Like Tree43Likes
Old 08-12-2013, 08:16 AM   #11821
Trader Rating: 27 (100%+)
Originally Posted by Orion_2kTC View Post
So I'm redoing my shocks based off a recommendation from a local. The setup suggests a 2 hole piston however I don't have any blanks and no 2 hole pistons. However I do have several 6 hole pistons laying around. I had the idea of closing off some of the holes with an old soldering gun then sanding any bumps smooth. Anyone ever done this with success?
That's how I changed mine to 4 hole, never had an issue doing it this way.
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 08-12-2013, 08:29 AM   #11822
Orion_2kTC's Avatar
Great! Thanks.
Orion_2kTC is offline   Reply With Quote
Old 08-12-2013, 10:03 AM   #11823
Trader Rating: 29 (100%+)
CA glue a tooth pick in the holes, let it dry, cut off extra, and sand flat. I have done this to both my DEX210, and DESC210 and it's perfect.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 08-12-2013, 01:10 PM   #11824
How to install a Sav÷x servo?
I would like to use the original Durango screws for the mounts but then you would have to use the rubber bushings.
jaank is offline   Reply With Quote
Old 08-12-2013, 01:59 PM   #11825
Trader Rating: 21 (100%+)
Easy, clean and quick. I've done this for years without problems
AE B6
AE B64
kerby is offline   Reply With Quote
Old 08-12-2013, 04:00 PM   #11826
Woulvesbaine's Avatar
Or buy 4x 1.0 tapered pistons (generally available online) and hand drill out to your desired size.
All of these options work fine. Use the one you're most comfortable with.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 08-12-2013, 04:00 PM   #11827
madweazl's Avatar
Originally Posted by shagino View Post
Rotate the mounting endbell. My tabs are about 2:00 when looking at the tabside.
The D3.5 just doesnt have many clock options on the can. I didnt want it clocked that far to keep it protected.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 08-12-2013, 04:52 PM   #11828
Trader Rating: 57 (100%+)
Where do you want the tabs to be? 2:00 seems ideal for me.
shagino is offline   Reply With Quote
Old 08-13-2013, 05:05 AM   #11829
madweazl's Avatar
That isnt too bad but I dont have a rear bumper either. I try to keep them as far forward as possible. Just wish the front didnt have the extra area machined out.
RadioPost
Old 08-13-2013, 05:57 AM   #11830
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Speed Passion motor will solve that.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 08-13-2013, 06:07 AM   #11831
madweazl's Avatar
Reedy Sonics (my preference) are fine too but Amain was out of 13.5s when I ordered the motor for this buggy (they're working on a spec'ish class out here). This is my first Trinity in years (10 probably ), not sure why they had to use the asymmetrical design but I guess everyone has to be unique.
RadioPost
Old 08-13-2013, 06:32 AM   #11832
McD44's Avatar
Trader Rating: 16 (100%+)
I just ordered the Diggity Designs front and rear carbon towers. I ordered the 4mm lowered rear tower. My question is about dogbone issues with the additional droop. I don't currently run the "Long" outdrives, will I have issues with the driveshafts popping out?
Also, are the edges prepped or do they need to be sanded/CA glued?
-Sean McDermott
Team Durango DEX210 | Team Durango DEX410v3 | Team Durango DESC410v2 | Team Durango DEST210R | "Whew, tires are expensive!"
McD44 is offline   Reply With Quote
Old 08-13-2013, 06:34 AM   #11833
Sorry, the pic is from my SC. Only had that one on my phone. My DEX210 only has the motor guard and is fine.
Old 08-13-2013, 07:31 AM   #11834
It's recommended to run the longer outdrives, especially with the additional droop.
The edges of the Diggity Designs towers are not prepped and it is recommended to CA them.
Edwin Hartman
Old 08-13-2013, 07:59 AM   #11835
McD44's Avatar
Thank you sir!
-Sean McDermott
St Ives RC Club B4Bandit Australian Racing 16580 Today 03:10 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
