Like Tree26Likes
Old 06-09-2013, 04:55 AM   #11356
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Originally Posted by EvanAZ View Post
Well since I can't use my Alum. bling on the new chassis, can anyone running the RDP +11 chassis chime in?
I'd like to know if the +8 body fits and also if there is much of a performance difference over the +8.
1st actual full race night yesterday with the +11. Qualified 2nd finished 2nd to the local ace who runs a Losi. With only one pack of practice on a new layout..I was able to qualify on the same lap (usually a lap down) and was only a tenth + or two off his best lap times. The car is just better with the +11 over the prior dimec +8. That being said..I am going to pick up the new one to test out. The 1st run of the dimec chassis was too flexible in the wrong spots.. Looks like they really put some time into resolving the issues they were having (thanks TD).
I need to work on my shock package. Car was great 1st half of the race (was out front for a few laps)...but got very bouncy and traction rolled about 3 min in. Not too sure what is causing this issue..but it's coming from the back of the car.
Car is in mm4 setting.
My bulldog body fit right in place over the +11 chassis. I just had to elongate a body mounting hole.I would assume the Durango body would as well.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 06-09-2013, 08:23 AM   #11357
platgof's Avatar
Do you have your shocks on the rear?
platgof is offline   Reply With Quote
Old 06-09-2013, 08:32 AM   #11358
RC10Nick's Avatar
looking at this drawing, you can see the new RR hanger is needed for the rear bumper in rm configuration. looks like those of us who run mm can get away with the old aluminum rr hanger from the kit
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 06-09-2013, 10:22 AM   #11359
j.d.roost's Avatar
Yes.
F1
Roche usa
R.I.P. Jon Williams
Old 06-09-2013, 12:03 PM   #11360
GregerL's Avatar
Hi all
We run this car in Sweden, and we tend to run quite a lot on high grip tracks and it works great in those condotions. However, when running RM on low grip tracks I seem to be struggeling for rear grip, mid corner, on throttle. I can play with most settings of the car and understand which way to go most of the time, but I get a lot of different input regarding rear anti-squat.
One explanation I've read is: "Less anti-squat gives more rear grip since it will squat more and transfer weight to the rear under acceleration."
But I have also read: "More anti-squat will increase the chassis' resistans to squatting, hence putting more pressure on the rear tires and increasing grip"
i have tried looking at diffent set-ups at Petit, and they are a litle bit all over the place regarding this.
So if I am looking for more rear traction do I go up or down from 1,5 degrees anti-squat? What is the general verdict with the 210?
Any help and input is much appreciated.
/Greger
GregerL is offline   Reply With Quote
Old 06-09-2013, 03:28 PM   #11361
GregerL's Avatar
Originally Posted by socal23 View Post
So I have a question. I'm still new to ball diffs. I picked up a used dex210 and the guy said the diff was fresh and after I got it he said he wasn't sure to just run it and find out for myself. Well I swapped everything from rm4 to mm4 and put it all together. I tried to get the diff to break in but after starting up the car I kept tighting the diff till I got to the barely forward rotation. Well finnly got it set with the wheels off and the diff screw was way out to get to that point. Was barely tight enough to not be able to hold the axle with my fingers. And as I was doing all thisnote the slipper was about 2 turns from locked. Well as I pur the tires on to do the rotations it seemed like the slipper was really loose BC I set the car on the floor and it diddent move.........
It might be the circlip that is popping out of its groove, have a look at this link:
http://www.petitrc.com/setup/durango...ialBuildGuide/
I have replaced the Durango circlip with an Xray one, the stock ones are quite weak.
/Greger
Old 06-09-2013, 05:00 PM   #11362
P6
Does anyone have a type a dimec for sale the older or rtr version
P6 is offline   Reply With Quote
Old 06-09-2013, 05:03 PM   #11363
new chassis + new hanger + misc, it's an $50+ upgrade.
Why can't durango just come out with the +8mm aluminum chassis? you know, the one Jorn Neumann has been using for over an year.
nicholasxuu is offline   Reply With Quote
Old 06-09-2013, 05:40 PM   #11364
RC10Nick's Avatar
i understand where you're coming from and I agree, but i actually prefer to have a lighter dimec chassis vs an aluminum one. it is pretty stupid, though.
JT RC Products
Old 06-09-2013, 06:18 PM   #11365
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
I have a Dimec20 Brand new. PM if your interested.
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 06-09-2013, 07:31 PM   #11366
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Anyone weight the alum. +8 or +11 over the Dimec +8?
Also is Amain the only U.S. seller of the RDP +11, there out of stock.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 06-09-2013, 08:20 PM   #11367
j.d.roost's Avatar
Agree..it's not wise to put all of your eggs in one basket...but
Rdrp has a big batch heading towards A-main right now (according to f.b.).
I would assume with such a high demand Amain will bulk up on stock...unless they know something we don't (like a new dex coming out ect..).
F1
Roche usa
R.I.P. Jon Williams
Old 06-10-2013, 07:34 AM   #11368
Heavy B's Avatar
Trader Rating: 18 (100%+)
I run the DIMEC+8 with the TD 30oz brass nose weight. I was running about that much weight with the aluminum chassis, but when I switched to the DIMEC (not DIMEC20 as they have been sold out) I went with the TD custom made one. They have 15oz & 30oz and they fit perfectly.
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
Old 06-10-2013, 08:16 AM   #11369
Trader Rating: 19 (100%+)
Originally Posted by GregerL View Post
Hi all
/Greger
The answer is both... lol. More anti squat will have less side bite (more rotation near the apex), but will accelerate harder exiting the corner. On lower grip tracks, the tradeoff is that it will be less stable accelerating over a long straight. Less anti squat will have less initial bite exiting a corner, but will allow more weight to be transferred as you accelerate down a long straight. I ran a loose track last week where I struggled to get over a double consistently, so I added anti squat. I could make the double every lap then, but it required more finesse on the track's two straightaways to keep it straight. I had run less anti squat the previous time at the same track and while it was more stable at high speeds, I couldn't get out of the corners as well. In that case, more anti squat was faster.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 06-10-2013, 03:13 PM   #11370
GregerL's Avatar
Thank you Jonny5, that clears it up for me a lot.
/Greger
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
EbbTide
