Like Tree32Likes
Old 08-25-2013, 09:35 AM   #11971
A heads up on the Tamiya 42214 damper X-rings ( o-rings).
Ive been using them in my DEX210 and they are soooooo much smoother than the original o-rings. The Tamiya shafts are a bit thinner in diameter, but still the x-rings are simply awesome in the Durango shocks
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
Old 08-25-2013, 10:50 AM   #11972
Trader Rating: 14 (100%+)
[QUOTE=McD44;12481234]What is your setup?
I just raced my MM4 setup for the first time yesterday on what is essentially beach sand. VERY loose and difficult to drive on especially with a MM car. I am new to 2wd 1/10 scale, I've been driving 1/8 scale and 4x4SC for a few years so my experience and skill with this kind of car is limited. I found that with a MM setup you basically never want to "stab" the throttle. You can enter corners faster though and when you're in the corner you use the throttle to maintain that speed, then roll on the throttle at the very exit of the corner when you're pointing in the direction you want to go. I worked to maintain a higher average speed without ever getting too aggressive with the trigger and it was working pretty well. I qualified 10th in the A-main and finished 6th. I was passing RM cars in the corners like crazy. There was one 180° corner that I had a ton of trouble with. It was extremely dry soft sand at the exit and since you had to slow down so much in the turn I had a tendency to get on it too much and fishtail or spin losing a lot of ground to other drivers. I imagine if I could have kept it together there I would have finished a few places better.
I ran the full 4.5° of rear toe, shocks mounted to the rear. I also find that running a higher inner camber link position on the rear helps with weight transfer keeping the rear a little more planted in corners. Are you running a shorty or full sized pack?[/QUOTE
for some reason RCTECH wont let me upload my pdf setup sheet, my mostly Im running stock setup from the book, stock springs, 27.5/25 wt oil, 4 hole shock pistons (2 holes glued) Ill try the camber link change and also the shock/a-arm flip. I guess I just might need to adjust my driving style for the MM and learn to be really smooth on the throttle! Also Im running full size lipo's.
fivepointnine is offline   Reply With Quote
Old 08-25-2013, 01:08 PM   #11973
McD44's Avatar
Trader Rating: 16 (100%+)
The full sized lipo might be your biggest problem. Your just not getting enough weight bias to the rear with them. See if you can borrow a shorty from someone to try out if you don't have one. Might make all the difference. Your rear springs are most likely too stiff as well for MM.
-Sean McDermott
Team Durango DEX210 | Team Durango DEX410v3 | Team Durango DESC410v2 | Team Durango DEST210R | "Whew, tires are expensive!"
McD44 is offline   Reply With Quote
Old 08-25-2013, 01:48 PM   #11974
cool, Ill see if I can source a shorty lipo and try some softer rear springs (Losi or Durango grey?) I cannot run the shocks on the rear as I get bind at full droop, I will have to drill the arms for droop screws or drill for shock holes to run it that way. I added another 2mm under the inner camber links, we will see if that makes a difference too.
Old 08-25-2013, 02:02 PM   #11975
GregerL's Avatar
Are they a direct fit, or do you need to use different plastic spacers?
GregerL is online now   Reply With Quote
Old 08-25-2013, 02:33 PM   #11976
Direct fit yes
My collection :
Old 08-25-2013, 05:09 PM   #11977
I finally got my hands on a 210 kit. It's my first 10th scale...feels like christmas
PS: I need to shorten the power wires, wasn't sure if i would keep that layout.
Óscar Álvarez
WRCC
chirivita is offline   Reply With Quote
Old 08-25-2013, 06:05 PM   #11978
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
Very nice!!!
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 08-25-2013, 08:15 PM   #11979
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Aluminium Chassis Feeler thread.
http://www.rctech.net/forum/r-c-item...l#post12483455
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 08-26-2013, 06:48 AM   #11980
GregerL's Avatar
Direct fit yes
Thank you very much, I will need to try those out then.
/Greger
Old 08-26-2013, 09:14 AM   #11981
Looking for help once more.
When the outdrive outputs are vertical then the suspension can move freely up.
When the oudrive outputs are horizontal then the suspension cant move as high up due to the dogbone not moving enough in the outdrive. The wierd thing it happens on the both sides, not only the nut side.
I did compress the spring and gave it a brief run on a drill but thats about it with the break in. Any ideas whats the cause of the problem?
jaank is offline   Reply With Quote
Old 08-26-2013, 09:36 AM   #11982
P6
I grabbed a slipper spring once and that was my problem count the number of coils on your diff spring should be 3 slipper has 5
P6 is offline   Reply With Quote
Old 08-26-2013, 11:15 AM   #11983
The slipper spring has 5 coils so that cant be it.
Old 08-26-2013, 12:17 PM   #11984
Trader Rating: 57 (100%+)
When you turn the car so the out drives are vertical, do you see the driveshaft move or th diff move? It doesn't make sense that it would matter
shagino is offline   Reply With Quote
Old 08-26-2013, 12:36 PM   #11985
Maybe this video explains it better. As you can see when i roll the car and the suspension is fully compressed the car bumps up and down due to the driveshafts not moving enough.
+ YouTube Video
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
