Like Tree24Likes
Old 08-26-2013, 01:24 PM   #11986
Trader Rating: 57 (100%+)
Originally Posted by jaank View Post
Maybe this video explains it better. As you can see when i roll the car and the suspension is fully compressed the car bumps up and down due to the driveshafts not moving enough.
I get you now. So when it's vertical, it works cause the dogbone angles up and nothing blocks it. When it's horizontal, the dogbone must be hitting the top of the outdrive?
I've never tried rolling at full compression though. I'll check in a few hours.
shagino is offline   Reply With Quote
Old 08-26-2013, 01:31 PM   #11987
Yeah, thats how it is. Thanks for helping out mate.
jaank is offline   Reply With Quote
Old 08-26-2013, 05:09 PM   #11988
4tec44's Avatar
Are their any companies out their that make a mid motor body that needs no cutting to fit the mm conversion.
TEAM DURANGO.
[Durango][Hobbywing][iPower][Jconcepts]
Rc8be.2,Dex210,Desc410v2,Traxxas 4tec.
4tec44 is offline   Reply With Quote
Old 08-26-2013, 05:50 PM   #11989
My buggy definitely doesn't have this problem. Can you verify the driveshafts are 65mm? The out drives are pretty close to flush with the camber mounting tabs. I wonder if you have the longer out drives meant for the SC. Did you build it yourself?
I highly doubt it. Given the position of the motor plate, it'd need a pretty high clearance.
Old 08-27-2013, 08:23 AM   #11990
Just built it from a kit.
I'll check on that tonight, maybe it is after all about the diff tightness so that the bolt head and nut are blocking the way.
EDIT: The driveshafts are 65mm.
Old 08-27-2013, 10:15 AM   #11991
P6
Google image it I found a few already but they do need cutting except the td body with the cowlings, before I had proper tools I uses a razor blade to cut body's then scrape along the edge to get rid of the sharpness I'm sure you could find one on eBay or something that is already cut
P6 is offline   Reply With Quote
Old 08-27-2013, 10:24 AM   #11992
Hmmmm. I just don't see how this is possible. Building from a kit gives you 65mm and the right driveshafts. Thought you may have bought used. If it was a diff problem, I can't see it happening on both sides.
Take a bunch of pics and post them.
Old 08-27-2013, 10:26 AM   #11993
onekiwi's Avatar
Why would you not want to cut it out? Worst case get a pair of toe nail sissors as they are usually sharp and tough and use them.
I don't think anyone unless purchased privately would want to cut it out for you as we don't all follow the lines (most probably do) when cutting to suit the buggy we have
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 08-27-2013, 10:30 AM   #11994
I think the intent is to use the same body for RM and MM.
Old 08-27-2013, 11:15 AM   #11995
Problem solved. I built the car based on manual but now with some common sense I rebuilt the drive shafts and done. Thanks.
Old 08-27-2013, 11:59 AM   #11996
Nice! Makes sense. Download the latest manual for updates.
Old 08-27-2013, 01:26 PM   #11997
TRF415boy's Avatar
My guess is you build the CVD wrong the first time, with the pin in the wrong way in the CVD barrel. I've seen this done before and let me tell you that isn't as per manual...
TRF415boy is offline   Reply With Quote
Old 08-27-2013, 04:51 PM   #11998
Brushless420's Avatar
Trader Rating: 169 (100%+)
Thumbs up RDRP +11mm Chassis DEX210
Just listed a NEW RDRP +11mm Chassis in the for sale forum.
Brushless420 is offline   Reply With Quote
Old 08-27-2013, 09:12 PM   #11999
Has anyone tried MM4 motor config on low traction clay type tracks? How is it different from rm3? I am considering to swap to mm4 due to the fact that i keep spinning out on hairpin turns. I personally love sensitive steering so i tend to oversteer and cos it to spin. Will changing to MM4 help me? Thanks in advance(:
Xiiaoda is offline   Reply With Quote
Old 08-28-2013, 03:33 AM   #12000
Trader Rating: 21 (100%+)
It would certainly help you recover easily to get out of a spin. I run MM4 and really enjoy how must steering it has. But it takes some getting use to. Give it a try.
mulepic is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
