Like Tree26Likes
Old 07-01-2013, 10:08 PM   #11536
rcjunky1's Avatar
are the RF pivot blocks the same/cpmpatible on the spec B?
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 07-01-2013, 11:09 PM   #11537
ekt
ekt's Avatar
The only difference in the spec B RF suspension holder, that I am aware of, is that they have added material so the pivot ball isn't used. The old style ones should fit on the spec B chassis.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 07-02-2013, 05:42 AM   #11538
ClayRacer's Avatar
Next time I order I will get a set, its only $5 it it works I will post photos..
Dex210 - SC104X4-FT - TeamC T8E - TeamC T4 FT v3 - AE 12R5.2 - MTS T2 - LC Racing LMB1
TrackStar & Hobbywing Motors - TrackStar & Hobbywing ESCs - Turnigy nanotech batteries all round
Spektrum DX3C - Sanwa M12
JConcepts, Proline, GM, TeamPower, Speedmind & Louise Tyres
ClayRacer is offline   Reply With Quote
Old 07-02-2013, 06:24 AM   #11539
Trader Rating: 110 (100%+)
I have been looking into buying a new chassis. I have the original alum one right now. I like the rcrd one but itnrequires other parts like the rear hangers to run it. Also looked at the tresery one but it is quite expensive. I'm still not sold on the new or even dimec +8 chassis because of the breaking issues. I have been really looking into the exotek carbon fiber chassis with alum front kick plate. Anyone know a relsese date and and good shares on them? Any input would be great. I'm running mid motor 4 and running a tight med bite indoor track.
*MIP/SCTE*
+FTM GRIP+
socal23 is offline   Reply With Quote
Old 07-02-2013, 06:31 AM   #11540
Trader Rating: 27 (100%+)
Originally Posted by socal23 View Post
..... I'm still not sold on the new or even dimec +8 chassis because of the breaking issues. ......
I have been running the updated chassis (DIMEC20) for several months now to test it for Durango and I have not managed to break one yet. I did break several of the original DIMEC20's.... So, I don't think that breakage should be a concern anymore when considering the DIMEC/DIMEC20 chassis.
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 07-02-2013, 06:32 AM   #11541
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
I personally run the updated "B" chassis/parts on my DEX210 & DESC210R. You won't be disappointed. Durango stepped up to the plate and have fixed the issues.
The changes are quite obvious.
http://www.team-durango.com/part-inf...artNo=TD320247
I will contact Mike about the Exotek stuff.
kwiksi is offline   Reply With Quote
Old 07-02-2013, 07:06 AM   #11542
Trader Rating: 19 (100%+)
+1 to both. The new plastic chassis are very solid. No more breakage concerns.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 07-02-2013, 07:32 AM   #11543
onekiwi's Avatar
Do the original motor guard FR and RR supports work as well as the original front bulkhead.
Or are they other thing you have to buy as well?
What about the optional tresrey bulkheads? Can they be modified to fit?
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 07-02-2013, 08:00 AM   #11544
The existing aftermarket RF hangers will work just as they did before, no modification needed. All aftermarket RR hangers will not work without some machine work, or a dremel if you are comfortable with that (I'm not). Same goes for front bulkheads, some machine work would be necessary to make them work.
Old 07-02-2013, 08:11 AM   #11545
So if your running mid motor with the type b chassis will the RR hanger work?
And the type B chassis is a +8 isn't it?
*MIP/SCTE*
+FTM GRIP+
Old 07-02-2013, 08:47 AM   #11546
Trader Rating: 57 (100%+)
Originally Posted by ClayRacer View Post
Do the Type B parts fit the standard Kit alu chassis ok? (TD320125) or are they ment for the DIMEC chassis?
Attachment 1084920
They're meant for the B chassis but I think it'd work on the aluminum. The motor guard would need spacers or will have some play though.
Here's a post I had in the DESC210 thread with pics. I'm sticking with aluminum for the DEX210.
Team Durango DESC210R
shagino is offline   Reply With Quote
Old 07-02-2013, 08:52 AM   #11547
Correct. MM will work but you lose that nub bumper.
Old 07-02-2013, 12:45 PM   #11548
GregerL's Avatar
I don't believe you hve to have the RDRP rear hanger kit to run the RDRP chassis, that is just if you want to run the LRC option, and the chassis is adapted to be able to retain droop with the LRC option. It should work with the original hangers if you want to keep the stock geometry.
GregerL is offline   Reply With Quote
Old 07-02-2013, 01:17 PM   #11549
j.d.roost's Avatar
Trader Rating: 28 (100%+)
You can run stock blocks on the rdrp +11 (I am).
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 07-03-2013, 11:49 AM   #11550
can someone tell me what degree the front casters are set at on the RTR? I asked durango and they just never reply
cripplethreat is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 Today 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
