Like Tree27Likes
Old 06-29-2013, 09:49 PM   #11506
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
Oops!!! I forgot about the chassis...
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 06-30-2013, 02:53 AM   #11507
madweazl's Avatar
I ordered the RTR today along with the aluminum servo horn, aluminum steering plate, spare shock towers, and a Reedy Sonic 13.5. A guy at the track recommended Megabites (red) out back so I grabbed a pair along with some JConcepts ribbed fronts (blue). Was looking at setups on PetitRC but couldnt find much for a very small (30x60) dry outdoor track. Any recommendations for initial setup?
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 06-30-2013, 07:24 AM   #11508
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
JC rips in blue look good for that track. May want to get green as well if track temps are cool and or damp/wet. Barcodes look like they would be dialed there as well.
Ran a few packs yest with the B stuff. No durability issues.
What's everyone using for pistons? Anybody using 2-3 hole?
I have new alum chassis and body as well as some other parts I just put in F/S section if anyone is interested.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 06-30-2013, 08:02 AM   #11509
ClayRacer's Avatar
Hi Guys, which ball cups are good replacements for the stock Durango ones? my rear suspension ballcups seem to pop way to easy
*EDIT - never mind, found the post.
ClayRacer is offline   Reply With Quote
Old 06-30-2013, 02:48 PM   #11510
madweazl's Avatar
Temps are 85-90 right now so I didnt think super soft would be a very good match. Not sure how much water it will get. A good sweep and it should be great.
RadioPost
Old 06-30-2013, 03:38 PM   #11511
BS-Racing's Avatar
Im Running 2X1.5 W/ 35WT Oil matched with Green Springs front
and 3X1.5 W/32.5 WT Oil matched with Red Springs Rear... Tons of pack, and very smooth, my favorite set up so far!
B5M
BS-Racing is offline   Reply With Quote
Old 06-30-2013, 07:21 PM   #11512
DonRSD's Avatar
Bought a DEX210 that should be here Wednesday
2 quick questions, if you guys dont mind...
  1. What size is the front & rear hex? I want to buy some ON ROAD tires/wheels and dont know what size to look for.
  2. Does the +8mm chassis make a big enough difference that I should buy one?
Xbox Live: DonRSD
PSN: DonVCorleone
The U - NY Mets - NY Giants - Miami Heat
TLR 22
E-Revo 1/10
DonRSD is offline   Reply With Quote
Old 06-30-2013, 07:28 PM   #11513
BS-Racing's Avatar
14MM Rear and the fronts are Bearing type wheels
And it all depends on what your looking for. Haha sorry if that didnt help
B5M
Old 06-30-2013, 07:31 PM   #11514
matt*strike's Avatar
Trader Rating: 41 (100%+)
I'm running 4 hole pistons
Team Redline O.G.
Alpha Raceway ---Carbondale, IL
matt*strike is offline   Reply With Quote
Old 06-30-2013, 07:42 PM   #11515
DonRSD's Avatar
Not at all lol
Well if Im looking for front tires/wheels, what do I search for?
I just want some STREET tires.
Xbox Live: DonRSD
PSN: DonVCorleone
TLR 22
E-Revo 1/10
Old 06-30-2013, 09:12 PM   #11516
ekt
ekt's Avatar
Here are the wheels that will fit the DEX210.
Front wheels http://www.amainhobbies.com/advanced...&x=-172&y=-165
Rear wheels http://www.amainhobbies.com/advanced...&x=-172&y=-165
As for tires, don't know of any tires specifically designed for onroad buggy use, I just use worn out sets. Any of the 2.2" tires found below will fit.
Front http://www.amainhobbies.com/index.ph...ires-2wd-Front
Rear http://www.amainhobbies.com/index.ph...ggy-Tires-Rear
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 06-30-2013, 09:19 PM   #11517
madweazl's Avatar
These are 2.2s, might be able to fit them up front.
RadioPost
Old 07-01-2013, 01:17 AM   #11518
ClayRacer's Avatar
Hi guys, I have broken this part 2 times in under 3 batteries so I guess its time to upgrade.
I run on a hardpack clay track with a wet and loose top surface. Is the Tresery 2/3 Block a good choice?
Here is a photo of the track conditions.
Old 07-01-2013, 04:39 AM   #11519
joho's Avatar
Attachment 1084832
Attachment 1084833
Attachment 1084831
This look like lali warehouse in HK, if that's the case, the Tresrey parts works great since you will want less antisquat for that track. I have a setting for that track if you are interest in it.
joho is offline   Reply With Quote
Old 07-01-2013, 04:41 AM   #11520
GregerL's Avatar
Attachment 1084832
Attachment 1084833
Attachment 1084831
The tresrey part is great, takes a ton of beating and holds up really well. However I would check out the new spec b hinge pin hangers. They are designed without the pivot balls, and you could also probably sand down a set to get a low roll center option which seems to be interesting for people running on loose surfaces.
GregerL is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
