Like Tree43Likes
Old 05-29-2013, 07:17 PM   #11236
heavy B do you use light red or dark red springs?
ScottZ is offline   Reply With Quote
Old 05-30-2013, 09:45 AM   #11237
mikesed's Avatar
Trader Rating: 39 (100%+)
Default capture
im running full capture camber links to avoid any ballcup issues.
it is working great. am i missing something by do it it this way. and why are more people not going this route. should i go to ballcups?
mikesed is offline   Reply With Quote
Old 05-30-2013, 10:06 AM   #11238
Trader Rating: 29 (100%+)
I guess it works but that looks like it raises the camber link 4 or 5mm on the shock tower.
I put on the Lunsford set and have not had 1 pop off.
Now my DESC210 has the stock ball cups on them, and I built them the same way as I did on the buggy and I have yet to pop one of them off.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 05-30-2013, 10:28 AM   #11239
mikesed's Avatar
it is set up equal to 2mm of ballstud rise.
no other issues i should worry about?
Old 05-30-2013, 10:46 AM   #11240
The only other things I would kind of be concered about are the C hubs, and the shock tower. They are now your weak points, instead of the ball cup popping it may break the hub or shock tower.
Thats just my .02
Old 05-30-2013, 10:57 AM   #11241
I bought the RTR kit can someone please tell me how to add reverse? I am in a wheelchair and practicing at the track by myself sucks because if I hit the tubing i'm screw till someone can help me!
cripplethreat is offline   Reply With Quote
Old 05-30-2013, 11:02 AM   #11242
Trader Rating: 57 (100%+)
Sorry, you need a different ESC. My wife has a RTR and I had to replace it just because of that.
shagino is offline   Reply With Quote
Old 05-30-2013, 11:09 AM   #11243
Heavy B's Avatar
Trader Rating: 18 (100%+)
Light red all the way around, sometimes black rear if it get a little ass slappy.
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
Old 05-30-2013, 11:14 AM   #11244
Jochim_18's Avatar
Originally Posted by shagino View Post
Another option:
Tresrey Forum
Is that associated axle or Durango?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 05-30-2013, 11:17 AM   #11245
Jochim_18's Avatar
Originally Posted by Khador12 View Post
I have been using the avid 12mm hexes. This pack has two wide and two narrow hexes another option for track width.
Are using stock Durango axle?
Old 05-30-2013, 02:11 PM   #11246
Last question for a while I hope. What is the Stock Gearing for the RTR and what is a good start gearing for someone who is terrible at racing and just wants to get used to being able to get around the track fast but not lightening fast. 13.5 motor!
Old 05-30-2013, 02:47 PM   #11247
Jochim_18's Avatar
I suggest 87/27 just turn down your radio till you get use to it.
Old 05-30-2013, 04:52 PM   #11248
theclutch's Avatar
Originally Posted by LoudOne View Post
Finally took a few shots of my DEX210... Ended up being my most expensive build yet... Exotek, Revolution Designs, LRP X-20 9.5 motor, Tekin RS esc... Paint by Larry at Kustom RC Graphics...
Does this body fit RM4 configuration?
XRAY XB2 2018, XRAY XB4 2017, Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 05-30-2013, 06:02 PM   #11249
Originally Posted by glenng View Post
rdrp makes aluminum zero degree caster inserts for the front c hub for like 6 bucks from amain which gives you overall 25 degree.
rdrp makes a new steering plate (r2) which changes the position of inner steering link attachment.
Thanks for the info on the 0 degree inserts. About to order them.
How do you like the steering plate someone mentioned not liking them compared to the tresrey cf rack a few pages ago but never said why.
RDRP is quickly becoming a favorite of mines.
Durango. I just got a DEX210 with JConcepts hex's on them. So that works also.
Originally Posted by SCT4TEN View Post
Haha. You did the same thing I did
Old 05-30-2013, 08:11 PM   #11250
Khador12's Avatar
Yes, and they have stock track width
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16581 Yesterday 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
