Like Tree27Likes
Old 08-21-2013, 08:28 PM   #11941
Trader Rating: 20 (100%+)
Default rear shocks
I see you are running the shocks on the rear of the arms. Did you just swap left & right arms so the mounting holes are on the rear? I'm assuming this is done to place a little more weight on the rear wheels to increase traction, is that correct?
D_n2blue is offline   Reply With Quote
Old 08-21-2013, 09:52 PM   #11942
madweazl's Avatar
Isnt that required when running MM?
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 08-21-2013, 10:33 PM   #11943
No, standard build has them on the front. Just wondering why some people are putting them on the back.
Old 08-21-2013, 11:01 PM   #11944
madweazl's Avatar
The shocks are so close to being inline with the axels I cant imagine it makes much of a difference.
RadioPost
Old 08-21-2013, 11:58 PM   #11945
onekiwi's Avatar
On high grip tracks it makes a difference, I felt you could get on the gas a little earlier.
I flipped the arms only but you can also just re drill extra holes in the rear of the arm.
I drove my DIY chassis yesterday and thought it worked really well. I need to lighten up the shocks a little now but all in all it worked really well
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 08-22-2013, 02:56 AM   #11946
McD44's Avatar
Trader Rating: 16 (100%+)
Here's my wiring. Doesn't interfere with the body. I am using the super flexible TQ sensor cable which helps.
-Sean McDermott
Team Durango DEX210 | Team Durango DEX410v3 | Team Durango DESC410v2 | Team Durango DEST210R | "Whew, tires are expensive!"
McD44 is offline   Reply With Quote
Old 08-22-2013, 03:04 AM   #11947
onekiwi's Avatar
If you want some more room on the side pods have a look at the penguin shells from the UK
He has raised the sides a bit more so fans fit with out a problem
http://www.ebay.co.uk/sch/haskins2004/m.html
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 08-22-2013, 05:12 AM   #11948
Trader Rating: 14 (100%+)
Originally Posted by shagino View Post
What speedo do you have? I would think putting it on the other side would lead to cleaner wiring. I guess it just really depends on the angle that's created.
I am running a GTB2 Novak.
fivepointnine is offline   Reply With Quote
Old 08-22-2013, 08:04 AM   #11949
Oasis's Avatar
Trader Rating: 36 (100%+)
Seem to be a lot of mixed reviews on the RDRP plate. I got cold feet and decided to stick with the Durango aluminum plate.
What are the "mixed reviews"..I dont think I've heard anything negative on the RDRP plate..I'm interested in what's wrong with them..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 08-22-2013, 01:58 PM   #11950
Any good starting points for gearing on 8.5R and 9.5R Speedpassion motors?
I'm driving on a quite small carpet track.
Not too sure about the ball cups too as they are too stiff. Arent there any other good ball cups by Durango for other vehicles?
jaank is offline   Reply With Quote
Old 08-22-2013, 02:06 PM   #11951
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
I run 8.5 SP setup 81/24. Go down a tooth or two for indoor.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 08-22-2013, 02:40 PM   #11952
Trader Rating: 57 (100%+)
Try searching in the DESC210 thread. I remember see a few mixed reviews also. The people who tried went back to the tresrey CF rack I think.
Picked up the car used as a backup buggy. One of the setup things that I wanted to try. The arms are pretty much the only thing you need to do. I heard the wheelbase is also a few mm's longer. I haven't done a side by side comparison but I'm driving this one on a high bite track.
shagino is offline   Reply With Quote
Old 08-22-2013, 02:42 PM   #11953
cantrell8's Avatar
Have you played with gearing to move the motor back at all? Just curious if anyone has?
Jonathan Cantrell
Viper rc
[email protected]
cantrell8 is offline   Reply With Quote
Old 08-22-2013, 06:52 PM   #11954
Oasis's Avatar
Try searching in the DESC210 thread. I remember see a few mixed reviews also. The people who tried went back to the tresrey CF rack I think..
I did a search on this thread and found nothing negative on the RDRP plate..I have however seen the carbon fiber rack crack..I have one on my dex210 and it seems to work fine..I haven't had any problems with mine..I have tried a few different racks. I didn't care much for the zero caster inserts. .made my buggy way to twitchy for me..
Old 08-22-2013, 08:55 PM   #11955
vr6cj's Avatar
Trader Rating: 124 (100%+)
So, it looks like that rack can be installed a couple different ways. Any one try it?
whats funny too is that rack isnt even on thier own websight. http://www.revolution-rc.com/our-products.html
vr6cj is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
