Durango DEX210 Thread
is there anywhere I can buy the pre drilled pistons in sizes other than 3x1 or 4.1 mm i'm looking for the ones in sizes like 3x1.2or3 and 4x1.2or3
Tech Legend
Trader Rating: 51 (100%+)
My new ones where 4 x 1.0 and I just used a 55 drill bit which is 1.3mm. You could get the 1.0 and use a 56 or 57 drill bil to get 1.2mm or 1.1mm if you wanted to. Mine are Durango tapered pistons. I know Great Planes has them in stock so Tower should have them as well. They also make 1.1, 1.2, and 1.3 x 4
Tech Legend
I think the general consensus is: if you are running on dirt/clay, remove the droop screws and grind off the droop pads from the front bulkhead. Use internal limiters and measure overall length, match shock lengths using the shock end to fine tune length.
If you run on carpet, turf, or cork, use the droop screws.
Tech Legend
nismomike taking 2mm of droop out of the front did help a good amount. Got me even closer to where I wanted to be with such a little change. At least I know that change is just like my touring car would do. Thanks again. Did add a fan to my LRP Flow and put 4 little vent holes in the body and now the speedo dropped about 45 degrees in temp so now that and motor are runnin lower temps with plenty of rip.
Now I will put the alum steering rack on and aluminum servo horn and thats it for tonight.
whats the advantage of running shocks on rear of tower with MM cars?
Im running on front and feel good
Hi guys, Im doing some research on mid motor cars. Can someone explain or point me in the right direction to info on differences between 3 gear vs 4 gear transmition for mid motor.
anybody willing to sell his used stock aluminium schassis main plate ? as long as its straight and not bend. ( for a nice price )
no more +8 and dimec for me
i'm a shaky guy so I doubt I can do it.. could you link me to the 1.2 and 1.3? i would be real grateful.
What is the difference between the Dimec and Dimec20?
Tech Legend
