Like Tree24Likes
Old 07-09-2013, 07:34 PM   #11581
matt*strike's Avatar
Trader Rating: 41 (100%+)
I have had them pop on the sct but not the buggy
Team Redline O.G.
Alpha Raceway ---Carbondale, IL
matt*strike is offline   Reply With Quote
Old 07-09-2013, 08:04 PM   #11582
DonRSD's Avatar
New to RC here.....
I have a DEX210 and the guy at the local RC shop told me to buy some TD701001 Droop Screws.
My issue is I forgot what he said to do with them lol.
He mentioned about the rear sagging or something.
Any help would be appreciated.
-A Clueless Newb
PSN: DonVCorleone
The U - NY Mets - NY Giants - Miami Heat
-TLR 22
-Durango DESC410R
DonRSD is offline   Reply With Quote
Old 07-09-2013, 10:15 PM   #11583
ekt
ekt's Avatar
Originally Posted by DonRSD View Post
New to RC here.....
-A Clueless Newb
Step 11 of the manual, if you're not sure where they go. One in each arm.http://www.team-durango.com/pdf/manu...n%20Manual.pdf
They are used to limit how far down the arm will travel.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 07-09-2013, 11:37 PM   #11584
Azagar's Avatar
I would recommend the internal shock limiters found on this part tree vs droop screws. There's 4, each 2mm. The front especially need them in my opinion. But I don't run them in the rear not sure why you got that bit of advice.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 07-10-2013, 12:16 AM   #11585
Trader Rating: 24 (100%+)
anyone else have trouble keeping the stock ball diff smooth. mine is gritty and notchy after 3 runs. seems as if the diff slips once its ruined.
any tips?
" It takes a lot of things to go right, but only one thing to go wrong to lose a race "
HEI | NBHC.com | Model Engines | World Hobbies
Jarred King is offline   Reply With Quote
Old 07-10-2013, 12:36 AM   #11586
any tips?
Team Durango have a diff building video on youtube - its good.
Put some thread lock on the the end of the diff screw and let it dry before assembling the diff.
If you want extra smooth action - sand the diff plates flat.
Use a minimal amount of grease
Make sure to run the diff in before assembling the gearbox.
Tungsten Carbide diff balls are a good upgrade - but the standard SS balls aren't bad - just don't last as long.
legacy555 is offline   Reply With Quote
Old 07-10-2013, 02:33 AM   #11587
any tips?
The diff plates aren't very durable if the diff slips. The balls etc are more durable. Turn the diff plates around when you rebuild the diff or put in new ones. Sanding the plates helps.
Yellow Wheels is offline   Reply With Quote
Old 07-10-2013, 06:20 AM   #11588
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
So far I have about 20 plus runs on my car and the diff is still smooth like when I built it. When I had it all together in the car I broke the diff in some and then the first pack or two I really ran the car very easy. Since then I tightened the diff a tad and set the slipper and the diff has been fine ever since.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-10-2013, 08:39 AM   #11589
DangerCow's Avatar
Thanks for the discussion on the STRC caps, I'm not going to bother putting them on, and unfortunately I opened the bag so I can't return them. Maybe some other solution will come up some day. I also heard that Durango is coming up with some soon.
___________________________________________
Axial Scorpion; Exo ../.. Kyosho Turbo Ultima; USA-1
Schumacher CAT K1; Cougar sv2; Cougar KF ../.. Serpent 411 ERYX 2.0
Tamiya XV-01 Pro ../.. Team Durango DEX210; DEX410; DEX408v2
Yokomo B-Max III Factory www.corvictoria.com
DangerCow is offline   Reply With Quote
Old 07-10-2013, 09:07 AM   #11590
Trader Rating: 19 (100%+)
any tips?
I've found the stock balls to be fairly soft. The first upgrade any car of mine gets is a BFast diff kit with their carbide balls and sanded rings. The diff in my SC is literally going on it's 3rd set of outdrives and still buttery smooth. That's over 6 months of racing. I do however keep the stock thrust assembly in place, it's a good piece.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 07-10-2013, 10:13 AM   #11591
Brushless420's Avatar
Trader Rating: 169 (100%+)
Exclamation DEX210 INSERTS
Which toe in inserts and camber inserts are most running? Also what axle inserts are suggested?
Brushless420 is offline   Reply With Quote
Old 07-10-2013, 10:18 AM   #11592
TAMAK's Avatar
Trader Rating: 28 (100%+)
Choose your surface and grab a hupo or Lutz setup: http://www.petitrc.com/setup/durango...ngoDEX210.html
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 07-10-2013, 03:19 PM   #11593
wyd
Tech Legend
wyd's Avatar
I use the STRC caps but I also use the stock hardware to mount my shocks so they have been excellent for me.
Old 07-10-2013, 03:45 PM   #11594
EvanAZ's Avatar
Trader Rating: 99 (100%+)
You can cut the ball end off the stock plastic one and see if those fit. I did that on a set of caps but they weren't STRC.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 07-10-2013, 04:19 PM   #11595
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi,
Exotek caps are designed with an internal ball radius so they mount right up to the stock shock mounts or aftermarket shock mounts;
FYI- new carbon +8mm chassis is in stock!
http://www.exotekracing.com/dex210-8...n-chassis-set/
Thanks!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
