Like Tree26Likes
Old 05-22-2013, 03:35 PM   #11191
platgof's Avatar
I hate to ask again, but, can the stadium truck chassis fit this, and would it help?
platgof is offline   Reply With Quote
Old 05-22-2013, 05:29 PM   #11192
8ight-e's Avatar
Trader Rating: 57 (100%+)
it would bolt up if you found a body to fit... but why? Get one of the available +8 +10's out there already.. stick w/ the aluminum as well iMO. I like them better in all conditions.. just my 2c though
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 05-22-2013, 05:50 PM   #11193
Trader Rating: 74 (100%+)
I have used the truck chassis on my 210. I used a modified +8 body. The car was too long it didnt drive very well.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 05-23-2013, 06:32 AM   #11194
Smittydidit's Avatar
Default +8 Chassis
Hey to all, Can anyone verify if the RTR comes with the +8 chassis already installed. I watched some video review and the guy says it comes with the +8 on it? Also,If you go to the Durango site and look up standard replacement parts it does not show the stock chassis # that is in the manual, only the +8?? I recently picked up the RTR and dropped a Reedy Sonic 9.5 in it, did my set up and and I'm having a blast with it. Takes me back to 84 when I used to race the gold pan RC10!
Smitty
RC8T "CE"--Orion "Truhe"--Hitech--Nitrotane
Tekno 410 -- RX8 -- Pro 4 4600 -- Hitech
Durango DEX 210 -- Reedy Sonic 9.5 -- Hitech
Futaba 4PL--Sponsored by N.S.F (Non spousal funds)
Smittydidit is offline   Reply With Quote
Old 05-23-2013, 06:36 AM   #11195
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Smitty
yes the RTR has the +8 chassis.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 05-23-2013, 06:39 AM   #11196
Thanks for the info! Really like the way this buggy works
Smitty
Old 05-23-2013, 06:40 AM   #11197
honda_stuntboy's Avatar
Trader Rating: 30 (100%+)
If any of you guys are having trouble with breaking the ears on your tranny case that hold the ball stud, check out my brace. Haven't broke one since. Works on all configurations. Fits under the inner ball stud. 1.4mm thick. Braces and skids
Check out my website at www.sumo-racing.com, like us on Facebook, or follow us on Twitter. Thanks, Terry.
honda_stuntboy is offline   Reply With Quote
Old 05-23-2013, 08:53 AM   #11198
DangerCow's Avatar
Just ordered one! Thanks!
___________________________________________
Axial Scorpion; Exo ../.. Kyosho Turbo Ultima; USA-1
Schumacher CAT K1; Cougar sv2; Cougar KF ../.. Serpent 411 ERYX 2.0
Tamiya XV-01 Pro ../.. Team Durango DEX210; DEX410; DEX408v2
Yokomo B-Max III Factory www.corvictoria.com
DangerCow is offline   Reply With Quote
Old 05-23-2013, 07:50 PM   #11199
8ight-e's Avatar
You should make that with a weight kit or make it in a few weights... just a thought
Tekno ET48, EB48.2
Old 05-23-2013, 10:37 PM   #11200
nismomike's Avatar
Have not seen much talk about the dual tapered pistons, but I have been running them on a few different tracks and I'm sold on them! I got the 4x1.0 pistons and I kept my entire setup the same aside from
: front pistons were stock 4x1.3, switched to 4x1.2 Dual tapered
: rear pistons were stock 4x1.4, switched to 4x1.3 Dual tapered
My buggy has more pack and lands better, but feels ultra glued to the track. I have better exit steering now, the rear rotates like a dream and squares up as soon as I punch the throttle coming out of the corner. I had a really great setup prior to the piston change, but wanted more pack without sacrificing rear sidebite/roll. I switched to the 2x1.6 pistons but my buggy seemed lazier and didn't change directions as aggresively without trying to wash out. I am really happy with the DS pistons and plan to put them in my DESC210 as well. Hoping for the same results.
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 05-23-2013, 10:42 PM   #11201
Oil ?
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
Old 05-23-2013, 11:29 PM   #11202
nismomike's Avatar
Originally Posted by ridgeracer View Post
Oil ?
I have 35wt fr dark green spring, and 32.5 rr dark blue spring.
But if your setup is pretty good already, the only change I would recommend is .1 smaller piston holes front and rear with the Dual taper. Then just run it. I have ran them on 2 different indoor med bite clay/dirt tracks, and at SRS outdoor loamy med bite.
Old 05-24-2013, 05:35 AM   #11203
4x? I thought most if the stock pistons were 6x.
Can someone school me on shock piston hole size vs displacement? What's the difference between 6x1.0/5x1.2/4x1.5/3x2.0?
Could NismoMike's handling change be due to the displacement area rather than dual taper?
On a similar note, would there be a difference between running these spur/pinion combinations? 69/23 and 81/27. Both ratio at 3.0.
Good idea. I wouldn't want to buy more than one though May also want to consider moving the sumo name to the sides, can't see it when it's installed.
shagino is offline   Reply With Quote
Old 05-24-2013, 07:04 AM   #11204
Will try. I use single taper 4x1.4 front and 4x1.3 rear now. Driving on a bumpy track with big jumps
My collection :
Old 05-24-2013, 10:04 AM   #11205
Heavy B's Avatar
Trader Rating: 18 (100%+)
Who use the stock pistons?
Resistence (I think that's the right word), the smaller the hole, given the same surface area of displacement, the more pack & static dampening. It would be nice to have a conversion table, but a 6x1.0 would feel like a 3x1.4 (just an example, don't hold me to the exact numbers). Even though the 3-hole piston has a smaller displacement, the rate at which the fluid moves through the piston is similar.
The larger the spur, the more torque to the tranny. If you are on a loose surface, the 69 spur would be better as it has less torque and would result in less wheel spin. Also, the spur size will help you position the motor forward and backward which has an impact on the pendulum effect of a RM car and weight positioning of the motor.
Disclaimer: I'm not Bill Nye the science guy, nor an engineer or physicist, but that is what I've learned through years of experience.
Hope that helps with some discussion....
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
