Like Tree43Likes
Old 04-15-2013, 11:59 AM   #10891
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
most do 3 gear unless your on a really loose track then you run 4 gear for more traction, but most conditions 4gear is too much rear traction
nolimit208 is offline   Reply With Quote
Old 04-15-2013, 12:13 PM   #10892
Jochim_18's Avatar
Adding a little more traction certainly won't hurt at all
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 04-15-2013, 12:19 PM   #10893
Jochim_18's Avatar
I have read few pages back lowering roll center on this car is by adding shims inside by the bulkhead is this correct?. When I look at the camber link angle of the car removing shims inside will lower the roll center on the rear, But somehow when I remove shims on the inside link by the rear bulkhead I had the oppsite effect and loose traction instead of gaining.
Old 04-15-2013, 07:20 PM   #10894
Morpheus847's Avatar
Trader Rating: 22 (100%+)
Have a question for you guys that have done the shock flip on the rear of the buggy. Did you swap the rear hubs also? The reason I ask is because when the hubs are left on the correct sides the camber link has alot of angle, if the hubs are swapped also the camber links stay lined up with the lower arm. All in all I liked the buggy pretty well, very loose on power though needs a lot more rear traction, if I bearly touched the throttle coming out of a slow corner I was going around. 1/8 ebuggy spoiled me I broke a rear hub on about my third practice lap. Moved the camber link to the outside hole and kept running though. After I relearned myself to drive 2wd, I stopped crashing every corner, lol, still need a little more traction though coming out of the corners, maybe a lighter trigger finger would help most, lol.
Hubs on correct side
Hubs flipped on opposite side
Tekno NB48.3, Werks B6, Byrons fuel
Mugen MBX6 tekno v4, Tekin RX8, Tekin T8 2650kv
TLR 22SCT 2.0 Brushless Hobbies 120a., Trinity DUO 10.5
SMC Batteries
Morpheus847 is offline   Reply With Quote
Old 04-15-2013, 08:08 PM   #10895
Now that I have looked at the manual for the first time I think the hubs were on backwards to begin with.
SMC Batteries
Old 04-15-2013, 09:31 PM   #10896
TAMAK's Avatar
Trader Rating: 28 (100%+)
Hub direction does not matter, the toe insert within the hub is critical! The hubs themselves can be installed left or right depending on youre wheelbase setting, as the turnbuckle can mount easier.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 04-15-2013, 09:36 PM   #10897
Trader Rating: 19 (100%+)
If you're loose on power a few things can help: shorter rear camber link, moving the lower shock mount in, and lowering the rear inner ballstud. Try one at a time as they have other effects on handling elsewhere on the track, so you need to find the balance that works for you.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 04-16-2013, 05:22 AM   #10898
RC10Nick's Avatar
Just remember its always possible to go too far in any direction when adjusting RC. You could be rolling so much that the outside tire starts to ride on the sidewall and looses traction because there's no tread.
Another thing to try would be moving the link on the hub to the next outer hole. That will reduce the amount of camber gain so you won't ride on the sidewall of the tire.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 04-16-2013, 05:28 AM   #10899
Jack Smash's Avatar
Trader Rating: 29 (100%+)
You are getting a little confused on your terminology here. Lowering the inner camber link does not lower the roll center, it raises it. That is why when you removed shims from the inner camber link you lost traction. You raised the roll center, which causes an increase in roll stiffness, which reduces body roll, and therefore traction. Make sense?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 04-16-2013, 08:02 AM   #10900
That's a bit backwards. A longer link will promote more body roll, and IF he is riding on the outer edge of the tire, that will only make it worse. To reduce that, either more static negative camber needs to be added, or remove inner ballstud washers to increase camber gain.
Old 04-16-2013, 01:55 PM   #10901
well after putting the buggy back together, my idea above in the 2nd pic keeping the camber link strait with the lower arm didn't work. When putting the tire on the ballcup end rubbed the inside of the rim. Ended up leaving the hubs turned that way and just mounted the camber link on the backside, now it's lined up above the axle so nothing rubs.
SMC Batteries
Old 04-16-2013, 02:34 PM   #10902
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
Bman's chassis are the bomb!!!
Durango DEX210 Thread-b1.jpg   Durango DEX210 Thread-b2.jpg   Durango DEX210 Thread-b3.jpg
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 04-16-2013, 02:49 PM   #10903
Tdiddy's Avatar
I found this picture interesting.
It's from the book,
MOTOGP Technology by Neil Spalding
(notice the directions the arrows point)
This shows that a motor spinning in the same direction as the wheels will tend to lift the front.
A motor spinning in the opposite direction as the wheels will tend to hold the front down.
I found while applying about 1/2 throttle on a high grip clay track with the car set in MM4 and a Reedy 10.5, it would could easily flip over backwards.
I've changed it to MM3 to see how this setting works.
Mark Thomas
Old 04-16-2013, 03:18 PM   #10904
Jochim_18's Avatar
Thank you for anwering my for the roll center adjustment for this buggy. Now I undestand when you add shims on the inside ball stud you lower the roll center instead of removing it to induce more roll into the buggy. thats why I ask because the camber link angle from the center line of the car is higher from the outside link when you add shims in the inside ball stud which for me raise the roll center higher.
I have't really played with setup changes on 2wd buggy but now I understand. Coming from touring car for the 11 years and I have only driven
4wd buggy setting up TC and 4WD buggy is similar.
Old 04-16-2013, 08:51 PM   #10905
DangerCow's Avatar
I'm wondering if anyone has a good gear-diff set-up for loose-to-mid traction dirt?
I know I know...I should be running the ball diff (which I have), but I'd like to give the gear-diff a shot as our club moves from indoor carpet to outdoor dirt.
I run Calibers in the rear, ribs in the front, and have yet to configure the geometry.
I ran 1000cst in my diff for the whole of the 7 month indoor season (high-grip carpet), and I expect to initially try 2000cst outdoors but would love to hear ideas!
I will be doing the rear-shock mod, and may try RM4 as traction can be low at the start of the season (later on the track get "sealed" with some, I don't know, glue or something).
Thanks for your time thinking of this!
___________________________________________
Axial Scorpion; Exo ../.. Kyosho Turbo Ultima; USA-1
Schumacher CAT K1; Cougar sv2; Cougar KF ../.. Serpent 411 ERYX 2.0
Tamiya XV-01 Pro ../.. Team Durango DEX210; DEX410; DEX408v2
Yokomo B-Max III Factory www.corvictoria.com
DangerCow is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16581 11-23-2017 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
