Like Tree26Likes
Old 04-03-2013, 08:11 PM   #10801
Originally Posted by ewashburnaf View Post
I can put two thumb screws on in less than 15 secs... I have two hands... and do both at the same time. Velcro or thumb screws... who really cares?!?
maybe he does not tap them? it really helps them a lot untapped ones are hard to get on for me actually hurts my poor fingers , but when tapped they are great.
but with the velco strap you would not even have to worry about the battery strap.
ooberman is offline   Reply With Quote
Old 04-03-2013, 09:51 PM   #10802
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Originally Posted by WolfAusti View Post
Finally got to try out my dex210 this weekend! I was overall impressed with how easily I was able to find a setup that suits my driving style and track. I ended up getting 4th, which I thought was a solid start with this new buggy. The guys ahead of me definitely had way more skill than I did.
Couple of concerns:
1. On my second lap of my first heat I broke a rear hub right where the ball stud threads in. I was pretty surprised this beefy part broke. I'm hoping this was just a fluke? I decided to switch to the third hole out with hopes that more material around the ballstud will make it more durable.
2. My buddy who runs a dex210 broke his transmission case at the camber link mount twice this weekend running in stock. Is this a pretty common issue? Any known fixes? Definitely a very annoying thing to deal with considering the time it takes to fix it.
3. The buggy is mediocre at best on initial turn in. It pushes pretty hard until I hit the brake and really force it to rotate. Running on a wet clay track with green bar codes with traction compound all around and with closed cell inserts in the rear, open in front. Tires are what the fast guys are running. I'm running brown associated fronts (1.85) and dark blue durango springs in the rear. 6 hole pistons with 32.5 wt up front, 30 in the rear. The suspension feels nice and complies very nicely. I feel like I have plenty of side bite as well. I think I will switch my battery to the forward location. Will this help with my pushing problem? Any other ideas are greatly appreciated.
Based on your tire choice and your description of the track it sounds and looks like you have decent traction. What was the reason for going rm4? Rm4 is usually for very low grip dusty tracks. That alone may be the issue with turn in. Also almost everyone i know runs 4 hole, 3 hole, and even 2 hole pistons. You can run 6 hole but even 35 wt oil is pretty light. But thats just my opinion.
zipperfoot is offline   Reply With Quote
Old 04-04-2013, 04:35 AM   #10803
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Originally Posted by P6 View Post
maybe i got one hand and two fingers d1k lol why does it matter i just want to switch to velcro doesn't affect you
Precisely! To each, his own.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 04-04-2013, 04:43 AM   #10804
8ight-e's Avatar
Trader Rating: 57 (100%+)
w/ 6hole, 1.2's on the front and rear 45wt in the front and 40wt in the rear works very well,, I wouldn't go much lighter than that myself.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 04-04-2013, 05:52 AM   #10805
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
I just want to give everyone interested in the chassis an update. They are all finished and going to get Hard Coated today. The anodizor said about a week because of scheduling. Everyone who has Pm'd me I believe I have gotten back to. If not pm me again and I will try my best to respond. With the abundance of Pm's about the skids and chassis, I've been overwhelmed from your support. I want to thank everyone that has purchased items from me. With that being said I still have a few +8 and +10 chassis available from the second batch. With outdoor season approaching fast, i am not sure if I will produce any more after this. So get them while you can. Thanks again guys.......Bman
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 04-04-2013, 07:28 AM   #10806
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Also reaming out the original holes is almost mandatory, the stock holes are too small and the beveled part of the thumb nuts will eventually break the battery strap. Here is a picture of what I am talkin about, aftermarket thumb nuts but rule still applies.
nolimit208 is offline   Reply With Quote
Old 04-04-2013, 07:35 AM   #10807
Oasis's Avatar
Trader Rating: 36 (100%+)
It affects the whole mojo..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 04-04-2013, 08:53 AM   #10808
Default dest210r
Does anyone here run the dest210r, Im looking for a better chassis for the stadium truck as I have broke two already. I would like to get an aluminum chassis but as to my knowledge no one makes one.
Dickchucksteve is offline   Reply With Quote
Old 04-04-2013, 03:58 PM   #10809
I make stainless steel skids for the front and rear on the Dimec chassis and Rcjunky makes an aluminum SC chassis. I included some pics of my stuff. It's all what you prefer...
Durango DEX210 Thread-210front.jpg   Durango DEX210 Thread-210rear1.jpg   Durango DEX210 Thread-210lrear.jpg   Durango DEX210 Thread-f2.jpg
Xray Xb2 CE
Old 04-04-2013, 04:56 PM   #10810
rcjunky1's Avatar
I am working on alloy st and sc chassis. I'm still not 100% happy with them and are still a work in progress. So far all feedback from the few running them is very good, just the fit isn't quite as good as I want it to be. Stay tuned, but it still may be a bit yet.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 04-04-2013, 07:26 PM   #10811
Trader Rating: 41 (100%+)
I dont feel like searching through all the post so does anyone know of a good fitting 12mm rear hex conversion? Thanks Joe
2SlowTC is offline   Reply With Quote
Old 04-04-2013, 10:17 PM   #10812
Trader Rating: 19 (100%+)
Any 12mm clamping hex for a B4 will do the trick. Maybe like these: http://www.tresrey-usa.com/yaiba-rac...rear-12mm-hex/
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 04-05-2013, 05:10 AM   #10813
Cool thanks...also anyone converted the front end to 12mm?
Old 04-05-2013, 05:35 AM   #10814
Trader Rating: 21 (100%+)
Originally Posted by nolimit208 View Post
If you run on a high bight track and have previously ran the slipper tight and now its slipping more than usual Look at the link below this is most likely your issue. All you need is one of the washers that you use by the idler gears, usually if your not running 4 gear you should have some left over from the build.
http://www.petitrc.com/setup/durango...perSpacerWear/
This tip just saved me a bunch of frustration. Thanks!
mulepic is offline   Reply With Quote
Old 04-05-2013, 06:07 AM   #10815
Khador12's Avatar
I used this front hex conversation. It was very easy to do.
http://www.petitrc.com/setup/durango...0_FrontHexMod/
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 Today 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
