Like Tree43Likes
Old 05-25-2013, 07:39 AM   #11206
SKIMAN's Avatar
Trader Rating: 17 (95%+)
Default question
Is anyone running the shocks in the rear config. that are still using
standard chassis and rear motor config? Just wondering if they noticed
any benifits or not really. was thinking about swapping the shocks to the rear.
thanks for any input.
We didn't lose the game; we just ran out of time.
Vince Lombardi
SKIMAN is offline   Reply With Quote
Old 05-25-2013, 07:51 AM   #11207
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
I am running rm4 with flipped arms, shocks to the rear. I noticed an immediate difference in stability. Buggy seems more settled overall.
James Cooper
SouthernFriedRacing
[email protected]
SOuthernFRIED is offline   Reply With Quote
Old 05-25-2013, 08:07 AM   #11208
RC10Nick's Avatar
Are you using the standard or a long chassis?
I would think for a mid motor configuration, you'd want the rear tires as close to the center of mass as possible to get more weight and therefore more traction on the rear wheels. Unfortunately this means keeping the wheelbase shorter. It's sort of the opposite for rear motor configurations. Pushing the rear tires back even further will help get the mass from the motor closer to being inside the wheelbase, thus reducing the pendulum effect.
Do you feel you have more or less rear traction after doing this mod? My thought process tells me you would have less, but then again the difference may be insignificant.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 05-25-2013, 08:36 AM   #11209
I am using the standard chassis. I haven't run mid-motor mainly because I run on outdoor loose dirt. You are correct in thinking in RM configuration the longer you make the wheelbase the more traction you gain. You also gain more stability when jumping. The trade off is, the longer you make something the more difficult it is to turn. I feel like I have better traction in my current configuration with the stock length chassis. Rear motor 4, flipped arms, and I have the hubs all the way to the rear. This is the longest possible wheelbase you can gain from the stock length chassis and it gives a very stable ride. After I swapped the arms and shifted the hubs the buggy became easier to drive out of corner's and i noticed it was more consistent going over jumps. I found I was less worried about lining everything up perfectly.. The buggy became more forgiving.
James Cooper
SouthernFriedRacing
[email protected]
Old 05-25-2013, 03:33 PM   #11210
LoudOne's Avatar
Trader Rating: 31 (100%+)
Finally took a few shots of my DEX210... Ended up being my most expensive build yet... Exotek, Revolution Designs, LRP X-20 9.5 motor, Tekin RS esc... Paint by Larry at Kustom RC Graphics...
Kyosho RB6.6, ZX6.6
Serpent SRX2 MM
X-RAY XB4 (2013), XB2 Carpet (2017)
Schumacher KF2
LoudOne is offline   Reply With Quote
Old 05-25-2013, 04:37 PM   #11211
godofcable's Avatar
Trader Rating: 37 (100%+)
looks sweet!
you should build a 1/8 E Buggy, where the build can EASILY reach $1200
www.rcsoup.com - R/C Reviews, News, and Tips <<- PM Me if you'd like us to feature your product
godofcable is offline   Reply With Quote
Old 05-27-2013, 07:36 AM   #11212
Trader Rating: 57 (100%+)
Originally Posted by Heavy B View Post
Hope that helps with some discussion....
Thanks. It did.
What are you using from RDRP? Can't see in the pic. Spent all that and stuck with the stock chassis?
shagino is offline   Reply With Quote
Old 05-27-2013, 08:23 AM   #11213
onekiwi's Avatar
towers and by the look all the shock stuff you can get,
caps
retainers
preload
mounts
bottom caps
thumb screws
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 05-27-2013, 08:32 AM   #11214
Ah. Thought a lot of that was actually exotek stuff.
Old 05-27-2013, 09:56 AM   #11215
onekiwi's Avatar
ah sorry your right
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 05-27-2013, 11:24 AM   #11216
LoudOne's Avatar
Originally Posted by shagino View Post
Thanks. It did.
RDRP are the Thumb screws, preload adjusters and the round side mounts... Everything else is Exotek... Can't say I'm an experienced enough driver to spend $$$ on a new chassis and notice a difference.. I think the stock chassis is just fine... It's one of the reasons I bought this car...
Kyosho RB6.6, ZX6.6
Serpent SRX2 MM
Schumacher KF2
Old 05-27-2013, 11:58 AM   #11217
RI think the stock chassis is just fine
It absolutely is. Just seems like a lot of folks(myself included) upgrade the chassis quickly. Since you dropped a lot of coin on this, I'm just surprised that one didn't get you
Old 05-27-2013, 10:29 PM   #11218
Default RDRP LRC KIT
anyone have any feedback on the lrc mounts for rm configuration? if so what chassis was used and what mount? thanks in advance.
glenng is offline   Reply With Quote
Old 05-27-2013, 10:45 PM   #11219
rcjunky1's Avatar
So I'll be getting a wrap for my buggy done by Mick at rctagz.com, so if anyone wants a wrap for there buggy, we'll have the die lines for the durango +8mm body in the near future. A local has one of his wraps already and it looks like good stuff, I look forward to getting mine in the near future (well, probably end of June as he needs a body to copy and that won't be in for another couple weeks)
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 05-28-2013, 01:57 AM   #11220
SCT4TEN's Avatar
~LRH Hobbies/Raceway Lrhhobbies.com
Td DeX408|NovaK Active8 2650 *Airtronics|m12
Kyosho zx5 Lrp 6.5
SCT4TEN is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16581 Today 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
