Like Tree43Likes
Old 10-25-2011, 08:23 AM   #1156
Trader Rating: 19 (100%+)
This won't help with the ballcups popping off (I know many have had issues, but we never have, even with the old ones), but I had the same adjusting issue when I built the 210. I took an 1/8 drill bit and bored the end of the ballcup roughly 3/16 deep to allow the shank of the link to not bind when it goes into the cup. You could also just shorten the ballcups by the same amount. As with any camber link assembly, use some type of lubricant- beeswax, chap stick, or black grease on the threads. I always use a drill to work the link in and out of the cups a few times before I assemble them for good.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 10-25-2011, 08:30 AM   #1157
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Matt Howard View Post
the plastic is too soft. The original ballcups would pop off when you tried adjusting the turnbuckle. The HD one's at least stay on when you're adjusting the turnbuckle but they still pop off way too easy IMO. I've converted all my previous durango vehicles over to Losi cups with standard ball ends and haven't had one problem.
So you use the 22 ballcups and ballstuds?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 10-25-2011, 08:43 AM   #1158
rcgod's Avatar
Trader Rating: 27 (100%+)
Anyone know what the wheelbase is?
rcgod is offline   Reply With Quote
Old 10-25-2011, 08:48 AM   #1159
Matt Howard's Avatar
They're losi ballcups that I stocked up on awhile ago, before the 22 came out. I use TC5 ballstuds because they have metric threads
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-25-2011, 08:53 AM   #1160
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by sparkwraps View Post
In theory, and correct me if I am wrong, a 3 gear rear has the motor spin up the usual way and when you punch it, the back of the car squats, taking weight off of the front wheels.
With the 4 gear, your motor is spinning the opposite direction and while the car may still squat under acceleration, it is not as much. So you have more weight on the front tires. (Motor spins toward the front/up instead of the towards the back/ground, essentially "lifting" the back of the car instead of forcing it down)
You have it 180 degrees backwards.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-25-2011, 09:15 AM   #1161
sparkwraps's Avatar
Trader Rating: 34 (100%+)
ok... The motor rotation is right in my theory and I was assuming that the rotational force of the motor was the gain in traction. So what is the traction/handling gain from in the RM4 setup?
sparkwraps is offline   Reply With Quote
Old 10-25-2011, 09:18 AM   #1162
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
In RM4 the motor and diff spin the same direction. In theory this places a lot of down force on the rear tires.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-25-2011, 09:24 AM   #1163
Super Moderator
In a 3 gear config, the motor spins backwards. When the motor spins backwards, it makes the car attached to it spin the opposite direction, which is forward. forward rotation of the chassis means more pressure on the front tires, and less on the rear
In a 4 gear config, the opposite happens. The motor spins forward, which makes the chassis rotate backwards, which means less pressure on the front tires, and more on the rear tires.
So in both configs the car squats on-throttle, but there is a slight pressure bias towards the front tires in 3 gear, and a slight bias towards the rear tires with the 4 gear.
- RCSpecialties -
Old 10-25-2011, 09:29 AM   #1164
sparkwraps's Avatar
OK, so if I am looking for more steering, I should stick to the RM3 setup?
Old 10-25-2011, 09:34 AM   #1165
Team Tekin
Randy_Pike's Avatar
Yes more or less. I've found I can get all the steering I need in both configurations so far.
Old 10-25-2011, 09:39 AM   #1166
Jmuck69's Avatar
So the new process in set up for a new track would be to determine tires, the motor config, then fine tuning suspension?
B6D | B64D
Old 10-25-2011, 09:50 AM   #1167
sparkwraps's Avatar
Cool - Thanks. Nixing my plans for a 4 gear swap tonight. Will work on other setups for a gain in steering instead.
Randy, What is your front shock length (droop)? Your setup sheet is missing that.
Edit - To be more clear, I am looking to remove the on power push that I have in my setup. I removed a good bit of it, but still suffering a bit.
Old 10-25-2011, 09:55 AM   #1168
Slash'em1's Avatar
Its a good day fellas! I just got my kit today and hopfully will be starting the build tonight. Has any thought about using RPM ballcups? I never had a issue with them on my B44. I'm thinking I should just get new ones before I start the build. I just want to make sure I get something that will work.
Slash'em1 is offline   Reply With Quote
Old 10-25-2011, 09:58 AM   #1169
ABBOTT's Avatar
Anybody tried the mid config out yet. At Smac there were several very succesful X-factory rides last season. But these are not the drivers who have decided to try the 210!
SmacTrac / STL Dirtburners / Blaze RC
ABBOTT is offline   Reply With Quote
Old 10-25-2011, 10:02 AM   #1170
Super Moderator
- RCSpecialties -
St Ives RC Club B4Bandit Australian Racing 16576 Yesterday 07:25 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
