Like Tree31Likes
Old 04-19-2013, 01:32 PM   #10921
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I know they have a front 12mm hex conversion with the Kyosho parts but I thought I heard of one using the Losi front axle and the DESC210 steering knuckle. Anyone heard of this one.
ST Racing Concepts (STRC)
Old 04-19-2013, 01:35 PM   #10922
You can use the DESC front assembly and just put a 12mm hex on it. Some index washers would be needed.
DESC410V2 TEKIN RX-8 PRO 4 4000
DESC210 TEKIN RS 10.5 NOVAK
DEX410V3 TEKIN RS PRO 6.5 NOVAK
DEX210 TEKIN RS THUNDER POWER 13.5
jonsee is offline   Reply With Quote
Old 04-19-2013, 05:58 PM   #10923
Trader Rating: 24 (100%+)
Anybody try a straight pin conversion on the rear?
thefnshow is offline   Reply With Quote
Old 04-19-2013, 10:09 PM   #10924
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
A straight pin with no hex?
If you shimmed the axle for a little side to side play, you could run an older style pin drive wheel if you found one that sits tight on the axle as to have no run out. If the wheel isn't tight on the axle, it would most likely wobble as it rotated.
I assume you have some older wheels you want to run on your car?
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 04-19-2013, 10:45 PM   #10925
i have some jconcepts rulux wheels brand new from my cat sx3 that i would like to use
Old 04-19-2013, 11:01 PM   #10926
Trader Rating: 19 (100%+)
You can use the pin drive setup off of the original DEX410 with a shorter pin. You'll need the cone washer and wheel distance bushing, and possibly a few shims.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 04-19-2013, 11:16 PM   #10927
wyd
Tech Legend
wyd's Avatar
Ok. I will check it out. Thanks
Old 04-20-2013, 09:30 AM   #10928
RC10Nick's Avatar
Oh man, don't tell me you got a dingo!
I hear it works really well at bumps in mid motor!
If you really are getting a dex210 I think you'll like it. There's plenty of stuff to tweak and try out that I'm sure you'd appreciate. Personally, I'm switching mine back to mid motor. I was faster with mid than rear. I just gotta figure out how to squeeze out a little more traction.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 04-20-2013, 09:38 AM   #10929
wyd
Tech Legend
wyd's Avatar
Hey Nick it is true I will have one in a week or so. I'm actually testing a new line of hopups from STRC. Can't wait to get it all ready and run it on the track at Bumps. Going to get a good amount of time in so Ican really test out all the new parts. Going to concentrate more on buggy this fall instead of SC like I mainly run.
Old 04-20-2013, 09:54 AM   #10930
Trader Rating: 41 (100%+)
This is my 12mm hex mod. Works great. Its using rb6 axles
2SlowTC is offline   Reply With Quote
Old 04-20-2013, 09:59 AM   #10931
RC10Nick's Avatar
Nice! What kind of hoppups? Ive been thinking about a new chassis lately.
JT RC Products
Old 04-20-2013, 01:38 PM   #10932
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Guide to front hex setup
http://www.petitrc.com/setup/durango...0_FrontHexMod/
nolimit208 is offline   Reply With Quote
Old 04-21-2013, 09:24 AM   #10933
P6
what shims fit the axles and what about a crush tube im trying to eliminate any bearing failure from the play and bending the pins ? thanks
P6 is offline   Reply With Quote
Old 04-21-2013, 02:01 PM   #10934
F11972's Avatar
Trader Rating: 18 (100%+)
I was thinking about turning my 210 into a dirt oval car. Has anyone done this? If you have, what parts did you use? Thanks
F11972 is offline   Reply With Quote
Old 04-21-2013, 11:04 PM   #10935
Jochim_18's Avatar
I just purchased the tresrey +10 chassis anyone have more information how the feels with this chassis?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
