Like Tree43Likes
Old 06-11-2013, 05:00 PM   #11386
I just put the Avid slipper in. I will try it on the track this Friday. I put an Avid slipper in my Kyosho SC-R. It works great.
Durango 4wd SC
Kyosho SC-R
Durango DEX 210
Radiopost
PSL Motorsports
coltsfan is offline   Reply With Quote
Old 06-11-2013, 06:45 PM   #11387
Slimsh8t's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Jonny5 View Post
You can use a 12mm hex adapter from the B4 from Yaiba, JC, or Avid to use your existing rears. I'm not aware of any conversion to use the Losi fronts, though you can do a conversion to use AE/Kyosho 12mm fronts using the spindle assembly from the Durango ST/SC and a 12mm hex adapter.
Part #s for the front ?
Thx in advance.
Kevin Murphy
Associated B5m/Reedy
AP Custom Paint/Kal-Gard/
Slimsh8t is offline   Reply With Quote
Old 06-11-2013, 07:42 PM   #11388
Smittydidit's Avatar
Originally Posted by Raul Garcia View Post
Mark
all of the chassis parts are available, through Great Planes. They are in stock. I ordered both DEX210 buggy, and DESC210 truck chassis parts as required. The option blocks are not available. You cannot find the part # by a quick search, the parts are located under the kit replacement parts. I dont know why they cant be found otherwise.
Thanks Raul! I'll give that a try. Was really looking for the new RF and RR blocks to eliminate those freeking pivot balls. Touch a pipe,BAM ! out comes the ball and there goes another R/F block!
Mark Smith
RC8T "CE"--Orion "Truhe"--Hitech--Nitrotane
Tekno 410 -- RX8 -- Pro 4 4600 -- Hitech
Durango DEX 210 -- Reedy Sonic 9.5 -- Hitech
Futaba 4PL--Sponsored by N.S.F (Non spousal funds)
Smittydidit is offline   Reply With Quote
Old 06-11-2013, 09:05 PM   #11389
rcjunky1's Avatar
alloy blocks also solve that VVV
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 06-12-2013, 02:07 AM   #11390
cyclone's Avatar
Hi guys,
Sorry I'm not searching for this info but I'm in a rush!
A) what's the benefit to handling of a +8mm chassis? Also what are the benefits of a std chassis?
B) what is the benefits of a avid slipper clutch?
C) any none kit parts you wish you bought straight away, or could afford?
D) are low profile high speed servos a good choice or do they lack the torque needed? I'm thinking sanwa sdx-801 or futaba bls-551?
E) any advice for carpet running? Tires, or anything I might not know? I've never ran an off road car.
Thanks a lot !
Andy
cyclone is offline   Reply With Quote
Old 06-12-2013, 06:08 AM   #11391
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Originally Posted by cyclone View Post
Hi guys,
Thanks a lot !
Andy
Will chime in on a few.
B-I think the stock slipper works great on carpet. Avid should have more adjustably for dirt/loose surfaces though.
D- a bls551 will work fine...but since you usually add weight up front anyway...I would just use a standard servo. Depending on how big your esc is you might be able to get away with running mm4,esc in battery tray and full size lipo with a l.p. servo...but I have not tried (I might look into this...)
E-I am running Dboots Terabytes in the rear and Schumacher Cut Stagger low profile in the front.
When you get time...search through the thread...Plenty of good info here.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 06-12-2013, 07:05 AM   #11392
RC10Nick's Avatar
Hi guys,
Thanks a lot !
Andy
C) CF rear tower and a good steering rack. I broke 3 towers before I got a cf one and the steering rack broke leaving me unable to race that day.
E) dboots or shumacher mini pins all around. I'd also suggest a gear diff for carpet. You'll also want a pretty stiff spring selection for carpet. And last but not least, be prepared to traction roll alot the first time you run carpet. And of course I almost forgot, run the car in mm4!
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 06-12-2013, 11:48 AM   #11393
gticlay's Avatar
What are the best steering racks "for the price"?
gticlay is offline   Reply With Quote
Old 06-12-2013, 12:05 PM   #11394
Trader Rating: 57 (100%+)
Mark
Great planes but not Tower? I still can't find it in the site yet.
Several different options:
http://www3.towerhobbies.com/cgi-bin...?&I=LXCMXD&P=7
http://www.amainhobbies.com/product_...Steering-Plate
http://www.tresrey-usa.com/tresrey-c...teering-plate/
If you want to save a couple of $, I got an Durango aluminum rack sitting around. $5. Just have to be okay with me packing it in paper and a envelope. Don't wanna have to run to the post office. PM me if you're interested.
shagino is offline   Reply With Quote
Old 06-12-2013, 02:26 PM   #11395
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
good price... great quality (not as cheap as the Durango one on Tower Hobbies though....)
http://www.exotekracing.com/dex210-d...steering-link/
Fishhook
ewashburnaf is offline   Reply With Quote
Old 06-12-2013, 05:14 PM   #11396
mikesed's Avatar
Default trying to save a few bucks
will the avid layshaft ($15) fit AE slipper setup with spurs?
or are the slipper plates different also?
i want to us my B4 suprs but dont want to spend the $$ on the tresrey shaft kit.($30)
mikesed is offline   Reply With Quote
Old 06-12-2013, 10:52 PM   #11397
DangerCow's Avatar
Plus 11mm chassis and Low Roll Centre rear suspension mounts for my 210. Going to try it with mid-motor as this car seems best with more steering than less.
[IMG][/IMG]
___________________________________________
Axial Scorpion; Exo ../.. Kyosho Turbo Ultima; USA-1
Schumacher CAT K1; Cougar sv2; Cougar KF ../.. Serpent 411 ERYX 2.0
Tamiya XV-01 Pro ../.. Team Durango DEX210; DEX410; DEX408v2
Yokomo B-Max III Factory www.corvictoria.com
DangerCow is offline   Reply With Quote
Old 06-12-2013, 11:54 PM   #11398
Hazzmatt1's Avatar
Default RD Steering plate
Glad this came up as I had some problems the other night.
I switched my steering plate to a RD. Day before race I had no issues, or I didn't notice any. However day of race my steering was over rotating during RT turns and locking up. I attempted to compensate with my radio to adjust the throw of the servo but just ended up losing to much steering. Adjusted toe out. Nothing Bump the rail the right way and I locked up. Just to clarify locking to the outside.
Several guys at the track looked at it and they couldn't figure it out either. Ended up switching back to stock and issue was gone.
Did I waste 15 bucks?? or another product I should have got.
Matt
Hazzmatt1 is offline   Reply With Quote
Old 06-13-2013, 07:20 AM   #11399
RC10Nick's Avatar
Matt
Which one? The original or the r2 plate? Looks like the r2 plate was designed to be run with no washers under the steering block ball studs. Perhaps that is your problem? If you're running an original style plate did you make sure to use the same ackerman position? (I know, stupid question, but needs to be asked anyway).
JT RC Products
Old 06-13-2013, 07:30 AM   #11400
Trader Rating: 74 (100%+)
Mark Smith
Ok so I installed my new chassis on my SC. It was super dialed everything worked great. You are able to continue to use the original RF mount if you have a alloy one, bit the RR block has to be modified to use if you want alloy ones to fit. The front bulkhead must use the new plastic ones. The truck drove better than ever last night. For those who are using the +8 plastic chassis you wont be disappointed.
Go to your local hobby shop to order the parts, they will have a GP dealer account, and they can find the parts.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16574 11-04-2017 02:55 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
