Like Tree23Likes
Old 08-13-2013, 07:06 AM   #11836
Guest
Send a message via Yahoo to kyoshoracer77
Default durango website
I been watching the durango website and the dex210 was on there yesterday an gone today???? U can search it an it will come up and the rtr???
kyoshoracer77 is offline   Reply With Quote
Old 08-13-2013, 07:19 AM   #11837
Trader Rating: 27 (100%+)
Not quite sure what you are talking about, but both the DEX210 and the DEX210 RTR show up under the Products tab.....
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 08-13-2013, 07:25 AM   #11838
Guest
Maybe they r out of stock??????
Old 08-13-2013, 08:01 AM   #11839
SUPERLOOPER's Avatar
http://www3.towerhobbies.com/cgi-bin...P=SM&I=LXCBXL#
Tower has them.
2017 Sponsors:
Team SOARSEIKI * AKA * Reds * Sanwa * Nitro Pro fuel * LFR * On point graphics * Xpert * M2C * Daytona RC paint
Brian Looper
SUPERLOOPER is offline   Reply With Quote
Old 08-13-2013, 08:53 AM   #11840
Trader Rating: 57 (100%+)
I think you're reading too much into it.
shagino is offline   Reply With Quote
Old 08-13-2013, 01:39 PM   #11841
Orion_2kTC's Avatar
Is the paper between the spur/pinion still the best way to set mesh?
Orion_2kTC is offline   Reply With Quote
Old 08-13-2013, 01:47 PM   #11842
I go by feel then look to make sure it looks right. It's just a tiny amount of play.
Great sig. I can relate.
Old 08-13-2013, 02:00 PM   #11843
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
A simple trick I picked up was to just put on a pinon 1 tooth bigger than the one I want to use. Make the mesh flush with that pinon then swap it out with the one you want to run. Presto perfect pinon mesh.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 08-13-2013, 03:16 PM   #11844
I'm having a problem with the thurst bearing.
Why cant the diff screw get fit trough the smaller thrust bearing spacer?
jaank is offline   Reply With Quote
Old 08-13-2013, 05:45 PM   #11845
Orion_2kTC's Avatar
Different problem, I'm installing a servo and I only have 2 bolts for the servo mount...can I get away with only using two?
Old 08-13-2013, 07:13 PM   #11846
mechanic77's Avatar
I've had issue with that too.....found a burr on the diff screw at the bottom of the threads, just take a file and clean it up and it will slip right on
Durango DEX210, Tekin RS, SMC 7.5, Savox 1258TG
Durango DEST210R, Tekin RS, LRP 8.5, Savox 1256TG
Ofna Nexx 8, Tekin RX8/1900kv, Hitec 5955TG (FOR SALE)
mechanic77 is offline   Reply With Quote
Old 08-13-2013, 07:51 PM   #11847
rcjunky1's Avatar
I've seen that same in the past, most likely the diff screw, not the thrust. Could you post some pics of your dex LM and modified? i'd love too see what bodies you run, the tower/shock set up and how you did the body mounts on both
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 08-14-2013, 01:16 AM   #11848
madweazl's Avatar
What would be a good baseline for the shocks (big bores)? Track is small, packed dirt, and not too rough but not smooth either. I only have 1.2 and 1.3 x6 pistons to play with right now. I was thinking 30 up front and 27.5 out back. I have 2.14 Avid rears or some light blue Durangos and was thinking of 2.63 Avids for the front with the 1.2s front and rear. Jumps arent huge and no whoops.
Not a very good pic of the 30x60' track but it's all I have right now.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 08-14-2013, 06:33 AM   #11849
tiago890's Avatar
Hey Guy's,
just picked up a DEX210 and swapped the stock chassis for the DIMEC +8, is there anything else that is a must change or add for this kit to start off with, also wanted to know some suggestions on tire choices for outdoor dirt track. The track layout was changed a week ago so the dirt is still fresh.
thanks
Sponsors: DaWife Racing and Team Myjob
tiago890 is offline   Reply With Quote
Old 08-14-2013, 07:23 AM   #11850
TAMAK's Avatar
Trader Rating: 28 (100%+)
Originally Posted by tiago890 View Post
Hey Guy's,
thanks
Good choice! I would make sure the car has an alloy or carbon steering link: http://www.exotekracing.com/dex210-d...steering-link/ and a BMAN rear skid for the original Dimec, if you got the type B don't worry about it... Only other must have "spares" would be a rear tower, gear cover, and pick up a hub / carrier set... I have yet to actually break anything but a rear tower and just recently a front spindle (my fault) in 2 years..
Outdoor offroad tires, always ask your local fast guys.. But you cant go wrong with a set of Proline M3 holeshots and 4 ribs.. Also, before you invest in tires / wheels. ask yourself if you want to use B4 or Durango rear wheel 12mm or 14mm hex??
DEX210 Wheels: http://www.tresrey-usa.com/tresrey-a...eel-hub-clamp/
B4 wheels on DEX210: http://www.tresrey-usa.com/yaiba-rac...rear-12mm-hex/
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
