Like Tree28Likes
Old 07-01-2013, 04:55 AM   #11521
ClayRacer's Avatar
Originally Posted by joho View Post
This look like lali warehouse in HK, if that's the case, the Tresrey parts works great since you will want less antisquat for that track. I have a setting for that track if you are interest in it.
Hi Joho, good spotting, yes it is Lali in HK, if you have a nice setup I would like to take a look thanks! what front tyres did you run, i'm using JC Rips but would like a little more steering... could be setup though, not had the chance to really get in to this buggy and start tuning with the damn toe block problem.
Originally Posted by GregerL View Post
The tresrey part is great, takes a ton of beating and holds up really well. However I would check out the new spec b hinge pin hangers. They are designed without the pivot balls, and you could also probably sand down a set to get a low roll center option which seems to be interesting for people running on loose surfaces.
Thanks for the heads up GergerL, do you have a link to the new spec B parts? I have not seen those.
Appreciate the help guys, I was getting really bummed out with my Dex210, I have been to the track twice and come home in pieces both times, I like the buggy and I'm sure it will be good once these problems are fixed
ClayRacer is offline   Reply With Quote
Old 07-01-2013, 04:57 AM   #11522
DonRSD's Avatar
Originally Posted by ekt View Post
Here are the wheels that will fit the DEX210.
Front wheels
Rear wheels
As for tires, don't know of any tires specifically designed for onroad buggy use, I just use worn out sets. Any of the 2.2" tires found below will fit.
Front
Rear
Originally Posted by madweazl View Post
These are 2.2s, might be able to fit them up front.
Thanks guys!
Xbox Live: DonRSD
PSN: DonVCorleone
The U - NY Mets - NY Giants - Miami Heat
TLR 22
E-Revo 1/10
DonRSD is offline   Reply With Quote
Old 07-01-2013, 05:38 AM   #11523
ekt
ekt's Avatar
Here's a link to the spec B suspension holders http://www3.towerhobbies.com/cgi-bin...?&I=LXDNUY&P=7
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 07-01-2013, 05:51 AM   #11524
ClayRacer's Avatar
Is the plastic better than the original? its a cheap option but I dont mind the extra couple of bucks for the alu one if it means I can spend a day at the track without my rear end falling apart
Have many people tried the B spec part with success?
Thanks again!
Old 07-01-2013, 06:28 AM   #11525
Trader Rating: 27 (100%+)
Thanks again!
I have been running the B type parts for several months now without any modifications and without any issues.
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 07-01-2013, 06:43 AM   #11526
Hi guys, I have broken this part 2 times in under 3 batteries so I guess its time to upgrade.
Attachment 1084832
I run on a hardpack clay track with a wet and loose top surface. Is the Tresery 2/3 Block a good choice?
Attachment 1084833
Here is a photo of the track conditions.
Attachment 1084831
On that track I would use the brass 0/3 block and if you want more anti squat I would buy the RDRP RR low roll center ones.
I have this setup and it works great on low grip tracks. Can be bought from Amain Hobbies
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
Old 07-01-2013, 06:55 AM   #11527
ClayRacer's Avatar
Do the Type B parts fit the standard Kit alu chassis ok? (TD320125) or are they ment for the DIMEC chassis?
The RDRP ones look intersting but kind of pricey.. I guess i'm still a little miffed that I need to buy these parts just to "fix" the kit lol.
*EDIT - I see you can buy RDRP1903 on its own (I only found the set for $65 before )
Looks like a good option!
Old 07-01-2013, 07:46 AM   #11528
Attachment 1084920
Attachment 1084921
The type b parts are intended for the type b DIMEC/DIMEC20 chassis.
Edwin Hartman
Old 07-01-2013, 08:16 AM   #11529
Attachment 1084920
Attachment 1084921
Im using the RDRP0046 brass RF suspension mount 0/3. For high grip tracks I use the brass 3/3 mount
My collection :
Old 07-01-2013, 08:22 AM   #11530
ClayRacer's Avatar
Thanks everyone for the help, I went ahead and ordered the Tresery toe block and a carbon steering upgrade from TSR products in the US. Lets hope it all works out well.
Dex210 - SC104X4-FT - TeamC T8E - TeamC T4 FT v3 - AE 12R5.2 - MTS T2 - LC Racing LMB1
TrackStar & Hobbywing Motors - TrackStar & Hobbywing ESCs - Turnigy nanotech batteries all round
Spektrum DX3C - Sanwa M12
JConcepts, Proline, GM, TeamPower, Speedmind & Louise Tyres
Old 07-01-2013, 08:39 AM   #11531
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Attachment 1084920
Attachment 1084921
That kinda sucks to change it like they did. I don't mind using the balls for the standard parts. I used this setup on several other brand offroad cars and touring cars with no problems. So now to use the new B parts I have to invest in a new plastic chassis. I will stick with the aluminum one and use the balls instead.
ST Racing Concepts (STRC)
Old 07-01-2013, 08:47 AM   #11532
ClayRacer's Avatar
Yeah, this is why I decided to get the Tresery part, I really just want something thats going to bolt in to the kit I have and I know Tresery parts are ok (used them before). Only bummer is I probably wont get them until the end of July (USA to Hong Kong postage time is not great) but hey thats the way the cookie crumbles.
Old 07-01-2013, 01:07 PM   #11533
GregerL's Avatar
That is true, but are you sure they won't work with the original chassis? I haven't tried it yet but I have the parts at home and was eyeballing it the other day and it looks to be possible. The main dimensions have not been changed, and you should be able to make it work with a spacer or two if you still want to use the original motor guard.
Looking at it I think with a small amount of DIY you could make a cheapo LRC option from the spec B RR hanger.
Anyway, I will have a stab at it next week and report back with my result.
/Greger
GregerL is offline   Reply With Quote
Old 07-01-2013, 09:49 PM   #11534
madweazl's Avatar
/Greger
From what I understand, it looks like the B parts are backwards compatible but I'm not positive.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 07-01-2013, 09:57 PM   #11535
ekt
ekt's Avatar
The spec B suspension holders should work with the aluminium chassis, it's just be the RR holder that you will have to use the old/aluminium version.
Leo Lorenzen
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
