Like Tree43Likes
Old 10-25-2011, 02:07 PM   #1186
Trader Rating: 19 (100%+)
Originally Posted by Glowster21 View Post
Guys, any of you running the actual kit 6 hole pistons? I want to try those and also close up some holes on the 2nd set of 6 holes it comes with, any particular pattern I should close off to go from 6 to 4 holes?
Cush ran the car with 6 holes - IMO it really needs to have 2-3 holes closed off and the oil lightened accordingly. The car jumped well, handled great, but chassis slapped hard off of even small jumps. We had 35ae front and 30losi rear. Maybe heavier oil would help, but ultimately I think the solution is to close off some holes or drill your own using the supplied blanks.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 10-25-2011, 02:24 PM   #1187
Matt Howard's Avatar
Nope, the 6 hole pistons don't give enough pack IMO. Just glue two opposing holes shut and be done with it. I'm running 4 hole 1.3's in front with 30wt and 4 hole 1.2's in the rear with 20wt.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-25-2011, 02:25 PM   #1188
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Why not run 1.2s up front as well?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-25-2011, 02:42 PM   #1189
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
are there any other kits share the same diameter size for the pistons?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 10-25-2011, 02:45 PM   #1190
Super Moderator
Cougar pistons might fit... But don't think that anybody elses pistons would yield any kind of advantage. The stock ones are great, and they supply blanks so you can drill your own as well.
Here is a question for you guys... if gluing your holes closed, why do you need to glue opposite sides in even numbers? could you close up 1 for a 5 hole piston? how about two next to eachother? What affect would we see?
- RCSpecialties -
Old 10-25-2011, 03:09 PM   #1191
Ok checked slipper again, rebuilt as per online manual - no change. What length is your slipper spring?
I have never had a prob building a slipper before....
mikeyscott is offline   Reply With Quote
Old 10-25-2011, 03:10 PM   #1192
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
You could close one hole, even 2 holes next to each other. The theory on two next to each other instead of opposing is the piston may bind. Two closed holes on opposite sides will be "even" and not bind the piston during travel.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-25-2011, 03:20 PM   #1193
Did you put the washers in? Before and after the spring? If so, try adding another washer.
Are you sure its not your diff slipping?
Old 10-25-2011, 03:26 PM   #1194
No reason really, but this way I "saved" a set of 6 hole pistons in both 1.2 and 1.3 in case I wanted to go back to them
RCTech #361
Old 10-25-2011, 03:28 PM   #1195
Yes washers there. Diff doesn't slip, the slipper gives before that.
Old 10-25-2011, 03:36 PM   #1196
Super Moderator
Take a vid... we are missing a piece of the puzzle.
- RCSpecialties -
Old 10-25-2011, 03:37 PM   #1197
Super Moderator
makes perfect sense....thanks Randy. By the way, did your read my race #2 report from last night? I am curious if you concur with anything I am experiencing. (page 76)
- RCSpecialties -
Old 10-25-2011, 04:33 PM   #1198
Super Moderator
Anybody know if these would work for the 210? Are these spring collars?
http://www.amainhobbies.com/product_...k-Nut-w-O-Ring
- RCSpecialties -
Old 10-25-2011, 04:35 PM   #1199
joelwhite's Avatar
Trader Rating: 55 (100%+)
those are for the regular 410 shocks, they arnt big bores
HEART OF A HUSTLER RACING TEAM
Trick Graphics--see spdrac430 on this forum for all your painting needs
Team Pit Racers-Fastest Guys In The Pits!
joelwhite is offline   Reply With Quote
Old 10-25-2011, 04:36 PM   #1200
Super Moderator
awe nuts.
- RCSpecialties -
St Ives RC Club B4Bandit Australian Racing 16576 Yesterday 07:25 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
