Like Tree24Likes
Old 09-15-2013, 07:56 PM   #12256
Trader Rating: 30 (100%+)
Have any one here tried the avid rc triad slipper clutch.
Otto.951 is offline   Reply With Quote
Old 09-15-2013, 08:12 PM   #12257
Pittster's Avatar
Originally Posted by shagino View Post
Why do you call it a MIP build? Makes me think of when MIP made their stealth transmission.
I've never heard of anyone ripping the front camber studs out. You may want to look into CF if you're a rough driver though.
Sorry ball diff my bad, I try not to be a rough driver but I only started doing it earlier this year, but yes if I stopped crashing I wouldn't have these issues
Just trying to future proof I read so many people breaking rear towers and I haven't had an issue yet but have a spare set ready to go.
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 09-15-2013, 08:17 PM   #12258
The Czechexican's Avatar
+1 Im wondering the same thing. Still having problems with the stock slipper.
The Czechexican is offline   Reply With Quote
Old 09-15-2013, 08:29 PM   #12259
Trader Rating: 15 (100%+)
Tried it last night and it was awesome. No problems. Very smooth power delivery and I could spend more time on the throttle as compared to stock. I did get the Durango upgrade pack as well as the slipper package.
www.5280Raceway.com | Racing. Elevated.
samsking is offline   Reply With Quote
Old 09-15-2013, 09:27 PM   #12260
rcjunky1's Avatar
I'm cheap and just went with the VST set up, cheaper, I can get it at my LHS (that I work at) and it uses regular spurs, and it looks sexier
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 09-16-2013, 04:23 AM   #12261
Trader Rating: 57 (100%+)
I just returned to the hobby last year. Just was curious why you used that term for my knowledge. So much to re-learn.
shagino is offline   Reply With Quote
Old 09-16-2013, 09:24 AM   #12262
Originally Posted by 2SlowTC View Post
I know it sounds crazy but....when a dingo diff is tight its still to loose. I have run many 2wd buggies over the years...losi, ae, kyosho, yokomo, etc. and the dingo diff is just the way it is....different. But when setup properly it kicks ass!
Any tips on how much to tighten the diff? I haven't run my car yet and set the diff up like I do on past cars. I do the tire spin test and set it up to spin 1-1.5 turns. From the sound of it, this won't be tight enough.
jha07 is offline   Reply With Quote
Old 09-16-2013, 09:44 AM   #12263
Do you have your esc on the left or right with the MM setup?
It would be a lot easier to route the wires if the esc were on the right side.
jaank is offline   Reply With Quote
Old 09-16-2013, 09:50 AM   #12264
Enigma R/C's Avatar
I got to check out the Durango DEX210 up close while making a product for my company for them, and wow, looks like a lot of engineering went in for a company that is not already well known in the 2wd racing category.
Impressed to say the least. Keep up the good work Durango.
Looking to buy/sell USED rc gear? www.rcshed.com
Enigma R/C is offline   Reply With Quote
Old 09-16-2013, 10:29 AM   #12265
rcjunky1's Avatar
The rumor was they spent a million dollars on the devlopment, no way of confirming that though. They did spend 10 years developing the dex410 when it first came out.
Team Durango Canada
Old 09-16-2013, 10:32 AM   #12266
Trader Rating: 41 (100%+)
There is a good build video online...someone might have the link up. Build it as described in the manual and crank it down. After you break it in crank it again. The last thing that you want is that diff to bark.
2SlowTC is offline   Reply With Quote
Old 09-16-2013, 11:11 AM   #12267
P6
I ruined my first fresh diff by letting it bark got new rings and carbide balls but never tried it again I'm using the ae gear diff still and I'm not looking to change maybe go go to the td gear diff but that's it for me
P6 is offline   Reply With Quote
Old 09-16-2013, 11:20 AM   #12268
Brushless420's Avatar
Trader Rating: 169 (100%+)
Default diff
Originally Posted by 8ight-e View Post
Buy the gear diff guys.. some 5k fluid and you'll never have an issue again. Better than the ball diff IMO inside or out.
Was running the ball diff with b-fast pro kit. IMHO the diff would never get tight enough. Finally decided to throw a gear diff in it. Ran it this weekend and it was better than the ball diff all day long.
Brushless420 is offline   Reply With Quote
Old 09-16-2013, 11:29 AM   #12269
Yes, I saw the video before building mine, so I'm confident the build is good. I just don't want it to bark, and from the sound of it, it's almost not possible to go too tight.
Old 09-16-2013, 11:44 AM   #12270
Yea man...just crank it down. I wouldnt swap this diff for any other. It works flawlessly and im running a 7.5 t motor with lots of speedo timing and boost.
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
