Like Tree26Likes
Old 07-07-2013, 11:30 AM   #11566
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Racedmy 210 for the first time on Wed evening and it worked well. Been practicing a little on my home indoor clay track to get a rough setup and idea on how the car would feel but Wed I took it to a rough indoor dirt/clay mix track with some larger jumps. I changed tires and tried the car out and it worked very well to my surprise. I changed out the shorty pack to a standard pack and the car was even better so that is what I stuck with for the night.
Track was very brutal if you missed the triple jumps and you would pay if you came up short but my STRC 4mm sock towers took it no problem as did my other STRC parts like my motor mount that took a huge shot and nothing happened. The BB shocks took the jumps with no problems. Very happy with the initial setup Ihave on the car. Now Iknow Ihave something pretty good to work with.
Only thing Ihad problems with my front axles if Itightened the screw up too tight and when to take my wheel off the aluminum axle would spin in the stock insert. Very minor issue I will take care of for next time.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-07-2013, 12:45 PM   #11567
DangerCow's Avatar
I have these STRC shock caps:
http://www.amainhobbies.com/product_...k-Caps-4-Black
and these TD aluminum shock mounts:
http://www.amainhobbies.com/product_...ck-Mount-Set-2
on my 210, but I am not sure what to put into the caps for a pivot ball. Anyone else running this combo?
___________________________________________
Axial Scorpion; Exo ../.. Kyosho Turbo Ultima; USA-1
Schumacher CAT K1; Cougar sv2; Cougar KF ../.. Serpent 411 ERYX 2.0
Tamiya XV-01 Pro ../.. Team Durango DEX210; DEX410; DEX408v2
Yokomo B-Max III Factory www.corvictoria.com
DangerCow is offline   Reply With Quote
Old 07-07-2013, 05:17 PM   #11568
Azagar's Avatar
An easy fix for this issue is to apply some locktite to the aluminum axel when inserting it into the axel position insert. Helps get a nice bond on the plastic so you don't have to worry about the insert losing its hold on the axel. Sounds like you will have to replace your position insert though.
DangerCow, you need these.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 07-07-2013, 05:48 PM   #11569
wyd
Tech Legend
wyd's Avatar
I/m going to order some new inserts and then when I put them on I will take your suggestion and ad some Loctite. Thanks
Old 07-08-2013, 03:54 AM   #11570
EvanAZ's Avatar
Trader Rating: 99 (100%+)
you need the pivot balls
http://www.amainhobbies.com/advanced...&x=-174&y=-171
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 07-08-2013, 04:21 AM   #11571
ekt
ekt's Avatar
Could try a bit of fuel tubing, otherwise I'm not sure how you would mount them, do they have some sort of lip to stop it from sliding off a pivot ball?
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 07-08-2013, 08:41 AM   #11572
DangerCow's Avatar
Thanks for the tip on the pivot ball, there are a few of them so I didn't want to collect them all to see what fit. I have used fuel tubing on my crawler but thought it would be out of place here.
Old 07-09-2013, 02:39 PM   #11573
Trader Rating: 2 (75%+)
Thinkin of switching to mm3. For you guys that are running it have any of you moved the shocks to the rear and how did you like it?
durangoman is offline   Reply With Quote
Old 07-09-2013, 03:16 PM   #11574
Trader Rating: 110 (100%+)
Got a dex210 for sale with some goodies on it if anyone is looking for one. Have a f/s thread on it as well. Would trade it for a dest210r or desc210r or sell for $175. Lmk
*MIP/SCTE*
+FTM GRIP+
socal23 is offline   Reply With Quote
Old 07-09-2013, 04:14 PM   #11575
Originally Posted by EvanAZ View Post
yea but with the strc caps its a weird fit. they dont snap in like they do with plastic caps. i went back to stock caps mounted on lunsford titanium shock mounts. i imagine the strc would work well with the stock plastic shock mounts or even the one piece tresrey reds
glenng is offline   Reply With Quote
Old 07-09-2013, 05:01 PM   #11576
Azagar's Avatar
Slight bit of play gleeng? Kinda normal when its double metal like that, my dex408 has the same problem.
Team Durango DEX210
Old 07-09-2013, 05:13 PM   #11577
matt*strike's Avatar
Trader Rating: 41 (100%+)
The strc caps and the tresrey mounts have play. So much that the nut is all that holds it from falling off.
Team Redline O.G.
Alpha Raceway ---Carbondale, IL
matt*strike is offline   Reply With Quote
Old 07-09-2013, 06:24 PM   #11578
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
I wouldn't want my alloy caps to ride on a steel standoff...I think they would need a plastic bushing...personally, I would stick with the stock plastic shock caps unless the alloy replacement came with a plastic bushing.
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 07-09-2013, 06:45 PM   #11579
Next time I rebuild my socks I'm going back to plastic caps
Team Redline O.G.
Old 07-09-2013, 07:27 PM   #11580
Thumbs up
I run the stock plastic for that reason. Tight fit and never had any issues. I have been told that they can separate from the shock bodies but I have had no issues what so ever.
2SlowTC is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
