Like Tree18Likes
Old 09-08-2013, 06:55 AM   #12166
Trader Rating: 30 (100%+)
What pinion do I need for 13.5 motor 87t spur a 27 pinion works?
Otto.951 is offline   Reply With Quote
Old 09-08-2013, 06:55 AM   #12167
Trader Rating: 41 (100%+)
Thumbs up
Originally Posted by Captcha View Post
Ok. Looks good cant waittoget one
Youll enjoy the 210. I came from a 22 as well i know you northern floridians run indoors but these cars are dialed out door as well. Plus easier to work on and tune than the 22. IMO.
2SlowTC is offline   Reply With Quote
Old 09-08-2013, 07:02 AM   #12168
tony montana's Avatar
Trader Rating: 65 (100%+)
thanks for the advise to look at the online manual. Tranny now fits perfect. One of issue Im having seems to be odd. I assume the diff goes in the tranny with the diff screw on the right side. I thought I had the diff somewhat tight atleast till I start breaking it in. But the left driveshaft seems to be hiting the diff nut and will not allow the rear arm to have any suspension travel. at first I thought the droop screw was just tighend to much, put I loosed it all the way and its the exact same. Any ideas? More than likely I have something assembled wrong but I have looked over it and cant seem to find any problems.
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 09-08-2013, 07:11 AM   #12169
Send a message via Yahoo to rcwarlock22
Hi. I've got a couple questions. I have a 210 and a DESC410 V2 and I'm thinking of buying a dex410 v3. Are there new cars coming that should hinder my 4w purchase? Also, with the 210, does anyone still run the original chassis as opposed to the +8 and whats the difference between the 2 handling wise? Thnx.
MIKE SMITH
**PRIVATEER **
B6D, B44.3, SC5M
rcwarlock22 is offline   Reply With Quote
Old 09-08-2013, 07:45 AM   #12170
You need to really crank down the diff it seams tight but theres still some more tightening to be done.
I run the stock chassis as small as possible. By this i mean shortest wheel base. I race at a big 1/8 th scale outdoor track and the car is dialed. Its a very presictable and stable car when its setup with a short wheelbase.
Old 09-08-2013, 07:47 AM   #12171
Oh i should also mention that i have the rear arms swapped and shocks mounted behind the tower. Also a bulldog cab foward body makes a huge difference with the shortwheelbase car. IMO
Old 09-08-2013, 07:51 AM   #12172
Trader Rating: 37 (100%+)
I agree. I run stock chassis with short wheelbase. I am not fan of the extended chassis.
rnpnick is offline   Reply With Quote
Old 09-08-2013, 08:22 AM   #12173
lil_man72's Avatar
Trader Rating: 29 (100%+)
i have 2 buggies with 13.5s. one is geared with a 69/30 and the other with a 78or81/33. they both seem about the same speed. you'll need to go to a smaller spur first since you can't put a big enough pinion on with the 87.
team durango
lil_man72 is offline   Reply With Quote
Old 09-08-2013, 08:33 AM   #12174
lil_man72's Avatar
if you can still find the dex410 i would pick one up. there's not a huge difference from the original to the v3 so i can't imagine the next version being completely different.
as far as the longer chassi, i have both the original and a rtr car. the longer chassi makes the car easier/more stable/forgiving/ but i think the shorter car can turn faster laps on smaller/tighter indoor tracks.
i like the shorter car right now and my son thinks the rtr is better.
we are running both cars in the 13.5 super stock class right now.
the shorter car turns faster laps but the rtr +8mm turns more consistant laps.
when i ran the rtr i just grabbed it and could run 5 minutes without a crash, but i've yet to finish a 5 minute race without some sort of problem with the short car. meaning even if i don't get marshalled, i find myself either spinning out or getting so loose i have to bail out of jumps or lines and regroup meaning slower laps.
team durango
Old 09-08-2013, 09:03 AM   #12175
your diff is probably not tight enough, and on top of that I would double check to ensure your CV's were assembled correctly.
fivepointnine is offline   Reply With Quote
Old 09-08-2013, 09:05 AM   #12176
anyone have any suggestions for eliminating understeer? The car turns in awesome but on power it pushes wide on sweepers.
Old 09-08-2013, 11:06 AM   #12177
lil_man72's Avatar
hello, i'm looking for the aluminum shock towers for the dex210 from rdrp. if anybody has them for sale lmk. i've been waiting for them to come off of backorder from amain for a while now. i'm also planning on getting several pairs of their aluminum c-hubs.
so anyway lmk if you have or know where i can get these used or new.
team durango
Old 09-08-2013, 12:47 PM   #12178
I had the same issue i lightened up the rear spring and shock oil. I also experimented with front tires bar codes or scrubs work well on a hard packed grooved outdoor track
Old 09-08-2013, 02:18 PM   #12179
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
Try taking out some front droop. Could also go longer wheelbase or lower front ride height compared to rear. You're trying to reduce rear weight transfer on power.
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 09-08-2013, 02:42 PM   #12180
Good point, I have my front set up pretty tall (ride height) and a little stiff (4 hole piston, 27.5wt oil and Losi red springs) running full droop and barcodes for front tires.
St Ives RC Club B4Bandit Australian Racing 16562 Today 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
