, 09:29 PM   #12299
Have the 210 rtr and only put electronics and 37 1/2 weight schlock oil in it. Set ups??
Old 09-20-2013, 09:36 PM   #12300
The Czechexican's Avatar
:DEX210:
:DEX410V3:
MARCCA Carpet Racer.
"I Huff SXT 3.0"
The Czechexican is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
