Like Tree43Likes
Old 09-07-2013, 02:50 PM   #12151
The Czechexican's Avatar
Originally Posted by touringdriver View Post
Is Durango coming out with new 2wd and 4wd buggies? tower is sold out but their prices are dirt cheap.
yes
The Czechexican is offline   Reply With Quote
Old 09-07-2013, 04:29 PM   #12152
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Originally Posted by simonseize View Post
I will need different tires, correct? Its a dirt track, maybe clay? Looked sticky. They were using a gas powered tamper as they had just rebuilt. I also don't know if I'll want to go MM immediately, or if the gear box is fully adjustable MM3/4 RM3/4 like the pro.
The RTR tires are too hard and don't provide optimal grip. The RTR does come with all the parts you'd need for any configuration of motor... MM3/4 or RM3/4. I think you only need the bearings that go in the smaller idle gears when running MM4 or RM4.
Anybody looking to buy the RTR kit needs to buy the front and rear skid plates to protect the older style Dimec chassis weak points. Another must change item is the steering plate.
On top of that, if you are prone to having pipes jump out at you... you'd want aluminum rear hubs, an aluminum RF hanger, and possibly a CF rear shock tower. Other than that, nothing else is really necessary.
Some "good to have items" are the CF front tower, battery thumb screws, the SUMO rear inner camber link brace (if you run spacers under your rear camber links... otherwise, the screw is long enough to handle some pretty hard hits), locking rear hexes.
Some "nice to have items" are Lunsford ball cups (or equivalent), TD or Exotek chassis weight, anything else blingy and orange.
As far as the ball cups go, you don't NEED anything but the kit ones. Build them right (tap them and/or make sure they are smooth and you can twist them with only a little force with your hands), don't ever pop them off when working on the vehicle, if one does pop off - replace it (should do that with any vehicle).
Fishhook
ewashburnaf is offline   Reply With Quote
Old 09-07-2013, 06:19 PM   #12153
broke my first part today...rear shock tower pretty amazing though as it has taken some incredibly hard hits.
fivepointnine is offline   Reply With Quote
Old 09-07-2013, 09:14 PM   #12154
tony montana's Avatar
Trader Rating: 65 (100%+)
Having a small issue with the build. On page 34 using rear motor 3 gear it says to use part number 320128. When I put them on the tranny doesn't sit correctly. Am I suppose to use them?
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 09-07-2013, 10:19 PM   #12155
Trader Rating: 9 (91%+)
The manual is wrong, check the online version of the manual there's also two supports that are not listed that go on the transmission to chassis brace and the shock pistons are wrong in the print manual too.
Darksidedesigns.net
msedsp is offline   Reply With Quote
Old 09-07-2013, 11:02 PM   #12156
carrotcake's Avatar
I bought my kit 2 months ago, just checked pg 34 same problem....can't believe they didn't update the manual for later production kits....or maybe Amainhobbies sold me a very old kit back in 2011.
Thanks for pointing this out. I thought Durango was really attention to details..especially with this kit.
Now I have to setup a laptop on my workbench and flip "pages" with my greasy finger pressing on the arrow keys.
carrotcake is offline   Reply With Quote
Old 09-07-2013, 11:05 PM   #12157
vr6cj's Avatar
Trader Rating: 124 (100%+)
I agree. THe manual although it looks really nice is one of the worst Ive seen in the market. Besides the flaws and lack of updates the pics are way to dark. I would also suggest looking into watching the vid on building the ball diff. Manual leaves out some key steps that u need to know.
vr6cj is offline   Reply With Quote
Old 09-07-2013, 11:22 PM   #12158
carrotcake's Avatar
Thanks for the tip! Appreciate it! I will try to find something to build the ball diff for this kit.
I'm new to RC getting into 2wd and 4wd buggies. But hey, people gotta start somewhere @ a point of time.
And yes - the manual looks really nice (cover) - kind of waste now...but I agree the pictures and coloring could be better. I guess with the laptop I can zoom more...... and also maybe use it to watch the ball diff videos / sites
Thanks again.
Robert
Old 09-08-2013, 12:11 AM   #12159
Captcha's Avatar
Looking at trading my 22 for a 210. What seems to be a goto setup for a good starting point? I run indoor high bite and outdoor medium all clay surfaces.
I have been greatly intrigued by the durango line and would like to give them a go
Brandon Ryan
Public Relations, and Hype-Man
301 Raceway & Hobby
3404 NE 37 PL.
Wildwood, FL 34785
Captcha is offline   Reply With Quote
Old 09-08-2013, 05:27 AM   #12160
Do you cut off the front edge of the wing where there is a line or not?
jaank is offline   Reply With Quote
Old 09-08-2013, 05:51 AM   #12161
McD44's Avatar
Trader Rating: 16 (100%+)
Here's a link to a great starting point for setup http://rcmcd.files.wordpress.com/201...ex210-2013.pdf
Up to you. I don't.
-Sean McDermott
Team Durango DEX210 | Team Durango DEX410v3 | Team Durango DESC410v2 | Team Durango DEST210R | "Whew, tires are expensive!"
McD44 is offline   Reply With Quote
Old 09-08-2013, 06:13 AM   #12162
Captcha's Avatar
Mcd44 it is a broken link.
Brandon Ryan
301 Raceway & Hobby
3404 NE 37 PL.
Wildwood, FL 34785
Old 09-08-2013, 06:40 AM   #12163
McD44's Avatar
Sorry, try it again. It should work now.
-Sean McDermott
Old 09-08-2013, 07:30 AM   #12164
Captcha's Avatar
Ok. Looks good cant waittoget one
Brandon Ryan
301 Raceway & Hobby
3404 NE 37 PL.
Wildwood, FL 34785
Old 09-08-2013, 07:55 AM   #12165
Thanks for the helpful reply!
I did order a RTR in blue. Upon advice here, I picked up some spares, but not all that you've mentioned. Would it be advisable to upgrade to the harder composite B type chassis?
simonseize is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16576 Yesterday 07:25 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
