Like Tree26Likes
Old 08-16-2013, 03:50 PM   #11881
Trader Rating: 57 (100%+)
Originally Posted by Orion_2kTC View Post
Is there an easier way to remove/service the servo without having to remove the front top deck and front tower? The arms of the top deck obscure the servo mounting holes.
You can remove the two screws on the side by the top deck swivel. The servo lifts right out. It does leave a tiny burr in the top deck mount though.
If you unscrew the top deck swivel mount, you can push it down a tiny amount to get the that screw out with no burr.
shagino is offline   Reply With Quote
Old 08-16-2013, 05:16 PM   #11882
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
+1... slides up and out with a little bit of an angle.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 08-16-2013, 05:32 PM   #11883
madweazl's Avatar
Remove the 4 screws from the bottom that go into the front bulkhead and the whole front end will swing up in one piece.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 08-16-2013, 05:36 PM   #11884
Since we all have different methods of accessing and maintaining different areas of this buggy, what do you all think is the best method to get the RF hanger out and replaced on a RM3 setup? It's been such a pain in the past to get to.. I usually end up taking everything off the back just to get that piece swapped out.
Fishhook
Old 08-16-2013, 05:52 PM   #11885
RC10Nick's Avatar
custom chassis, in the style of xfactory:
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 08-16-2013, 05:55 PM   #11886
McD44's Avatar
Trader Rating: 16 (100%+)
Broke the stock one because of the modifications?
-Sean McDermott
Team Durango DEX210 | Team Durango DEX410v3 | Team Durango DESC410v2 | Team Durango DEST210R | "Whew, tires are expensive!"
McD44 is offline   Reply With Quote
Old 08-16-2013, 06:02 PM   #11887
RC10Nick's Avatar
nope, just decided to take it a few steps further.
JT RC Products
Old 08-16-2013, 06:25 PM   #11888
I think I just unscrewed the RR hanger and loosened the rest of the transmission and I could ease it out. I may have had to remove the top deck though. Replace it with an aluminum piece and be done with it
Any flex at all?
Old 08-16-2013, 08:20 PM   #11889
vr6cj's Avatar
Trader Rating: 124 (100%+)
I have got to say that the snap ring in the diff is the most unconvient pile I have every had the displeasure to work on and I have snap ring pliers.
thanks, thats all. lol
vr6cj is offline   Reply With Quote
Old 08-16-2013, 08:29 PM   #11890
madweazl's Avatar
I have a ball diff on the way, cant wait...
RadioPost
Old 08-16-2013, 08:36 PM   #11891
theclutch's Avatar
Here's some more of my transverse shorty mod I posted a few pages back. I managed to get the battery about 1/4" further back than previously, but I had to make a new top deck to get rid of the flex I induced when I cut off the support posts.
I'm trying to understand what are you trying to accomplish by moving the battery in that direction especially with a mid motor setup?
You're shifting more weight to the back and oddly still have a mid motor setup... AND you're also adding more weight to the outer edges of the car which would make it less nimble. All road race car designers out there aim to get the center of gravity as close to the center line of the car as much as possible and then play with the weight distribution front/back as they see fit.
So by putting more weight to the outer edges of the car, you're making the car want to "lean more" as it's turning. But at the same time, it would be less nimble when you want to change directions. And then by moving the battery to the back (and keeping mid motor setup), you've reduced the amount of weight in the front which would have a tendency to give you less steering...
So, I'm confused with what you're trying to accomplish. But maybe I missed something so I'm open to the thought process. Certainly not trying to insult anyone as I'm just trying to understand.
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 08-16-2013, 08:59 PM   #11892
mechanic77's Avatar
Originally Posted by rcjunky1 View Post
Thanks, so basically the hard springs and a new chassis. Depending on the wheelbase I would of just made a custom side pod for the inside and mount the elctronics in the battery area, with custom bumpers would of done the trick as well, but less fun
Yeah, that would have been easier .....but there's a few things you can't tell from the pictures (1)it's a +10mm wheelbase (2)I made the rear of the chassis wider so that the droop screws would still work with arms flipped with the shocks on the back and (3)the chassis is drilled for multiple battery configurations, 6 positions with a shorty (front/back and left/middle/right) and 3 with a full pack (left/middle/right).....
and I'm thinking about making up a set of shock towers for next season.....we'll see what happens
Durango DEX210, Tekin RS, SMC 7.5, Savox 1258TG
Durango DEST210R, Tekin RS, LRP 8.5, Savox 1256TG
Ofna Nexx 8, Tekin RX8/1900kv, Hitec 5955TG (FOR SALE)
mechanic77 is offline   Reply With Quote
Old 08-16-2013, 09:38 PM   #11893
vr6cj's Avatar
Alot mid motor setups use the config he's trying to do. Yokomo for instance uses this layout in the MR. I have used it in my yoke and my mm rb6 mid motor and its great. Xfactory has used it for years like this Mid motors have so much steering/corner speed as it is and alot less traction in the rear then I like. this actully helps keep the rear more planted and sure footed to me. Helps the rear rotate too.
Its all up to what you are wanting your car to do I guess. U can think of this layout to the standard rear motor in a way with normal esc/reciver vs everything inline esc/reciever.
Old 08-17-2013, 03:31 AM   #11894
RC10Nick's Avatar
Mid motor setups aren't about getting as much weight on the front tires as possible. It's about getting all the weight inside the wheelbase in order to reduce the pendulum effect that happens when the motor sits behind the wheelbase.
As for being nimble, that's not entirely the point of mid motor. As I said, the pendulum effect limits how fast you can go in a turn without swapping ends. Reduce or remove the pendulum, and you can go faster through a turn before you need to worry about swapping ends. Also, mid motor tends to be more stable in bumpier sections. The pendulum effect works in more than one spacial dimension
What makes RM work so well in lower traction is the static weight distribution. It has more weight on the rear. I'm not shocking anyone by saying this. They usually have at least 65% and up to 70% of their weight on the rear tires. The dex210 in mid motor with the battery the whole way back has about 62% on the rear. It's never going to generate as much reach bite like that. Other companies have identified a solution, as vr6cj has pointed out. Turn the battery sideways and get as much freaking weight on the back without putting it outside the wheelbase as possible. My goal is to get at least 65% on the rear without having to add weight. I was up to about 64% with the battery a 1/4" from the motor. With my new configuration, the battery is as close as it can get. That 1/4" will help quite a bit. Also, now I can move my ESC a little off center and 1/4 further back to optimize it's placement and reduce the wire length to help my weight distribution even more.
The whole point of this is to have a car that grips like a rear motor, but drives like a mid motor. I'm getting close. The last time I was out at the track, which is very dusty and loose, I had much more rear grip with the battery the way it is. It was still loose, but I did manage to turn some heads that day. "That's mid motor?" "I can't believe you can get that thing around the track without being all over the place!" etc
Mid motor is still in its "black magic" days, but I think I've got it figured out and I'm ready to have a massive advantage over rear motor drivers until they catch up with physics.
JT RC Products
Old 08-17-2013, 09:08 AM   #11895
Could anyone give me a good starting spot for gearing with a 81t spur for 17.5 blinky? I don't want to buy new stuff as soon as I get enough I plan on getting the Avid slipper
cripplethreat is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 Yesterday 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
