Like Tree23Likes
Old 07-28-2013, 06:39 AM   #11746
Brownie.'s Avatar
Originally Posted by RC10Nick View Post
What pistons are you using? My car jumped much better after I switched from the kit 6 hole to a 4 hole.
Just using kit pistons still. What weight oil with the 4 hole pistons?
Not My Problem
Brownie. is offline   Reply With Quote
Old 07-28-2013, 08:57 AM   #11747
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I use a 4 hole x 1.3mm pistons in my car. RIght now I use 30wt front oil with Durango black spring and 27 1/2wt rear oil with the Dark Blue Durango spring. Jumps really well like this without it doing anything funny. Think it will be a really good starting point for you.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-28-2013, 09:19 AM   #11748
Is the dimec type B chassis durable?
Are steel skids still needed for indoor track use?
ericzwick is offline   Reply With Quote
Old 07-28-2013, 01:02 PM   #11749
Trader Rating: 27 (100%+)
Not sure about the DIMEC, but the DIMEC20 type B chassis is super durable. I have been running it since January and I have not been able to break one yet.... No longer a need to run the skids with the type B chassis to increase durability.
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 07-28-2013, 01:14 PM   #11750
perfect! Thanks!
Old 07-28-2013, 04:10 PM   #11751
Default Dimec
What are the difference between the Dimec & dimec20 +8 running on indoor clay dirt mix will I c big difference over kit chassis??? Thanks
dolfns1 is offline   Reply With Quote
Old 07-29-2013, 06:02 AM   #11752
Brownie.'s Avatar
No worries sounds good. just a dumb question it feels like the car has alot less pack in the front than the rear... all my other car feel the opposite, less pack in the rear, when i drop it from about 10 inches it slaps the front of the chassis and barely moves the rear. i dont understand why, it has 30w front and 25w rear (i dont have any half weights atm) with very simmilar springs to yours and 6x 1.3 pistons.
ill get my hands on some 4x 1.3 and try those. it just dosent make sence to me. most of my jumping issues are it tips sideways or actually jumps so far tail down it lands upside down haha.
cheers for the help
Not My Problem
Old 07-29-2013, 06:13 AM   #11753
wyd
Tech Legend
wyd's Avatar
cheers for the help
You drop it with the oils and pistons I have it won't feel like that. I actually had it at first with 35wt oil front and 30wt oil rear but seemed a little too much pack. You can on my setup go one stiffer spring in the front and one softer in the rear depending on your track and how the jumps are. Should get you in the ball park.
One thing I noticed vs the other brand cars I have run is when you look at many different setups the Durango ones are all over the place and you don't see many common setups. Only thing seems common is pretty much the camber link postions and shock positions. Oils, pistons, springs, and battery placements are all over the place.
Old 07-29-2013, 08:30 AM   #11754
RC10Nick's Avatar
Post
cheers for the help
I actually run a larger pistons in the rear. 1.1 up front and 1.3 in the rear with the same weight oil front and back.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 07-29-2013, 01:06 PM   #11755
The +8 chassis will give you more stability and better traction coming out of turns. If you are running on a very tight track, the stock aluminum chassis might be better (depends on layout), but overall the +8mm Dimec20 chassis would be the way to go. Make sure that you get the type B chassis with the additional type B parts (bulkhead and RF/RR suspension mounts).
Edwin Hartman
Old 07-29-2013, 06:55 PM   #11756
lil_man72's Avatar
Trader Rating: 29 (100%+)
Originally Posted by DangerCow View Post
how are the aluminum towers? does the added weight that high up have any negative effects on the car?
lil_man72 is offline   Reply With Quote
Old 07-29-2013, 09:12 PM   #11757
What is a good starting point for stock gearing for racing on a small indoor carpet track?
cripplethreat is offline   Reply With Quote
Old 07-29-2013, 09:37 PM   #11758
Trader Rating: 2 (75%+)
Indoors I run mm4 with 24/81 on a 10.5.
durangoman is offline   Reply With Quote
Old 07-29-2013, 10:53 PM   #11759
ekt
ekt's Avatar
For 17.5T? 69T spur and 30-35 pinion, depending on how technical the track is.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 07-30-2013, 10:06 AM   #11760
Woulvesbaine's Avatar
Love the Alitalia scheme. Did you paint that?
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
