Like Tree23Likes
Old 07-12-2013, 08:30 PM   #11626
Trader Rating: 2 (75%+)
Originally Posted by madweazl View Post
This can happen when the thrust being goes out. Check the nut and bolt that holds the assembly together as well.
New thrust bearings and nut and bolt. I am lost lol.
durangoman is offline   Reply With Quote
Old 07-12-2013, 08:57 PM   #11627
Trader Rating: 19 (100%+)
Are you sure the thrust washers are oriented properly? The one with the smaller ID goes to the outside against the diff bolt.
Only other thing I can think of is there may be a burr on the diff bolt (really shouldn't be, but it's possible) that is causing the bolt to tighten.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 07-13-2013, 07:27 AM   #11628
Trader Rating: 74 (100%+)
Johnny I thought the thrust washer had a different OD.. Either way, the smaller is closest to the head of the bolt.
The Exotek chassis, I like the design. But since switching to the Tresrey +10 chassis my car is awesome.
We also have Tresrey castor blocks, lrc blocks, & lower shock spring cups coming.
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 07-13-2013, 01:48 PM   #11629
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
When you went to the +10 chassis wouldn't it make the car more numb feeling especially on clay? I can see longer on carpet to help mellow it out some but I tried +10 type chassis on my Tamiya and my B4.1 and both handled worse on the medium to high bite clay tracks.
I have run the stock chassis on clay and also a fairly rough track with medium bite and it felt very smooth and easy to drive. I would like to mess around with moving the front axles to 3 or 2 as I'm in the stock postion of back 4mm for my steering blocks. Interested to see how the car acts once I the front axles closer to inline.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-13-2013, 01:59 PM   #11630
Brian,
On the DEX210 the longer chassis benefits handling characteristics. I run on both clay and dirt. I think lrc blocks are a missing link in my setup.
Also with the 12mm hex conversion on my front axles I am forced to run full trailing front wheels. Also this takes the adjustment away, & the sensitivity making the car more predictable.
Old 07-13-2013, 07:50 PM   #11631
Trader Rating: 24 (100%+)
any one else finding the standard TD diff balls flat spot quickly ?
I built a brand new diff, started tuning in the slipper on the bench doing it the old way where u hold both wheels and punch the throttle untill front wheels lift 2 inchs and diff slipped for 0.5 a second and now its f****d. feels gritty and doesnt turn well.
I then built another new one and after 2 runs on dirt its gritty and feels terrible.
is there a setting to go off, like lock diff and loosen 1/8 of a turn or something?
JK
" It takes a lot of things to go right, but only one thing to go wrong to lose a race "
HEI | NBHC.com | Model Engines | World Hobbies
Jarred King is offline   Reply With Quote
Old 07-13-2013, 09:25 PM   #11632
ae4ever's Avatar
JK
Had the same problem! Went through 3 new diffs, picked up a B-fast pro rebuild kit and never looked back. Great products!!
ae4ever is offline   Reply With Quote
Old 07-14-2013, 12:33 AM   #11633
madweazl's Avatar
JK
You're just leaving them too loose. When I build the diffs, I tighten the diff 1/4 turn at a tight once it starts to get snug. After each quarter turn, I rotate the diff by hand a few times until I get it close to fully tightened. I'll then drop it in the car and hold one wheel and give it throttle for about 30 seconds, switch to the other tire and do the same. It will usually loosen up a fair amount after this so I'll repeat the procedure after tightening it up and repeat the process for about 1 minute on each side. Recheck and readjust and toss it on the track. Durango is supposed to have a good video on building the diff but I havent checked it out yet.
If the diff slips at all, it's toast and not worth racing.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 07-14-2013, 01:10 AM   #11634
[QUOTE=madweazl;
If the diff slips at all, it's toast and not worth racing.[/QUOTE]
wow, if it slips once throw in bin lol. other brands arent like this. balls must be to soft. ran mine today with new diff didnt slip still feels good.
Old 07-14-2013, 02:36 AM   #11635
madweazl's Avatar
Regardless of manufacturer. Once it slips, it wont ever be smooth again. The flats spots on the balls and groove in the ring will get worse exponentially quicker. At my skill level it isnt going to make a difference but you fast guys sure will. Cheap enough to rebuild and have it operate properly.
RadioPost
Old 07-14-2013, 03:21 AM   #11636
I a g r e e....
Bfast kits are unbeatable, using their greases too. My bfast kit is having a b day in my Dex210. .
Old 07-14-2013, 03:45 AM   #11637
yeah bfast is good.
Old 07-14-2013, 07:30 AM   #11638
platgof's Avatar
I used the Acer tungsten balls from Tower, with new Durango plates and thrust bearings. I went by the rebuild video on the Durango site. I bought 3 packs of ten of the Acer balls to do two sets.
platgof is offline   Reply With Quote
Old 07-15-2013, 06:17 AM   #11639
SUPERLOOPER's Avatar
What body are you guys using with the +8 type B chassis. My Jconcepts body does fit but not well. Options?
2017 Sponsors:
Team SOARSEIKI * AKA * Reds * Sanwa * Nitro Pro fuel * LFR * On point graphics * Xpert * M2C * Daytona RC paint
Brian Looper
SUPERLOOPER is offline   Reply With Quote
Old 07-15-2013, 06:48 AM   #11640
ekt
ekt's Avatar
http://www3.towerhobbies.com/cgi-bin...?&I=LXCUXF&P=7 for the +8mm DIMEC
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16563 Today 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Pistol123
