Like Tree43Likes
Old 08-15-2013, 07:11 PM   #11866
RC10Nick's Avatar
Here's some more of my transverse shorty mod I posted a few pages back. I managed to get the battery about 1/4" further back than previously, but I had to make a new top deck to get rid of the flex I induced when I cut off the support posts.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 08-15-2013, 07:20 PM   #11867
McD44's Avatar
Trader Rating: 16 (100%+)
I just got the Diggity Designs 4mm lowered rear shock tower and man is there some major droop now. I am running the gear diff which has the normal length outdrives. At full droop the top part of the dogbone pin at TDC is still within the outdrive. I had no problems with pins popping out during practice. I do however have the shocks mounted to the rear of the tower which I believe will limit the droop more than front mounted shocks due to the anti-squat angle of the arms. If you're running 3 of anti-squat and have front mounted shocks i imagine you'll have some problems.
-Sean McDermott
Team Durango DEX210 | Team Durango DEX410v3 | Team Durango DESC410v2 | Team Durango DEST210R | "Whew, tires are expensive!"
McD44 is offline   Reply With Quote
Old 08-15-2013, 07:20 PM   #11868
vr6cj's Avatar
Trader Rating: 124 (100%+)
Does either kit(rtr or kit) of the dex210 come with a +8 chassis. Neither discription says.
vr6cj is offline   Reply With Quote
Old 08-15-2013, 07:31 PM   #11869
McD44's Avatar
I know the kit doesn't. The RTR has a DIMEC chassis but I don't think it's the +8.
There's a new version coming out within the next 6 months and I'm pretty sure it'll have the +8 chassis. That's the rumor anyway.
-Sean McDermott
Old 08-15-2013, 07:36 PM   #11870
vr6cj's Avatar
ah thanks, picked up a used one under a hundy and was looking to update it but man, not sure. Even though car was cheap its alot to update these cars.
Old 08-15-2013, 08:10 PM   #11871
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
The RTR DIMEC is +8mm. If you go to Team-Durango.com and pick the vehicle you want to look at. Up top there will be a tab to look at the "Standard Parts" and "Optional Parts". Anything in the standard parts is what is on the vehicle that you are looking at.
Well... I just looked at it again.. and I guess since they started making the version B chassis, they have discontinued the original DIMECs.. and they aren't there.
It is a +8mm DIMEC on the RTR.. not on the kit though.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 08-15-2013, 08:10 PM   #11872
Trader Rating: 57 (100%+)
Pretty sure the RTR is +8. I don't think they make the buggy DIMEC without the +8.
shagino is offline   Reply With Quote
Old 08-15-2013, 08:16 PM   #11873
mechanic77's Avatar
Originally Posted by rcjunky1 View Post
I've seen that same in the past, most likely the diff screw, not the thrust. Could you post some pics of your dex LM and modified? i'd love too see what bodies you run, the tower/shock set up and how you did the body mounts on both
Yeah, here you go rcjunky:
Late model w/Customworks Mountaineer body
Modified w/my own body (illegal....next year )
Both chassis's are made from G10FR4, the late model has a customworks front bumper, the rear body mount on the mod is from customworks, and I made most everything else (non-stock) from G10 and Kydex. Let me know if you have any questions, I'd be more than happy to answer
Durango DEX210, Tekin RS, SMC 7.5, Savox 1258TG
Durango DEST210R, Tekin RS, LRP 8.5, Savox 1256TG
Ofna Nexx 8, Tekin RX8/1900kv, Hitec 5955TG (FOR SALE)
mechanic77 is offline   Reply With Quote
Old 08-15-2013, 08:19 PM   #11874
vr6cj's Avatar
Can any of you guys measure the wheelbase on your +8's so I can measure mine and see where it is at. Wouldnt want to order a chassis if its alrdy got a +8.
UPDATE: So compared it to my RB6 it is almost identical in wheelbase lenght so Im pretty sure u guys are right and it comes with the +8 older non B chassis.
Old 08-15-2013, 08:35 PM   #11875
If your chassis is plastic tub, it's +8. I have never seen or heard of a regular sized Plastic chassis on this buggy. If it's made of some other material, then it could be any number of sizes.
Fishhook
Old 08-15-2013, 09:00 PM   #11876
madweazl's Avatar
Out of the box, my RTR had a 289mm wheelbase.
On another note, still looking for initial setup ideas from my earlier post.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 08-15-2013, 11:07 PM   #11877
rcjunky1's Avatar
Thanks, so basically the hard springs and a new chassis. Depending on the wheelbase I would of just made a custom side pod for the inside and mount the elctronics in the battery area, with custom bumpers would of done the trick as well, but less fun
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 08-16-2013, 10:04 AM   #11878
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Looks pretty interesting. Wonder how it will work at Bumps, Pit Stop or Grind Lab like that. Still have the motor in the wrong direction.
ST Racing Concepts (STRC)
Old 08-16-2013, 11:30 AM   #11879
Orion_2kTC's Avatar
Is there an easier way to remove/service the servo without having to remove the front top deck and front tower? The arms of the top deck obscure the servo mounting holes.
Orion_2kTC is offline   Reply With Quote
Old 08-16-2013, 03:05 PM   #11880
Trader Rating: 74 (100%+)
I use a 120mm long hex driver from Racers Edge to reach through the holes and remove the 4 screws.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is online now   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16575 Yesterday 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
