Like Tree26Likes
Old 05-04-2013, 08:38 AM   #11071
Hey guys I'm curious what you all are running for steering epa? I made a custom rack I used for a long time so I could use 100-120 spa without the wheels locking out after stripping 2 servos in a week or two. Now I want to try to use the factory shaped rack since I bought the truck and don't think my custom rack is going to hold up with the bigger tires of the truck. I'm down to around 60-70 on my buggy with the factory rack which makes the steering a little twitchy and I believe caused my servo issues. I don't want to strip any more servos. It seems everyone else figured this issue out so hopefully you guys have some suggestions, thanks.
AMorgan is offline   Reply With Quote
Old 05-04-2013, 08:50 AM   #11072
Trader Rating: 39 (100%+)
i need blank pistons who makes them and a part number please!for big bores
DR.Vanostrum is offline   Reply With Quote
Old 05-04-2013, 10:05 AM   #11073
AP3XMONK3Y's Avatar
Originally Posted by P6 View Post
since i went to taper pistons im at 1.2x4 f/r with 25wt ae f/r i have tons of grip and my buggy feels very responsive the springs i choose depended on my weight im at 1585g with a 10.5t no boost but it feels very light on the track almost enough to wheelie and geared up for the long straights i may have problems when warmer temps hit this summer tho... a stiffer front spring will make it more responsive also
Do u have to make this piston or can u buy them made. I've only found the1.0x4
DEX210,Hobbywing,futaba,revtech,jconcepts
DEX410V3,Hobbywing,futaba,revtech,jconcepts
s350 bk1 evo
AP3XMONK3Y is offline   Reply With Quote
Old 05-04-2013, 10:08 AM   #11074
nismomike's Avatar
The piston parts tree should come with blanks as well. The last couple times I bought them I remember getting blanks.
But Tresrey also offers them and I hear they are really good.
Here is the link.
http://www.tresrey-usa.com/tresrey-m...piston-blanks/
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 05-04-2013, 12:07 PM   #11075
Trader Rating: 57 (100%+)
Finally broke a gearbox camber mount. What a pain to change! I have the tresrey cf camber mount but never put it on.
TD330157
Comes with 4 blanks. A buck or two cheaper than Tresrey. I use these.
Earlier versions if this part are all drilled but it was changed at some point in time.
shagino is offline   Reply With Quote
Old 05-04-2013, 12:32 PM   #11076
Are you sure everyone i have seen has them all drilled, i think the last three numbers of tree is 157???
Old 05-04-2013, 12:45 PM   #11077
gticlay's Avatar
So, what is the best aluminum steering system?
gticlay is offline   Reply With Quote
Old 05-04-2013, 12:49 PM   #11078
There are two versions that have the same part number. 330157. Just look at them when you're at the track dude
I ordered them from Tower and A Main. Both came with blanks. I've also seen the set that's all drilled though. Thrown in with a used buggy.
Old 05-04-2013, 02:22 PM   #11079
onekiwi's Avatar
Anyone tried the tresrey or highest servos?
Whats your thoughts?
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 05-04-2013, 09:49 PM   #11080
P6
I bought the 4x1.0 single taper and a gmk whole thing drill set I planed on closing two holes for indoor but outdoor season is coming so I'm just gonna keep this setup
P6 is offline   Reply With Quote
Old 05-05-2013, 06:03 AM   #11081
platgof's Avatar
Has anyone tried a gear diff in these? I also need to find an aluminum steering horn and need suggestions on what to get. I am having a problem going sideways on all my 210's (buggy, truck, and sc.) Is there a way to lesson this? It goes from worse with the buggy to not so bad with the sc.
platgof is offline   Reply With Quote
Old 05-05-2013, 06:17 AM   #11082
RC10Nick's Avatar
I have a geardiff in mine and like it. However, I don't think that will fix your problem with going sideways.
If you're going sideways (spinning out in middle of turns?), i'd look at your tires, then your springs, then your camber/link settings.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 05-05-2013, 06:36 AM   #11083
its all in your diff set up i got an b-fast biff and it never spins out if anything pushes.
ScottZ is offline   Reply With Quote
Old 05-05-2013, 06:50 AM   #11084
Trader Rating: 21 (100%+)
I run a gear diff in both my dex and desc. You'll get a ton of advice in here and most of it doesn't work. Did you try moving the battery as far back as possible?
On my desc I run mm4 so I need weight in the back. On my dex I run rm3 and I use a shorty pack pushed all the way forward.
Try simple things first, like moving the battery around, ride height, tires, etc.
mulepic is offline   Reply With Quote
Old 05-05-2013, 09:09 AM   #11085
P6
im using the sc10 gear diff with 1000cts ae oil and i went to a stiffer front spring and added a little rear droop to fix my sideways problem it was more of during braking or a sharp turn my front would dig then kick the rear out lifting the inside tire all is good now tho i couldnt be happier next step is a longer chassis im still using the kit alum
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
