Like Tree23Likes
Old 03-31-2013, 04:21 PM   #10771
Trader Rating: 520 (100%+)
Originally Posted by SOuthernFRIED View Post
Does everyone use the stock Durango 3x8x3.5 thrust bearing? Or is there a better alternative?
I'm going to be rebuilding the ball diff in my recently purchased dex210 soon, and I'd like to make it the best I possibly can.
There are a few things to do to get more turn in, moving the battery would be the easiest and quickest, also a weight in the bottom of the chassis in place of the plastic plug would be my next move. Tresrey makes a rear ball stud mount if you are having problems with the trans mount, i have use it in the past, and its bullet proof. The stock diff parts are really good, and easily outlast any other brands parts, but Bfast does make very good stuff if you feel the need for something different.
flame56mx is offline   Reply With Quote
Old 03-31-2013, 04:42 PM   #10772
MX943's Avatar
Trader Rating: 41 (98%+)
Arrow
Ttttt
B5M
2013 BMW S1000RR Motosport 200hp
2015 Yamaha YZ450F,2002 CR250R
Aprilia Tuono ,2006 CRF450X st legal
BMW M3 E46
MX943 is offline   Reply With Quote
Old 03-31-2013, 05:07 PM   #10773
P6
i got the vega rear camber link mount once i broke my trans case just dremel or cut off the camber tabs add 2mm under the vega piece and its stock with three holes and im wanting to get alum rear hubs they seem like a bad landing can ruin a run pretty easy ive only broke one but it didnt take much and the ballstud broke through to the next position
P6 is offline   Reply With Quote
Old 03-31-2013, 07:27 PM   #10774
Oasis's Avatar
Trader Rating: 36 (100%+)
Originally Posted by ae4ever View Post
Bfast pro kit is the way to go!
Yep..I ran the same diff (bfast thrust, diff rings & diff balls) in my 210 for 8 months ()..that's twice a week racing and it was starting to feel gritty 2 weeks ago..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 03-31-2013, 08:43 PM   #10775
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
Thanks for the answer's guys... B-fast it is!
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
SOuthernFRIED is offline   Reply With Quote
Old 04-01-2013, 12:19 PM   #10776
WolfAusti's Avatar
Trader Rating: 37 (100%+)
Originally Posted by P6 View Post
can anyone post pics of how your doing the velcro battery straps, using the thumb screws is getting annoying when im moving the battery foams for track conditions
P6, for the battery strap I dremeled slots right between the battery mount posts as shown in these shots. If you're running the battery forward, I would highly recommend gluing a foam strip down on the chassis right in front of the rear retainer. This keeps the battery from rattling around since it's only being held down in one place and not towards the back of the pack. I used the foam that hobbyparts batteries are packaged with and it seems to work well. I'm running a losi 22 battery strap.
Daily drivers: B5M | Xray XB4 | Axial YETI | Scion FR-S
WolfAusti is offline   Reply With Quote
Old 04-01-2013, 06:09 PM   #10777
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Guys what springs and Ride Ht. are you running? Thanks...
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 04-01-2013, 06:26 PM   #10778
Trader Rating: 62 (100%+)
Losi orange front, pink rear. 23mm front and 24 rear.
TEKNO RC * TLR * EXOTEK
patrick is offline   Reply With Quote
Old 04-01-2013, 06:44 PM   #10779
sc10pc's Avatar
Smile
Originally Posted by TAMAK View Post
Just mounted my shocks on the rear of the arm. I facebooked Jorn and he states it provides more rear traction. I am testing this out on Wednesday.
Attachment 1042312
Tamak i saw this tonight and decided to do this to my buggy as well and i want to know what your setup is for the buggy after your shock flip? Thanks
Ofna Nexx 10SC: Novak Ballistic 550 4.5t, Novak GTB2, Orion Vortex 1007
Durango DEX210: Tacon 8.5t sensored, Duratrax DE10, Savox SC1257TG
Team Associated B44.1: Viper VST6.5T, Duratrax DE10, Orion Vortex 1007
RETIRED: Team Associated B44
sc10pc is offline   Reply With Quote
Old 04-01-2013, 06:56 PM   #10780
Trader Rating: 29 (100%+)
When I ran the losi 22 everyone was trying to get rid of these straps, now people want them on the 210.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 04-01-2013, 09:01 PM   #10781
Originally Posted by Bman's 3XNT View Post
Got some goodies in today! +8 wing brackets..... I also finished putting my +8 Hard coat all together
Update on the second run: Posted a pic of the first +10 off the mill....
wing mounts: Black, Alloy, +8mm. Its like they made them to match your chassis Especially with the timing of release.
They look good too, is it me or is there more wire clearance too for the motor with the lower bracket?
and the chassis is just stunning. cant wait to get it and have it all mounted up.
glenng is offline   Reply With Quote
Old 04-01-2013, 09:09 PM   #10782
more specifically: bfast carbide diff balls with his sanded down diff rings and also ceramic thrust balls with the treated thrustwashers to replace the caged race setup that durango provides. I think he has a whole package deal for all those pieces and then associated stealth difflube (part # 6591) on the carbide diff balls and associated black grease on the thrust. and you will be super lovely.
Old 04-01-2013, 09:17 PM   #10783
i like TD dark green up front and TD Black in the rear. some guys at my track do light red all around, and i tried that on friday, but i think i like a tiny bit stiffer spring up front and the dark green is not overly stiff by any means. im also gonna try out losi silver up front and pink in the rear this friday during practice. seems commensurate to an all TD dark green on all corners (though amain is outta dark green rear)
Old 04-01-2013, 10:00 PM   #10784
Oasis's Avatar
This is for a indoor clay track, medium to high traction, front springs are TD Dk. Green, pistons are 1.4 4 hole, 35wt. Losi. Rear: Losi Pink, 1.4 4 hole, Losi 30wt. Ride height is 23mm front & rear.
Old 04-01-2013, 10:12 PM   #10785
WolfAusti's Avatar
Wasn't aware of that! I actually much prefer that strap over running plastic thumb screws. Just can't justify paying $10 for aluminum ones...
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
EbbTide
