Like Tree23Likes
Old 09-11-2013, 05:43 PM   #12211
I don't personally like trailing steering so for me it's inline only. The manual gives you a good starting location for the camber links. You can start with 1.5 anti squat. I personally like 3 in rear motor or none in mid motor. You don't need a setup sheet. Just try something. If it doesn't handle right, change it. A kit car isn't an rtr.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 09-11-2013, 06:41 PM   #12212
Trader Rating: 18 (100%+)
Looks like inline steering will be the next change I make. Everything feels good but it's just too lazy on the steering both on and off power. Want to get it feeling too twitchy and them dial out steering.
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 09-11-2013, 10:02 PM   #12213
8ight-e's Avatar
Trader Rating: 57 (100%+)
Anyone have a dialed setup for the mid-motor config? I have a great setup on my buggy for rear, but even with that large rear weight my tail just wont stay planted on our track with the mid motor. I may just shelf the setup for carpet running during the winter but this is a clay/dirt mix so it's a med to high bite but certainly not high. I love the feel of this thing on the jumps but cannot seem to find a happy place for it. thoughts or just give up :P lol
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 09-12-2013, 04:26 AM   #12214
McD44's Avatar
Trader Rating: 16 (100%+)
I found that removing the rear weight actually helped. I'm running the shocks to the rear, 1.5 A/S, and 4.5 rear toe in on a sand track (talking beach sand). I'll post my setup but I won't have access to it until tomorrow. The biggest thing for me was to find out where I could push it and where I had to be cautious with the throttle. I am more consistent with it in MM for sure and my lap times are slightly better. As I get more in tune with the handling characteristics I believe lap time will continue to improve.
I come into the corner faster and just try to maintain speed until I'm pointing where I want to go AND heading in a relatively straight line then I roll on the throttle. On sharp turns >90 I have to constantly remind myself not to get on it too early. That's really my only problem spot right now. This thing in MM just tears through sweepers.
-Sean McDermott
Team Durango DEX210 | Team Durango DEX410v3 | Team Durango DESC410v2 | Team Durango DEST210R | "Whew, tires are expensive!"
McD44 is offline   Reply With Quote
Old 09-12-2013, 01:18 PM   #12215
Are the hinge pins on the DEX210 pretty strong or do they bend like the DEX410?
jha07 is offline   Reply With Quote
Old 09-12-2013, 01:29 PM   #12216
most likely no, depends on how you use it. power, track, how much you crash, etc.
ultimate solution is mcmaster's pins, I got that in my 4wd sct for almost a year now, and still perfectly fine.
nicholasxuu is offline   Reply With Quote
Old 09-12-2013, 01:37 PM   #12217
I already have mcmasters on my DESC410 and DEX410, and was going to cut some for the 210 as well. But when I started the build, I saw the pins are full width unlike the 410, which made me wonder if durango fixed the hinge pin problem.
I guess I'll make the effort and cut some for the 210 just to be safe.
Old 09-12-2013, 01:41 PM   #12218
the ones on my desc410v2 was full width as well. bend and break in two days. Bought and cut some kyosho pins, bend in a few races.
I believe the material is more important (than shape).
*I haven't achieve to bend any pin on 2wd buggy yet. they are really light.
Old 09-12-2013, 05:01 PM   #12219
Ripped out my rear right arm first day out and the hinge pin was straight as an arrow. Think it safe to say the stockers are halfway decent lol
Old 09-12-2013, 05:47 PM   #12220
Originally Posted by Cameron Kellogg View Post
Any updates from Bman's on this project. I just now found this and want one.
just a thought, why not keep the front drive train, and make a front brake out of it?
a 11g servo, and perhaps some 3d printed parts.
simpler project than this one, Front brakes!
and especially on high grip tracks, the front wheel brake improves brake performance massively.
+ YouTube Video
Old 09-12-2013, 09:08 PM   #12221
Woulvesbaine's Avatar
I only run stock and mm and I've not had any issue with the pins on the 210. I did change them out for Lunsford on my 410. I'm not aware of any issues owith the pins on the 210.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 09-13-2013, 12:11 AM   #12222
murky123's Avatar
I bend the lunsford titanium ones just as easy as the stock dex210 ones
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 09-13-2013, 01:02 AM   #12223
lil_man72's Avatar
Trader Rating: 29 (100%+)
i've only broke 2 things on my 2 dex210s. the front shock tower is cracked on one and i tore a right front c-hub into 3 peices on the same car.
i have all of the 1/10th scale durango cars, the 210, the st, the sc, the desc410 and the dex410 and i haven't bent a hinge pin yet. i have pulled the rear out of the st and the sc and broke 2 front arms on the desc410.
i plan on getting the aluminum c-hubs for the dex210.
any word yet on a new 2wd buggy?
team durango
lil_man72 is offline   Reply With Quote
Old 09-13-2013, 01:17 AM   #12224
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
I've had a couple snap on me... none that bent though.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 09-13-2013, 05:54 AM   #12225
Tunatsol's Avatar
I had 1 h pin snap at really high speed crash I'm talking 50 to 60 mph on a straight in to sweeper
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Kremzeek
