Like Tree23Likes
Old 06-23-2013, 04:25 PM   #11461
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Anybody know what size thrust balls are in the diff?
kwiksi is offline   Reply With Quote
Old 06-23-2013, 06:05 PM   #11462
j.d.roost's Avatar
Trader Rating: 28 (100%+)
These.
http://www3.towerhobbies.com/cgi-bin...&I=LXATSB&P=FR
and the Jconcepts ballcups made all the difference in the world for me.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 06-23-2013, 11:02 PM   #11463
P6
Originally Posted by durangoman View Post
Any of you guys run into any problems with your motor wire routing when using a c/f rear shock mount? I am running the standard body and my motor wires seem to be holding the body up. I can push it down to get the body clip in but was just a little concerned.
I have the vega camber mount and a cf tower 13g wire no body mounts just velcro on the side pods all four wires through the tower flat against the gearbox I'm not sure the height of the body mount hole but I seem to have enough clearance for my kit or jc body without problems from what I see in the manual
P6 is offline   Reply With Quote
Old 06-24-2013, 09:39 AM   #11464
Heavy B's Avatar
Trader Rating: 18 (100%+)
Default DEX210 For Sale
If interested in a very clean DEX210 go here:
Team Durango DEX210
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
Old 06-24-2013, 07:35 PM   #11465
ApacheRacer's Avatar
Trader Rating: 17 (100%+)
Have a dex210 for sale PM for more info and pics!!
ApacheRacer is offline   Reply With Quote
Old 06-25-2013, 12:49 PM   #11466
Trader Rating: 2 (75%+)
I have seen some guys running the rear shocks on the backside if the shock tower. Any benefits and what parts do I need for the conversion?
durangoman is offline   Reply With Quote
Old 06-25-2013, 01:26 PM   #11467
j.d.roost's Avatar
You can either drill holes for the bottom of the shocks...or flip the a-arms backwards (thats what most do). I also needed a 2mm shim on the bottom of the shock to space it away from the camber link.
I only run mm4 on carpet...and can tell you it's great for that. Car gets more lift and seems less tippy.
I don't know how good it works on dirt.
F1
Roche usa
R.I.P. Jon Williams
Old 06-25-2013, 04:13 PM   #11468
Trader Rating: 41 (100%+)
Rm3 with the arms flipped works great on dirt jd. And for anyone else who wants to know. But like i said in an earlier post i found that the car ran way better setup with short wheel base
2SlowTC is offline   Reply With Quote
Old 06-26-2013, 07:34 AM   #11469
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Just added the Durango 4 x 1.3mm double tapered pistons to my buggy along with the new gold shock shafts and then I already new I wanted lighter oil from when I first tested the car. Took a few laps last night and it felt very smooth overall and took the jumps well with no problems of bottoming out. So I think my oil combo and spring combo are pretty close. Running most of Jorn's setup that I found from the Reedy Race and one other race where he had pretty much the same oil and spring combo. I'm running Dark Green Front springs and Dark Blue rear springs with 30wt front oil and 27 1/2 rear oil. Front has the 30 gram weight with 30 degree caster and longest camber link positioning. Also have the the stock 4mm back setup for the front axle. Middle hole on tower and outer on arm for the shock mounting.
Car has good off power going into the corner but once I get to middle off the corner it don't have a tight finish as it either pushes out or I could use a little overall steering throw (I already have it as far as it can without modding the steering knuckle some). Otherwise in just a few packs I ran it feels really good. Its just minor setup tweaks now. If you have any ideas on the tighter steering coming off or if guys do mod the knuckle some for more overall throw let me know. I have no problems using my Dremel.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-26-2013, 07:43 AM   #11470
wyd
Tech Legend
wyd's Avatar
Originally Posted by 2SlowTC View Post
I ran my car with the shortest wheelbase possible...i.e stock metal chassis and hubs as short as they can go and WOW my dex was amazing except for a broken hub and ball stud(it is a Durango) any way this is all on a outdoor 1/8th scale nitro track that is BIG....just though I'd let you all know. I see a lot of talk about huge wheelbase on these cars. Give it a try
At least on our clay indoor tracks most guys no matter what brand car they run where all switching back to stock length chassis's from the +8 styles that a lot of companies are making. Even when I ran my Tamiya TRF201 the stock length chassis was so much better than the +8. Going really long would seem to make the car more numb feeling overall which would be ok if I was on carpet racing but not as much for dirt or clay. Stability is not a problem with my car as I run it now with the stock alum. chassis. Mine is pretty close to as short as I can make it so far. Feels pretty neutral on the track.
Old 06-26-2013, 08:16 AM   #11471
nismomike's Avatar
What are you running as far as droop/limiters in the front? I don't use the droop pads front or rear, but instead I ground them off the front bulkhead and use 2mm of internal limiters and 1mm in the rear. I am running nearly identical setup in my shocks otherwise. Do you use the 1.5/3.0 rear toe block? Also, how much bump-out do you have at full droop?
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 06-26-2013, 09:40 AM   #11472
wyd
Tech Legend
wyd's Avatar
Right now the droop stops are on and I have full droop at this time. I have 3 degree of rear toe with the 1.5 anti squat. I have very little bump steer in the car right now.
For just starting out with the car it feels really nice and smooth. Takes the small and large jumps equally as well. Rear I have the shocks in middle hole on arm and middle hole on tower.
In the few packs I have run I already feel the car is as good as any car I have ran at our track and that is just with a limited amount of runs. Very happy with the car so far. Zero diff issues (mine has not come loose at all). Going to add an aluminum servo horn and aluminum rack for my steering instead of the plastic one the ball studs mount to. I will do that before I run the car tonight again to see if that changes it a little.
Old 06-26-2013, 09:47 AM   #11473
nismomike's Avatar
I would shorten your front shock length by 2mm. Either using the droop screws or internal limiters. That's gonna give you more on power mid to exit steering.
Old 06-26-2013, 11:08 AM   #11474
wyd
Tech Legend
wyd's Avatar
Thanks. I will certainly try that tonight. Not use to having an offroad buggy that has some touring car adjustments. Lots of learning to do with this car. I'm a little behind and been reading back pages to try to catch up on the info available for this car. Lots of reading left to do thats for sure.
Old 06-26-2013, 11:35 AM   #11475
nismomike's Avatar
I think the general consensus is: if you are running on dirt/clay, remove the droop screws and grind off the droop pads from the front bulkhead. Use internal limiters and measure overall length, match shock lengths using the shock end to fine tune length.
If you run on carpet, turf, or cork, use the droop screws.
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
EbbTide
