Like Tree26Likes
Old 07-03-2013, 12:49 PM   #11551
onekiwi's Avatar
Its on their page explaining about all the inserts. Have a look
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 07-03-2013, 01:19 PM   #11552
GregerL's Avatar
GregerL is offline   Reply With Quote
Old 07-03-2013, 01:21 PM   #11553
GregerL's Avatar
Originally Posted by cripplethreat View Post
can someone tell me what degree the front casters are set at on the RTR? I asked durango and they just never reply
I'm not sure what insert it comes installed with, I believe it is the +5, which gives a 25+5 set up. However, the rtr is delivered with all the inserts so it gives you all the options the kit has with 25 +/-5 and 25 +/-10 degrees.
Old 07-05-2013, 07:32 AM   #11554
ClayRacer's Avatar
Hey guys quick update, a Rep from Durango returned my emails. He was willing to send me parts to get me back on the track! I had already ordered the Tresery upgrade however so I thanked him for the kind offer and told him to keep them for someone in need.
Great to see they do care about customers though and the offer was on the table if I had actually needed the parts.
Also there is a new distributor in Hong Kong for Durango and the local shops should be able to restock soon!
Dex210 - SC104X4-FT - TeamC T8E - TeamC T4 FT v3 - AE 12R5.2 - MTS T2 - LC Racing LMB1
TrackStar & Hobbywing Motors - TrackStar & Hobbywing ESCs - Turnigy nanotech batteries all round
Spektrum DX3C - Sanwa M12
JConcepts, Proline, GM, TeamPower, Speedmind & Louise Tyres
ClayRacer is offline   Reply With Quote
Old 07-05-2013, 02:37 PM   #11555
Trader Rating: 2 (75%+)
What manufacturers springs have you guys found to work best?
durangoman is offline   Reply With Quote
Old 07-05-2013, 02:48 PM   #11556
Mxer59's Avatar
Trader Rating: 114 (100%+)
Most you guys running shorty or stick packs?
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 07-05-2013, 03:04 PM   #11557
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
The Durango springs are fine.
Shorty's for sure.
kwiksi is offline   Reply With Quote
Old 07-05-2013, 06:39 PM   #11558
EvanAZ's Avatar
Trader Rating: 99 (100%+)
I run mainly the Durango ones, they have a good range, but I have used Losi to get the in-between wts. that Durango is missing, not much of a difference as far as performance noticed.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 07-06-2013, 06:09 AM   #11559
the losi rear yellow and front orange work good.
ScottZ is offline   Reply With Quote
Old 07-06-2013, 03:19 PM   #11560
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
Default VTS clutch in 210 buggy
I added a VTS clutch to my 210 buggy. Utilizing a Tresrey Associated topshaft, I filed down the flat areas on the shaft to accept the Durango inner slipper plate as I have a TON of TD spur gears to use up. The VTS clutch basket snaps into the TD spurs. The only tricky part is opening up the center hole on the outer pressure plate. I used my drill press to ensure it's centered and Dremel to make a slot for the cross pin. I tested on the extra high grip clay it at SCVRC.
We all know the spur and pinion need to be protected from debris. I took a stock gear cover and removed the center section so the clutch is exposed. While not optimal for outdoor racing, I found it to be perfect for a clean indoor track.
Its amazing how hot a clutch can get in five minuets. Having the clutch basket exposed might be beneficial...
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 07-06-2013, 04:59 PM   #11561
WheelNut's Avatar
Send a message via MSN to WheelNut
Hey guys, I had a 210 kit last year, but I sold it (mistake!). Now I'm thinking about getting another 210, but I'm on a really tight budget (university). Anyone running the 210 RTR? As far as I can tell it is exactly the same as the kit, but it has a gear diff with plastic outdrives and a plastic chassis. The ESC and motor look like they should be enough to race with and the price on the RTR is amazing. Anyone know if the plastic compounds are the same, or if there are any chassis issues with the RTR? I won't be using the stock servo or Tx/Rx.
Cliffnotes: Is the RTR platform any different than the kit? (besides the obvious parts)
•Brad Comis
WheelNut is offline   Reply With Quote
Old 07-06-2013, 05:00 PM   #11562
RC10Nick's Avatar
for those running the type B +8 chassis, I have a question: dimic or dimec20?
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 07-06-2013, 05:39 PM   #11563
EvanAZ's Avatar
The RTR one has a plastic chassis and I suspect the reason they are blowing them out is to make the chassis change to the B (newer stronger plastic one).
The kit has the alum chassis but it is not +8. The outdrives are not plastic, they are steel and have a plastic cap but I took them off after finding they would rub.
I would change the servo out but the SP stuff works fine for stock.
Old 07-06-2013, 05:39 PM   #11564
EvanAZ's Avatar
dimec20
Old 07-06-2013, 06:57 PM   #11565
Hazzmatt1's Avatar
Default Steering
On the stock ackerman/steering plate what are the different adjustments going to do??? I am looking for a bit more steering and was wondering if I moved the ball in or out what exactly it would do for me.
Thxs
Matt
Hazzmatt1 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
