Like Tree26Likes
Old 06-10-2013, 09:06 PM   #11371
Smittydidit's Avatar
Default New "B" parts
Originally Posted by Jonny5 View Post
Here you go: http://www.team-durango.com/part-inf...artNo=TD330578
Yep, stock hingepins without the pivot balls. May need a shim depending on what kickup is used.
Thanks for the link! I tried all day to find these new parts here in the states with no luck. Great Planes has no listings for the new numbers. Tower has no listings. I really would like to get this new stuff SOOOO Where Jonny5?? Where can one aquire such parts?? Looking for the new +8 "B"Chassis,Front bulkhead and RF/RR pin blocks and motor guard. The Durango site says these parts are available in the states through Great Planes. Thanks in advance for the info
Mark Smith
RC8T "CE"--Orion "Truhe"--Hitech--Nitrotane
Tekno 410 -- RX8 -- Pro 4 4600 -- Hitech
Durango DEX 210 -- Reedy Sonic 9.5 -- Hitech
Futaba 4PL--Sponsored by N.S.F (Non spousal funds)
Smittydidit is offline   Reply With Quote
Old 06-10-2013, 09:55 PM   #11372
Azagar's Avatar
Making the return back to my 210. I had planned to wait out for a +8 alloy chassis back in December when I broke my dimec20 chassis, unfortunately it turned into a 6month break from everything RC. But i'm finally back, this time with a new Tresrey +10 chassis that was delivered today. Can't wait to get back out on the track, hopefully I haven't forgotten how to drive.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 06-11-2013, 05:35 AM   #11373
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Guys. What 12mm hex will give best fit in front/rear with say AKA front/rear wheels?Have tons of these mounted up and would like to use them.
kwiksi is offline   Reply With Quote
Old 06-11-2013, 06:54 AM   #11374
Heavy B's Avatar
Trader Rating: 18 (100%+)
Look forward to the new chassis, whenever it's available. I noticed right away that the chassis is pre-machined for the 2mm lowered RR hanger. Also, it looks like the rear droop screw stop might be machined as well, that would help with running less anti-squat if you run the shocks to the back. Those are two places I've had to dremel on the current DIMEC chassis.
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
Old 06-11-2013, 06:58 AM   #11375
Heavy B's Avatar
Originally Posted by ekt View Post
I've had this issue too, placing a shim on the layshaft before putting on the slipper plates fixed it.
Thanks for the tip, fixed it right up. Can't believe I didn't think of that??? Glad I asked on here before sending a snarky email to support.
Brian Bernt
Old 06-11-2013, 07:10 AM   #11376
Trader Rating: 19 (100%+)
Mark Smith
As of today, I believe the only place to get them is the TD site. The plus to that is if you order today, you have it tomorrow. The big downside is it's overnight air freight from Europe at a cost of $50.
I would expect them to be in stock at Tower very soon, which will be much cheaper than an overseas order.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 06-11-2013, 08:09 AM   #11377
cyclone's Avatar
Hi guys are the durango wheels the only ones that fit the dex 210?
Thanks!
cyclone is offline   Reply With Quote
Old 06-11-2013, 08:22 AM   #11378
Trader Rating: 27 (100%+)
Thanks!
DE makes wheels that fit the DEX210 as well:
http://www.deracing.net/store/index....y&path=149_166
I personally only run the TD wheels and they hold up very well.
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 06-11-2013, 10:32 AM   #11379
gticlay's Avatar
I have a ton of Losi wheels/tires I'd like to use... any conversion parts out there? Having a difficult time finding info on that. Thanks!
gticlay is offline   Reply With Quote
Old 06-11-2013, 10:35 AM   #11380
You can use a 12mm hex adapter from the B4 from Yaiba, JC, or Avid to use your existing rears. I'm not aware of any conversion to use the Losi fronts, though you can do a conversion to use AE/Kyosho 12mm fronts using the spindle assembly from the Durango ST/SC and a 12mm hex adapter.
Old 06-11-2013, 12:07 PM   #11381
Thanks for the response. I guess I'll just have to suffer with the original +8 untill the new stuff is available
Mark Smith
Old 06-11-2013, 12:54 PM   #11382
Trader Rating: 74 (100%+)
Mark Smith
Mark
all of the chassis parts are available, through Great Planes. They are in stock. I ordered both DEX210 buggy, and DESC210 truck chassis parts as required. The option blocks are not available. You cannot find the part # by a quick search, the parts are located under the kit replacement parts. I dont know why they cant be found otherwise.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 06-11-2013, 03:38 PM   #11383
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Anyone try to mod the AVID Triad slipper on their Rango?
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 06-11-2013, 03:40 PM   #11384
Trader Rating: 110 (100%+)
I just bought the avid lay shaft and gear cover combo when I orderd the triad slipper set up.
*MIP/SCTE*
+FTM GRIP+
socal23 is offline   Reply With Quote
Old 06-11-2013, 03:41 PM   #11385
EvanAZ's Avatar
Thanks, I just found it.
http://avidrc.com/product/5/accessor...cessories.html
Gonna do mine also.
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
